BiggTim Posted August 13, 2017 Share Posted August 13, 2017 Can anyone confirm for me what spinner Galland had on his E-4? Hole, or no hole? Thanks, Tim Link to comment Share on other sites More sharing options...
CANicoll Posted August 13, 2017 Share Posted August 13, 2017 Well, I've seen pictures with the central cannon installed i.e his E White 13, and other pics of White 13 with the spinner cannon hole covered. I think you can grab a pic that you like and go with that aircraft. Look here for a pic of the cannon hole covered over. Chris BiggTim and LSP_K2 2 Link to comment Share on other sites More sharing options...
BiggTim Posted August 13, 2017 Author Share Posted August 13, 2017 That is the reason for my confusion. I keep finding pics of both spinners, and I couldn't figure out if it was the same plane or not. Good to know I am not insane. CANicoll 1 Link to comment Share on other sites More sharing options...
LSP_Mike Posted August 13, 2017 Share Posted August 13, 2017 Tim, can you get a Werk No. from one of the pics? BiggTim 1 Link to comment Share on other sites More sharing options...
Lud13 Posted August 13, 2017 Share Posted August 13, 2017 Well, I've seen pictures with the central cannon installed i.e his E White 13, and other pics of White 13 with the spinner cannon hole covered. I think you can grab a pic that you like and go with that aircraft. Look here for a pic of the cannon hole covered over. Chris That is the picture of Bruno Hegenauers Bf 109, member of JG26 Stabschwarm.. No wing camera and spiner is white with green tip, AG Emil had yellow spiner and wing camera, and yes spiner had a cap not hole for the gun. BiggTim 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted August 14, 2017 Share Posted August 14, 2017 ...and no 109E had a centerline gun/cannon . BiggTim 1 Link to comment Share on other sites More sharing options...
BiggTim Posted August 14, 2017 Author Share Posted August 14, 2017 (edited) Tim, can you get a Werk No. from one of the pics?I can't seem to see the WN in the images I have, but the Trumpy E-4 box art depicts it with a solid spinner. I have some othwr artwork that shows it with an open one. I'll try to locate some photos. This is the one. https://goo.gl/images/RCy28B It looks to me like the spinner is flat, but I know better than to trust a painting. Also, the same plane is depicted on the cover of the squadron 109E book with a hole in the spinner. Again, I don't trust it. Edited August 14, 2017 by BiggTim Link to comment Share on other sites More sharing options...
Artful69 Posted August 14, 2017 Share Posted August 14, 2017 ...and no 109E had a centerline gun/cannon . Actually the E-2 Had the wing 20mm FF's plus a 20mm firing through the spinner ... as well as the cowl MG's. It was notoriously unreliable though (the engine mounted gun), and thats why production was halted in favour of the E-1's and E-3's Rog BiggTim 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted August 14, 2017 Share Posted August 14, 2017 This may sound like sacrilege, but I much prefer the look of the spinner without the cap, so I'd leave it off, but that's just me. BiggTim 1 Link to comment Share on other sites More sharing options...
nmayhew Posted August 14, 2017 Share Posted August 14, 2017 ...and no 109E had a centerline gun/cannon . What he said I think this is a classic example of modeller myth becoming accepted as fact, and yet with no actual basis BiggTim and MikeMaben 2 Link to comment Share on other sites More sharing options...
BiggTim Posted August 14, 2017 Author Share Posted August 14, 2017 This may sound like sacrilege, but I much prefer the look of the spinner without the cap, so I'd leave it off, but that's just me. Me too! LSP_K2 1 Link to comment Share on other sites More sharing options...
nmayhew Posted August 14, 2017 Share Posted August 14, 2017 Actually the E-2 Had the wing 20mm FF's plus a 20mm firing through the spinner ... as well as the cowl MG's. It was notoriously unreliable though (the engine mounted gun), and thats why production was halted in favour of the E-1's and E-3's Rog Do have evidence any of these actually flew in combat? I have records of every German a/c shot down over Britain and no 109s - where armament was recorded - had a cannon firing through the hub. Still very suspicious! Dany Boy and BiggTim 2 Link to comment Share on other sites More sharing options...
BiggTim Posted August 14, 2017 Author Share Posted August 14, 2017 (edited) Still very suspicious! Indeed. However, I seem to recall reading an article that said AG might have replaced a damaged solid spinner with a holed one at some point in the life of the a/c, but can't recall the source now. I certainly would like to see a photo of it to confirm. Where's Martin and his amazing library of photos? Edited August 14, 2017 by BiggTim Link to comment Share on other sites More sharing options...
BiggTim Posted August 14, 2017 Author Share Posted August 14, 2017 BTW, I finally spotted the work number of this aircraft - its 5819. Link to comment Share on other sites More sharing options...
DougN Posted August 14, 2017 Share Posted August 14, 2017 His E4's had the cap, however, note that there are two types of caps. One "factory" looking one that is more pointed, and one "field applied" looking one that is more blunt. I would suggest picking up the Dragon E4 kit for a Galland 109E4 if you can, as it gives you both types of caps (and looks 100 times better IMHO). CANicoll and BiggTim 2 Link to comment Share on other sites More sharing options...
