1/32 Revell F-4E - What could possibly go wrong!
1/32 Revell F-4E Phantom USAFE aftermarket in flight
  • Please log in to reply
100 replies to this topic
#91 Victor K2
Victor K2
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 152 posts
Posted 08 January 2018 - 06:25 PM
Speaking as a former ground crew, most, if not all stenciling  on aircraft are for the benefit of the Aircrew. If the aircraft had to be "turned round" by them (only likely if they landed at a different, non type operating airbase). The information given on the stenciling would tell them the pressure/type of lubricant etc, needed to replenish the aircraft. Failing that they would ring the home base and ask the engineers advice on what size spanner/screwdriver was required and then ask the ground crew to bring said tools and while they are there "could you please turn the aircraft round as you will be far quicker and we can get back to base".
Why have a dog and bark yourself  :hmmm:
Great work btw.
  • Shawn M and RichieB like this
#92 Shujaa
Shujaa
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 57 posts
Posted 10 January 2018 - 10:21 AM
Oh common'... We can't have the "God's" showing up in the crew-room, buying the spark-chasers & grease-monkey's a beer with dirty hand's or do we...
Hmmm, something funny about that remark. Don't know if it's the combination of the "God's" with dirty hand's or the combination of the "God's" buying the techies a beer... :hmmm:
Kind Regards,
Rudy.
  • RichieB likes this
#93 RichieB
RichieB
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 94 posts
  • Gender:Male
Posted 13 January 2018 - 09:39 AM
Anyone know why the USAF decided to remove most of the stencils other than the sheer number of man hours required to put them on in the first place?
Quick question:
For weathering purposes I'm looking to use a Panel Line Wash and try out the oil dot technique with Mig Ammo Oilbrushers. Which of these should I do first?
I believe they are both enamel type products so I guess they may interfere without sealing coats.
I'm going to test it out on the drop tanks which look like this currently:
Any steers before I kick off would be greatly appreciated!
  • sandokan and F`s are my favs like this
Richie B
More kits than sense.
#94 themongoose
themongoose
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 223 posts
  • Gender:Male
Posted 14 January 2018 - 03:01 PM
I would think the panel line first as it’s about shadowing. Weathering would happen over time and some elements would get into the panel lines.
On the bench - 1/48 Revell PT-17, and a 1/32 T-38 Thunderbird custom build.
#95 RichieB
RichieB
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 94 posts
  • Gender:Male
Posted 15 January 2018 - 09:08 PM
Thanks for the advice, sounds like a plan!
Richie B
#96 Bruce
Bruce
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 517 posts
  • Gender:Male
Posted 24 January 2018 - 12:49 AM
Don’t forget the raised longitudinal seam on the center line tank like the ones on the wing tanks!
Edited by Bruce, 24 January 2018 - 12:50 AM.
#97 RichieB
RichieB
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 94 posts
  • Gender:Male
Posted 24 January 2018 - 09:42 PM
Thanks for the steer Bruce, I'll have to look into it as the Revell tank is obviously devoid of that detail.
Richie B
#98 Bruce
Bruce
    Senior Member
  • LSP_Members
  • 517 posts
  • Gender:Male
Posted 05 February 2018 - 06:59 AM
the squadron walkaround #45 has some pictures you can make out the seam I'm referring to.
also, there are 4 sway braces for the center line pylon that drop down from either side of the drop tank pylon, their location is outlined on the bottom of the kit.  There are two braces that drop down to stabilize the fins on the tank, the location of these are also outlined on the kit.
Bruce
Edited by Bruce, 05 February 2018 - 03:14 PM.
  • Martinnfb, harvey and Shawn M like this
#99 RichieB
RichieB
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 94 posts
  • Gender:Male
Posted 05 February 2018 - 10:00 PM
Many thanks Bruce, just what I was looking for! Some scratch building required here methinks.
Are they rivets or bolts along the tank seamline?
Also, I presume the seam runs only on the left hand side of the tank?
Richie B
#100 Bruce
Bruce
    Senior Member
  • LSP_Members
  • 517 posts
  • Gender:Male
Posted 05 February 2018 - 10:23 PM
I believe the way the tank was made the center section was one piece of sheet metal that was rolled then the ends were bolted together and the cone ends were riveted on much like the wing tanks.  I'll see if I can find any close ups of the seam.
Bruce
#101 Bruce
Bruce
    Senior Member
  • LSP_Members
  • 517 posts
  • Gender:Male
Posted 11 February 2018 - 02:14 AM
Back to the question of why stenciling was reduced on aircraft, as a retired Air Force pilot, it was my understanding that it was driven by costs. When an a/c went in for R&R and repaint, the time required to cut stencils and repaint them slowed the turnaround times and increased costs so only major items were repainted, i.e. grounding points, jack points, etc.
  • harvey, Victor K2 and RichieB like this
Also tagged with one or more of these keywords: 1/32, Revell, F-4E, Phantom, USAFE, aftermarket, in flight
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
