alaninaustria Posted February 24, 2017 Share Posted February 24, 2017 I read somewhere that the Jumo 004 could also be started using compressed air to turn the 1st stage compressor over and subsequently the turbine before priming the fuel nozzles - similar to a modern air start cart for jets... Cheers Alan Link to comment Share on other sites More sharing options...
Jan_G Posted February 27, 2017 Author Share Posted February 27, 2017 little work done on this one engines sanded and panel lines renewed in some places. I used the plastic spacers to maintain the necessary width to achieve smooth fit to the wing test fit of main parts. Fuselage surface is now ready for painting, with all sanding and panel lines renewing done What I am really happy about, is the joint of wings and fuselage. it is almost perfect as you can see below, on dry fit pics Thats why I decided to put together wings and engines with all details separately and glue it together with fuselage at the end of the build part. and some PE details One must be patient with these, but the result is worth it thanks for looking jan Volture, dennismcc, MikeC and 1 other 4 Link to comment Share on other sites More sharing options...
Martinnfb Posted March 6, 2017 Share Posted March 6, 2017 Nice details here, me likey Cheers M. Link to comment Share on other sites More sharing options...
alaninaustria Posted March 11, 2017 Share Posted March 11, 2017 Very nice! Coming along nicely!! Cheers Alan Link to comment Share on other sites More sharing options...
Jan_G Posted May 2, 2017 Author Share Posted May 2, 2017 time to work on this one I have managed to glue all exterior PE`s and started with interior here are some photos of progress thanks for looking jan Shawn M, Gazzas, Rick Griewski and 2 others 5 Link to comment Share on other sites More sharing options...
Gazzas Posted May 2, 2017 Share Posted May 2, 2017 My fingers hate the PE I touch, but my eyes really like yours Link to comment Share on other sites More sharing options...
Spaced Marine Posted May 3, 2017 Share Posted May 3, 2017 Looking nice. I have one of these to do myself. I like how the photo etch has come out. It looks good. Link to comment Share on other sites More sharing options...
dodgem37 Posted May 3, 2017 Share Posted May 3, 2017 Delicate work. Nicely done. Sincerely, Mark Link to comment Share on other sites More sharing options...
Guyman1 Posted May 3, 2017 Share Posted May 3, 2017 Wow really nice, The PE gives this model a very detailed look keep going mate this is interesting. Guy Link to comment Share on other sites More sharing options...
Jan_G Posted May 4, 2017 Author Share Posted May 4, 2017 thanks guys for positive feedback! really apreciate it Genereally Im also not comfortable with PE, for me resin stuff is much easier to handle started to paint cockpit with Mr. Paint RLM 66 (and 2 lighter shades of base color) Eduards interior set match quite nicely Mr Paint RLM 66 color, some wetahering and final clear coat should unite it thanks for looking jan Victor K2 and Gazzas 2 Link to comment Share on other sites More sharing options...
VintageEagle Posted May 4, 2017 Share Posted May 4, 2017 Looks fantastic Jan. I just bought the kit as well (my first one after a break of 20 years :-O ) and hope to be able to finish it this year. I have been studying and researching the Me 262 for quite a while know and have thousands of wartime documents in my archive that I copied from various archives. With the risk that I am too pettifogging, I wanted to point out two details of the Eduard panels that are incorrect for the Me 262 B-1a/U1: Eduard's blind flying panel is that of a bad-weather fighter variant with single-axis autopilot, where the large repeater compass was not in the same vertical line as the artificial horizon, but slightly offset to the right. The lower edge of the panel was modified with a curved edge. In the Me 262 B-1a/U1 both the larger repeater compass and artifical horizon were on the same vertical line and the lower edge was also modified, but with straight lines that were more angular than in the standard blind flying panel. This is confirmed by wartime photos. The nice looking red and white circular markings on the engine instruments was a feature that could only be found in certain JG 7 aircraft. I have a wartime document of the Technischer Aussendienst of Messerschmitt that described this field modification by JG 7 incl. drawing of how they marked the different dial ranges with red and white for better and faster reading. Aircraft of other units did not feature this (at least I haven't seen them on any other unit's Me 262) Roger Jan_G 1 Link to comment Share on other sites More sharing options...
Jan_G Posted May 4, 2017 Author Share Posted May 4, 2017 Eduard's blind flying panel is that of a bad-weather fighter variant with single-axis autopilot, where the large repeater compass was not in the same vertical line as the artificial horizon, but slightly offset to the right. The lower edge of the panel was modified with a curved edge. In the Me 262 B-1a/U1 both the larger repeater compass and artifical horizon were on the same vertical line and the lower edge was also modified, but with straight lines that were more angular than in the standard blind flying panel. This is confirmed by wartime photos. The nice looking red and white circular markings on the engine instruments was a feature that could only be found in certain JG 7 aircraft. I have a wartime document of the Technischer Aussendienst of Messerschmitt that described this field modification by JG 7 incl. drawing of how they marked the different dial ranges with red and white for better and faster reading. Aircraft of other units did not feature this (at least I haven't seen them on any other unit's Me 262) Thanks Roger for all these valuable details! Definitely for me its too late to change the panel and position of artificial horizon (dont want to spend more time with this build than needed). At least I have painted that nice looking instruments with boring RLM66 However all such informations will help other guys here who are not experts in Me 262 (like me ) now it looks this way jan Victor K2 and VintageEagle 2 Link to comment Share on other sites More sharing options...
Jan_G Posted May 4, 2017 Author Share Posted May 4, 2017 gentle chipping and highlighted edges thanks for looking jan Victor K2 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 5, 2017 Share Posted May 5, 2017 Jan Enjoying following your progress and so perfectly done.. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
dodgem37 Posted May 5, 2017 Share Posted May 5, 2017 Nice layering effect. Dark, lighter, lightest. Sincerely, Mark Link to comment Share on other sites More sharing options...
