1/32 Hasegawa P-26A Peashooter Part Deux...
Hasegawa P-26 Peashooter
  • Please log in to reply
187 replies to this topic
#31 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,530 posts
Posted 22 September 2016 - 03:33 AM
Ya..I know the fix is easy. I do wish I rescribed/re-riveted the model before assembly and I would've, if I've seen this issue earlier as it would be far easier to do this un-assembled.
Port side wing, closer to the fuselage as well..as pictured by Doug -- I have that too. Just noticed it.
  • harvey and Leaning_Dog like this
#32 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,530 posts
Posted 22 September 2016 - 04:25 AM
Is this real or a scale miniature replica? I'm searching for picts online and I just can not say what's what with this sample.
  • Peterpools, sandokan and MikeC like this
#33 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,530 posts
Posted 22 September 2016 - 04:32 AM
BTW..that molding issue applies to the other side (underdside) of the wings -- just not as noticeable and obviously as visible in comparison.
Edited by Shaka HI, 22 September 2016 - 04:37 AM.
#34 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 37,855 posts
  • Gender:Male
Posted 22 September 2016 - 05:14 AM
That's the real deal in that photo.
Kev
  • williamj, Clunkmeister and Shaka HI like this
#35 Old Dog
Old Dog
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 284 posts
  • Gender:Male
Posted 22 September 2016 - 02:13 PM
It's only sort of the real deal, per the Air Force Museum's website "This P-26A reproduction is painted to represent the commander's aircraft of the 19th Pursuit Squadron, 18th Pursuit Group, stationed at Wheeler Field, Hawaii, in 1938".  At one time the museum had a real deal but apparently it was on loan and was returned to its owner.
  • Clunkmeister and Shaka HI like this
#36 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,530 posts
Posted 25 September 2016 - 03:54 AM
Some minor work done. Using an old electric toothbrush make sanding putty far more efficient!
  • DougN, MostlyRacers, harvey and 4 others like this
#37 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,530 posts
Posted 26 September 2016 - 01:38 AM
Finished up the the seams/molding issues and another coat of primer.... I think I have a problem, the cowling does not fit over the engine when it's glued together!
Color coats soon -- now it starts to get fun!
  • MostlyRacers, harvey, Peterpools and 1 other like this
#38 MostlyRacers
MostlyRacers
    Senior Member
  • LSP_Members
  • 4,699 posts
  • Gender:Male
Posted 26 September 2016 - 04:49 AM
Good save on these molding flaws, Shaka. I keep the idea of the old toothbrush as a micro-sander :goodjob: !
I think that yes, you are good for prying apart the cowling and regluing it after you have fit the engine. I'd do all the paiting before, so that in the end you have just a small touch-up to do at the engine cowling seams.
Hubert
  • harvey and Shaka HI like this
#39 DougN
DougN
    Senior Member
  • LSP_Members
  • 2,214 posts
  • Gender:Male
Posted 26 September 2016 - 07:24 PM
Yes, the assembled cowling does not fit over the assembled engine, nor should it as the actual aircraft is the same.  As Hubert suggests, you can do most of the painting prior to assembling the two parts of the cowl ring, and then attach them together over the engine, or you can do that first, and just mask the engine area.  Either way, you will need to paint the interior of the cowl ring before attaching it.
Doug
#40 mozart
mozart
    Senior Member
  • LSP_Members
  • 2,060 posts
  • Gender:Male
Posted 27 September 2016 - 08:31 PM
Sounds complicated Shaka but it's coming along nicely! :)
Max
www.ordinarycrew.co.uk
#41 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 23,183 posts
  • Gender:Male
Posted 27 September 2016 - 08:40 PM
Shaka
Very nice; taken care of and the wings look perfect. Looking forward to the painting stages and all the fun
Keep 'em coming
Peter :popcorn:
0338ba3a-e311-4dab-8212-e3c738b97d5d_zps
ZM He 219 A-O
#42 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,530 posts
Posted 02 October 2016 - 07:17 PM
Apologies for the lack of updates...I have such a bad case of Carpal Tunnel on my right arm that I find it difficult to get any work done.
It is getting better -- so I'm glad I don't have to do anything more drastic than what's been proposed to me quite recently!
  • harvey likes this
#43 harvey
harvey
    Senior Member
  • LSP_Members
  • 17,561 posts
  • Gender:Male
Posted 02 October 2016 - 07:59 PM
Any plans for surgery ? I had my wrist cut about 28 yrs ago and not a prob since...........Harv
  • Shaka HI likes this
There's a fine line between cuddling and holding someone down so they can't get away
working on:  Tamiya F4U-2 Night Fighter
Trump P-38M BACK ON BENCH FINISHED!!!
#44 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,530 posts
Posted 02 October 2016 - 09:32 PM
I'm trying to avoid that Harv..
And If I did, it would be my first surgery anything....
Fingers crossed....
  • harvey likes this
#45 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,530 posts
Posted 03 October 2016 - 12:24 AM
Well, I Primed/painted the Prop with Vallejo Air Aluminum. I going try and polish the blades to see how shiny it gets.
The brace I'm wearing makes detail work difficult, but doesn't interfere with painting single color paints!
After light polishing...I'm impressed with this metallic paint!
Edited by Shaka HI, 03 October 2016 - 03:05 AM.
  • harvey, Peterpools, MikeC and 1 other like this
