Tomcat14 Posted December 2, 2017 Share Posted December 2, 2017 Great Looking Phantom. Chris Memir 1 Link to comment Share on other sites More sharing options...
thefenders Posted December 2, 2017 Share Posted December 2, 2017 Memir, How did you shrink an F-4 down to 1/32 scale? Your Phantom, has to be one of the most realistic scale models that I have ever seen!! Amazing build! Memir 1 Link to comment Share on other sites More sharing options...
Vulcan Posted December 2, 2017 Share Posted December 2, 2017 Just awesome... Memir 1 Link to comment Share on other sites More sharing options...
Marcel111 Posted December 2, 2017 Share Posted December 2, 2017 wow, just incredible skill to produce that weathered effect! Awesome! Marcel Memir 1 Link to comment Share on other sites More sharing options...
Spooky56 Posted December 2, 2017 Share Posted December 2, 2017 Outstanding work Memir Memir 1 Link to comment Share on other sites More sharing options...
Gazzas Posted December 3, 2017 Share Posted December 3, 2017 Wow! I really like that fading and chipping! Gaz Memir 1 Link to comment Share on other sites More sharing options...
Eagle Driver Posted December 3, 2017 Share Posted December 3, 2017 Now we are talking serious LSP work! One of the greatest posted here. Ever. Thanx for sharing! Memir and alaninaustria 2 Link to comment Share on other sites More sharing options...
Rocat Posted December 3, 2017 Share Posted December 3, 2017 (edited) Solid weathering skills! Edited December 3, 2017 by Rocat Memir 1 Link to comment Share on other sites More sharing options...
Memir Posted December 3, 2017 Author Share Posted December 3, 2017 Absolutely amazing! There isn't much more I can say, but I will ask, you said that you used Mr color paints, what about the metal areas. Were they Mr color or something else, because they look equally real, fantastic work. Hi Squizzy. Many thanks... Metal areas are mix of MRPs, AK XTREME metal and stabilisers' aft panels are touched up with Uschi's Iron Type Metal Powder. Link to comment Share on other sites More sharing options...
Memir Posted December 3, 2017 Author Share Posted December 3, 2017 I can only say .... WOW !!!! what a job on the weathering !!!! very nice idea .... I like .... if I dared , how did you proceed Alain Hi Alain. Many thanks. As a base I sprayed camouflage fields with MRP SEA colors out of bottle. Then salt masking method and light shades of base colors. Salt removed and darker shades of base colors followed. Those areas simulating moist color around panel lines were sprayed with even darker colors low PSI. Light green received another layer of light tone but with added yellow color to mix. I used fine and worn sanders and sand paper to wear some areas. Then overall Flory washes and local use of ammo panel liners. Some areas were weathered with Tamiya weathering master powders. Should you need more info let me know Cheers alain11 1 Link to comment Share on other sites More sharing options...
Memir Posted December 3, 2017 Author Share Posted December 3, 2017 Holy hell!! That is without a doubt the best F-4 model I've ever seen. The paint work is so realistic it's hard to believe it's a model. It looks so real. Did you know you're missing an antenna on the nose gear door? Great work!!! Jake Hi Jake, many thanks for comments. I have noticed missing antenna after making pictures unfortunately. Probably victim of carpet monster or swallowed by vacuum cleaner. Just found there is the same part in my F-4E kit which is not to be used so I have a spare one and will work on that today... Cheers Link to comment Share on other sites More sharing options...
Memir Posted December 3, 2017 Author Share Posted December 3, 2017 The weathering effect is superlative ad absolutely realistic! :m0152: How did you made scraps of paint? xacto knife? Many thanks for sharing Ciao Filippo Ciao Fillipo, I made scratches 3 different ways: 1. with red Mr Paint riveter but any sharp needle or pin would work basically the same. 2. I used a lot green scouring pad for dish washing. All those tiny dots and scratches are made with it 3. fine or worn sand paper Most of scratches I over sprayed with very light base color to blend them down... Link to comment Share on other sites More sharing options...
Jack Posted December 3, 2017 Share Posted December 3, 2017 Memir, i have to agree with all the statements and admirations, there is nothing more to add, and i think your work displays the craftsmanship of a true modeller, hat's off to you Jack. Memir 1 Link to comment Share on other sites More sharing options...
Jan_G Posted December 3, 2017 Share Posted December 3, 2017 perfect build and stunning weathering!! and welcome to the forum jan Memir 1 Link to comment Share on other sites More sharing options...
Mr b Posted December 4, 2017 Share Posted December 4, 2017 Wow lovely work man...just lovely rgds Memir 1 Link to comment Share on other sites More sharing options...
