mozart Posted April 7, 2016 Share Posted April 7, 2016 Clever construction Carl, I like it! Max Link to comment Share on other sites More sharing options...
Azgaron Posted April 7, 2016 Share Posted April 7, 2016 Nice job! Looking good so far! HÃ¥kan Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2016 Author Share Posted April 7, 2016 Thanks Max and HÃ¥kan! I gave the bays a quick wash and then installed then in the fuselage halves. As expected, you can't really see much. Zero77, Shaka HI and dmthamade 3 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 7, 2016 Author Share Posted April 7, 2016 I then added a few tabs to the fuselage halves to help hold them together. It worked better than I thought since in this pic it's only the tabs holding the unglued halves together. With glue added and some clamps for a hopefully good joint. dmthamade, Zero77 and Shaka HI 3 Link to comment Share on other sites More sharing options...
Guest Posted April 7, 2016 Share Posted April 7, 2016 Lovely !.....Harv Link to comment Share on other sites More sharing options...
Azgaron Posted April 7, 2016 Share Posted April 7, 2016 Looks great! HÃ¥kan Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2016 Author Share Posted April 8, 2016 Thanks gents! Here it is with the clamps and tape off. It's a very simple fuselage shape. One of the reason I wanted to get the fuselage together first was to see if the cockpit bulkhead would need any tweaking to fit. Thankfully, I just had to shave a bit off the resin pour stub to make it fit. Zero77 and Shaka HI 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 8, 2016 Author Share Posted April 8, 2016 I think you can make out the small amount that needed shaving off to fit the bulkhead. With the bulkhead test fitted to the fuselage: While the fuselage was setting up, I assembled the main wings. After removing them from the sprue, I used tape as handles to make then easier to sand. A few quick passes and the mating surfaces were flat. This kit is going together faster than I thought it would. I think it's partly being a simpler kit and also the quality of the mouldings even though it's limited run. Then again, I haven't done the cockpit yet so we'll see I guess. Carl mozart, Zero77, Shaka HI and 2 others 5 Link to comment Share on other sites More sharing options...
Azgaron Posted April 8, 2016 Share Posted April 8, 2016 Nice work with the bulkhead and wings! HÃ¥kan Link to comment Share on other sites More sharing options...
BradG Posted April 9, 2016 Share Posted April 9, 2016 Famous last words "wow this kit is falling together" BloorwestSiR 1 Link to comment Share on other sites More sharing options...
dennismcc Posted April 9, 2016 Share Posted April 9, 2016 This is looking very promising, bodes well for other FLY kits. Cheers Dennis Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 9, 2016 Author Share Posted April 9, 2016 Famous last words "wow this kit is falling together" Yup, isn't that the truth! I can see some possible issues with the nose gear too. Carl Link to comment Share on other sites More sharing options...
Fooesboy Posted April 9, 2016 Share Posted April 9, 2016 Hi Carl, Great work so far, and soooo fast too! Just to help me understand, how are you cleaning up the seam on the nacelles? The reason I ask is that it looks like your method is going to be much faster but I cant quite get my head around it. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 10, 2016 Author Share Posted April 10, 2016 Hi Carl, Great work so far, and soooo fast too! Just to help me understand, how are you cleaning up the seam on the nacelles? The reason I ask is that it looks like your method is going to be much faster but I cant quite get my head around it. Thanks Fooesboy! The resin inserts are fairly deep and will end up covering most of the inner seam. It's only near the openings that you need to fill and sand. I'm only planning to do the lip and not go too much further in. I'll try to get a pic up later. Once they're sanded smooth, I can then glue the inserts in from behind. Carl Fooesboy 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 11, 2016 Author Share Posted April 11, 2016 So as expected, I've run into some concerns with the nose landing gear. The support arm is made up of two parts, 65 and 68 as seen here in there instructions. They're a butt joint so I decided to drill them and add a pin for strength. Once I did that and test fitted the part, I realized it was too long. So I shortened it and reattached the two together. Compared to a stock part: When I checked the Kagero book, I noticed that the "A" shaped link was solid on one side. It's the upper bit resting on the tire in this image: So out with the sheet plastic and hopefully this works. Zero77 1 Link to comment Share on other sites More sharing options...
