BloorwestSiR Posted January 27, 2017 Author Share Posted January 27, 2017 Thanks Maru and Jens! The Aires cockpit definitely isn't the best way to go about this. The Mastercasters one supposedly made for the 22 isn't much better though. Anyways, a bit more progress. I assembled and painted the seat along with the belts. I'm using the paper belts made by Wako. Here's the front bulkhead almost finished: I've pretty much got the rest of the cockpit ready for installation in the fuselage. I just need to fit the fuselage tank and I'm good to go. Alain Gadbois, BradG, Shaka HI and 4 others 7 Link to comment Share on other sites More sharing options...
mgbooyv8 Posted January 28, 2017 Share Posted January 28, 2017 Looking good! Cheers, Peter Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 30, 2017 Author Share Posted January 30, 2017 Looking good! Cheers, Peter Thanks Peter! I'm still chugging away at this build. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 30, 2017 Author Share Posted January 30, 2017 So here's the finished front panel. I'll add the gun sight after it's installed in the fuselage. A couple pics of the cockpit together: Shaka HI and BradG 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 30, 2017 Author Share Posted January 30, 2017 I inserted the cockpit into the assembled fuselage and you can barely make out anything. The lower wing was then glued in place with a set of clamps to hold it tight while the glue set. Next up will be the upper wings. Carl Shawn M, BradG, Shaka HI and 1 other 4 Link to comment Share on other sites More sharing options...
Shaka HI Posted January 30, 2017 Share Posted January 30, 2017 Wam, bam, thank you ma'am! Slow down buddy! BloorwestSiR 1 Link to comment Share on other sites More sharing options...
Cees Broere Posted January 30, 2017 Share Posted January 30, 2017 That's one heck of an improvement, how are you going to clean up the port sill ledge? BloorwestSiR 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 31, 2017 Author Share Posted January 31, 2017 Wam, bam, thank you ma'am! Slow down buddy! Slow down? Any slower and my son will be finishing the build for me. Actually it's been all the festivities that have slowed me down. There's one more which is my son's 6th birthday this Friday and then I'll have some free time. Shaka HI 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 31, 2017 Author Share Posted January 31, 2017 That's one heck of an improvement, how are you going to clean up the port sill ledge? Thanks Cees! Originally when I did my test fittings, the ledge was flush against the fuselage side so I'm not sure what happened. With the cockpit door in place, it's all by unnoticeable. BradG, MikeC, Alain Gadbois and 2 others 5 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 31, 2017 Author Share Posted January 31, 2017 Carl, Love the seat,belts and the bulkhead and together the whole ensemble is really IMPRESSIVE. Rock on Carl! Thanks Maru! After some thought, I realized that the cockpit parts for the PCM Spitfires might be a better fit. I'll have to check and see. But that'll be for another project... Carl Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 31, 2017 Author Share Posted January 31, 2017 To add some detail to the wheel bays, I used some upper bay sections left over from an Alleycat E wing conversion. They're not 100% accurate, maybe not even 75% accurate but I like the visual improvement. With a coat of silver on them and some black where the cannon ejection ports are: BradG and Shaka HI 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 31, 2017 Author Share Posted January 31, 2017 Finally, with the upper wings in place. I ended up with a clean joint on the port side and a step on the starboard one. So there should bit of filler there. The same goes for the underside: The last thing I did was drill out the engine exhaust pipes. More to come. Carl Shaka HI, BradG and MikeC 3 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 31, 2017 Share Posted January 31, 2017 Hi Carl Nice progress on the Spit. Don't you just love that when a step appears on one side and not the other. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Alain Gadbois Posted February 1, 2017 Share Posted February 1, 2017 Hi Carl, I have heard this kit was a difficult build, but you are really showing it can be done well with good planning. Seems almost easy.... Link to comment Share on other sites More sharing options...
Shaka HI Posted February 1, 2017 Share Posted February 1, 2017 Really nice, Carl...and I know what this kit looks like cause I have it and will probably use it as test mule for painting/weathering. You gonna rivet this thing? Link to comment Share on other sites More sharing options...
