Pastor John Posted February 25, 2016 Share Posted February 25, 2016 Hi everyone, For some time now the problem of how to display all the Ju 88s and 188s I want to build has existed - in order to capture such a variety of camouflage applications (my main interest in the aircraft). Such a collection takes up so much space in any scale. The most obvious choice to me was to simply leave the wings off - but did I want them on again and built and painted well enough to slot back on and off or did I want to make the fuselage without the moulded on fillet area of the wing root? if I went for this option the model would look more realistic but that realism would only be maintianed if the model was then mounted on a factory dolly. I decided in the end to go with the latter option and worked from many photos to try and get photo-etch set designed to represent the wing attachment points. That done I set about blanking off the hole left in the dissected kit parts minus the moulded on fillets. PE should be here any day but I have made up a test shot ready. I think it looks better like this so even if I do not keep the realism by making a factory dolly - and instead use a wooden plyinth and brass pegs - it is still a good option for how to make a number of the same models. I can always decide now to make the main version as complete models and and others I like as fuselage only models? Anyway I do not have a price yet but if this appeals to you also let me know There are obviously many ways to skin a cat (not that I ever would) - here is just one way that keeps the strength of the parts at all times and allows plenty of space at the end to paint cockpit. I dissected the fuselage into three parts, built up the rear fuselage and added roof part and some locating tabs to surround of rear fuselage. I then added one side with front bulkhead in place, followed by the floor. The other side can then be put on followed by the inner cockpit sides to the front dissected fuselage parts - cockpit side walls need amended as they have detail designed to sink into the cavity of the moulded on wing root. Cockpit can be built up in a way that suits your painting of the sub assemblies. D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Pastor John Posted February 25, 2016 Author Share Posted February 25, 2016 I have made the rear fillets also as separate parts as they are more often than not seen on the fuselage when the wings are not, when fuselage is dissected some of the rear fillet detail is still seen aft of the cut panel line - leave this in place until you are ready to add the fillet as it will help with correct location. D.B. Andrus and dutik 2 Link to comment Share on other sites More sharing options...
Pastor John Posted February 25, 2016 Author Share Posted February 25, 2016 (edited) Naturally you might want to simply buy the PE part to save money - chop off the wing root and blank off and fill yourself - a bit of mess but no dissected parts and trying to put Humpty Dumty back together again. Edited February 25, 2016 by Pastor John Link to comment Share on other sites More sharing options...
Pastor John Posted February 25, 2016 Author Share Posted February 25, 2016 Here is the PE, parts 17-20 are for if doing a 388 without wings Zero77 1 Link to comment Share on other sites More sharing options...
Pastor John Posted February 26, 2016 Author Share Posted February 26, 2016 PE arrived today and I have continued with test shot / display model. there are a few little things to change but you get the idea. Any missing detail is to be scratch built and I will provide what info i can in that regard - nothing difficult. Zero77, mattlow, Iain and 2 others 5 Link to comment Share on other sites More sharing options...
blackbetty Posted February 26, 2016 Share Posted February 26, 2016 you could even go further and use the port and starboard side as two different planes, as well as painting one top and one bottom half to show the horizontal camouflage. with one kit you could get sort of a 3D-3view when mounted to a background.... Link to comment Share on other sites More sharing options...
