Wackyracer Posted February 3, 2017 Share Posted February 3, 2017 Hi I'm currently building a 109 G-10 as white 44 of NJG11. I'm using the Revell kit along with a hoist of am and pe to get it right. Here's my problem, I've discovered the said plane was a Mtt Regensburg build rather than an Erla so have to make a few mods to my current craft. I can scribe the curved panel to the cowling beneath the cockpit ok and have the small wheel budges already but I need to 'create' the bumps under the engine cowling. I have several Revell 109G-6's in the stash and just wondered if the gun bumps (which are too small anyway) could/would work with a little mod or if anyone else has any ideas? Ironically I have 2 trumpeter G-10's in the stash and should have gone with them but I'm too far into the build now to back out having modified the exhausts for flame dampers etc and throwing a load of Barracuda resin in as well. Link to comment Share on other sites More sharing options...
dodgem37 Posted February 3, 2017 Share Posted February 3, 2017 Can you make the bumps on the Trumpeter kit from resin and attach them to the Revell kit? Sincerely, Mark Wackyracer and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 3, 2017 Share Posted February 3, 2017 Can you make the bumps on the Trumpeter kit from resin and attach them to the Revell kit? Sincerely, Mark That would have been my suggestion, take and coat the bumps from the Trumpy kit in mold release agent, coat them in some resin and take that negative and create a mold to pull a new resin bump to glue onto the Revvie kit. Link to comment Share on other sites More sharing options...
Martinnfb Posted February 3, 2017 Share Posted February 3, 2017 Hi there, do not do anything, the Erla's cowling has nothing to do with Regensburg style. It is very different in terms of shape and size. For example , you can not just scribe the curved panel-line , you would have to cut out the whole panel, insert a new one that is flat and then add a curved bump. The situation gets even worst about upper cowling. You are better off building Trumpeter's kit or perhaps Hasegawa. Also your guns are too much out, please check your references . This photo collection can help. Sorry to serve it to you so bluntly, but it is not time and cost effective, having said that , it can be done .........once? Cheers Martin and again if in doubt check your references, or shoot me a PM Link to comment Share on other sites More sharing options...
Guest Airfixer Posted February 3, 2017 Share Posted February 3, 2017 Agreed.. I'd either recommend to select another decal option for your Erla G-10 or using a different kit to replicate "White 44". The lower cowling in particular is way more voluminous, it's rather "absorbing" the bumps than just lacking them. Besides, you'd also have to install a different oil cooler...different gun ports...completely different cowling geometry, etc... D.B. Andrus 1 Link to comment Share on other sites More sharing options...
LSP_Mike Posted February 3, 2017 Share Posted February 3, 2017 Good catch on the guns, which I see are too far out, and not staggered. The good thing is, you can finish this kit, and do the version you want with less trouble. Link to comment Share on other sites More sharing options...
Wackyracer Posted February 3, 2017 Author Share Posted February 3, 2017 (edited) Thanks everyone. All suggestions make sense. Re the guns I went with what Master show in their instructions and how far the plastic kit ones protrude OK, so I now have a G-10 with flame dampers and erla build. Anyone have a suggested scheme and/or did a bird actually exist? White 44 will have to wait till the next G-10. Edited February 3, 2017 by Wackyracer Link to comment Share on other sites More sharing options...
Martinnfb Posted February 3, 2017 Share Posted February 3, 2017 I see, please refer to to picture here, the guns partial show the first "ring" in similar fashion as it is on regular G's More useful pictures are available here Link to comment Share on other sites More sharing options...
thierry laurent Posted February 3, 2017 Share Posted February 3, 2017 Changing his mind while building a 109 is really a risky business as there were many, many differences, more particularly late in the war... Good luck. Wackyracer 1 Link to comment Share on other sites More sharing options...
Wackyracer Posted February 3, 2017 Author Share Posted February 3, 2017 (edited) Managed to remove the flame dampers so we're back in business. I have severall eduard exhaust sets so can steal the pe guards to replace. So ready for a new scheme. Having both sets of Barracuda G-10 decals I fancy a overall dark green. Hey was going with a overall rlm 76 before so let's move this one to the dark side. Perhaps black 13 jg27 or black 22 jg52 or green 7 jg300. Edited February 4, 2017 by Wackyracer MikeMaben 1 Link to comment Share on other sites More sharing options...
