BloorwestSiR Posted January 31, 2017 Share Posted January 31, 2017 With a pair of Spitfires for the Jurassic Plastic and Keep it Civil group builds on the bench, I got carried away and started working on another pair that I've wanted to do for some time. The unique looks of the the HF VII with its extended wingtips and Ocean Grey/PRU Blue paint scheme has had a big appeal to me. Likewise, the VIII with the iconic Grey Nurse shark mouth is hard to resist. The biggest challenge for building a VII was the deeper rear canopy section and the rear pressure bulkhead. Roy Sutherland's build of the VII in the "How to Build Tamiya's Spitfire" book was a great source of inspiration. Unfortunately it didn't cover how to make the rear canopy. I cut and spliced two canopies together to get the correct depth, hoping to use it as a master for a smash moulded replacement. Unfortunately it didn't work out with the sheet plastic melting and deforming my master. Guess I should have expected that but that was my first try at this sort of thing. My second try, I simply bent the plastic sheet to the right shape. This seemed to work out much better. With that out of the way, I turned my attention to the fuselage modifications. I started by cutting away the rear section to match the new canopy. Here is the modified one in front of the VIII fuselage. Shaka HI, Christoffer Lindelav and mpk 3 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 31, 2017 Author Share Posted January 31, 2017 For Grey Nurse, I decided I wanted to do in flight and use the display stand that Tamiya includes with the kit. Of course this meant a pilot figure would be required. The kit figure is in the typical European flight uniform which would be far too warm for Pacific based crews. Fortunately Master Details released a suitable figure. Comparing his torso to the kit pilot revealed that he was significantly taller in stature. This is even more apparent when he's seated in the cockpit which I dry fitted to see. Vs. the kit pilot: Time for some mods here. Carl cib2265, Shaka HI, mpk and 1 other 4 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 3, 2017 Author Share Posted February 3, 2017 A small update here. I attached the pilot's legs and then started trimming away the parachute so that he could sit lower in the cockpit. At the same time, I trimmed the seat down to get him further into the "bucket" of the seat. By the time I was done, there wasn't much of a bucket left. Carl Shaka HI, cib2265 and MikeMaben 3 Link to comment Share on other sites More sharing options...
cib2265 Posted February 3, 2017 Share Posted February 3, 2017 Just about to do that exact same figure for my NMF Tamiya 1/32 Mk VIII Spitfire - will follow for sure... Its a pity you need to attach the 30 gallon slipper tank to use the inflight stand....i wonder if theres a work around? Link to comment Share on other sites More sharing options...
Shaka HI Posted February 3, 2017 Share Posted February 3, 2017 Carl, what's with this obsession with Spitfires? There's gotta be a story behind this...if I'm not mistaken, it's not even your favorite AC??!? Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 3, 2017 Author Share Posted February 3, 2017 (edited) Just about to do that exact same figure for my NMF Tamiya 1/32 Mk VIII Spitfire - will follow for sure... Its a pity you need to attach the 30 gallon slipper tank to use the inflight stand....i wonder if theres a work around? I think if you're looking to attach it permanently, you could drill a hole in the lower wing and fit the nut from the inside. I used their stand on a 1/32 X-15 and that's how I did it. It's attached with the screw so is removable but you'll have the hole showing. Edited February 3, 2017 by BloorwestSiR Shaka HI 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 3, 2017 Author Share Posted February 3, 2017 Carl, what's with this obsession with Spitfires? There's gotta be a story behind this...if I'm not mistaken, it's not even your favorite AC??!? I'm not really sure Shaka. I think a lot of it has to do with how great the Tamiya kit is and that I've been able to get them at a decent price. It's also lent itself to building other variants without too much work. Carl Shaka HI 1 Link to comment Share on other sites More sharing options...
dennismcc Posted February 3, 2017 Share Posted February 3, 2017 Building 2 Spitfires at once, sounds good to me, the HF VII is a very attractive looking aircraft and I remember the same article firing me up to build one, but alas as usual I was sidetracked by some other builds. So I will be very interested to see how this one goes. Cheers Dennis Shaka HI, BloorwestSiR and mpk 3 Link to comment Share on other sites More sharing options...
Joel_W Posted February 4, 2017 Share Posted February 4, 2017 Carl Certainly an interesting duel build for sure. Joel mpk, BloorwestSiR and Shaka HI 3 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 6, 2017 Author Share Posted February 6, 2017 Building 2 Spitfires at once, sounds good to me, the HF VII is a very attractive looking aircraft and I remember the same article firing me up to build one, but alas as usual I was sidetracked by some other builds. So I will be very interested to see how this one goes. Cheers Dennis Thanks Dennis! I really wish Barracudacast had released a conversion set for it after he did the article and made the masters. I emailed him asking if he was going to but never got a reply. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 6, 2017 Author Share Posted February 6, 2017 Carl Certainly an interesting duel build for sure. Joel Thanks Joel! I think I'll be able to pull it off. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 6, 2017 Author Share Posted February 6, 2017 With the seat and the pilot's parachute pack cut down, it was time to see how it all worked together. I painted and attached the seat to its bulkhead and then dry fitted it doing with the IP. As you can see, this is a really tall pilot. So some foot surgery was required. I did a test fit in the fuselage to see how he looked: With his head in place and the windscreen on: I think I'm in the clear now. Except that I now have to paint a figure. Carl Anthony in NZ, MikeC and Totalize 3 Link to comment Share on other sites More sharing options...
LSP_Ron Posted February 6, 2017 Share Posted February 6, 2017 Ouch, he must be pissed about chopping off his feet! I think I'm in the clear now. Except that I now have to paint a figure. I'd feel the same way. Joel_W and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 6, 2017 Author Share Posted February 6, 2017 Ouch, he must be pissed about chopping off his feet! I guess we'll call him Stumpy. Serves him right for being so tall I've just stripped the paint off from my first attempt at painting him. This could take a while. Carl Link to comment Share on other sites More sharing options...
Joel_W Posted February 6, 2017 Share Posted February 6, 2017 Carl, Good luck on your 2nd try at painting the figure. I've never gotten one half good enough to use. It's a skill set I just never mastered the basics of. Joel mpk and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
