LSP_Kevin Posted March 20, 2017 Share Posted March 20, 2017 I think that this is ok ... I like it Me too! Kev Link to comment Share on other sites More sharing options...
ClumsyDude Posted March 20, 2017 Share Posted March 20, 2017 Looks good to me too Micha. Jim Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 21, 2017 Share Posted March 21, 2017 Nice! Link to comment Share on other sites More sharing options...
spacewolf Posted March 21, 2017 Share Posted March 21, 2017 That's wonderful, love the detail work you are doing !! Vaughn Link to comment Share on other sites More sharing options...
CANicoll Posted March 24, 2017 Share Posted March 24, 2017 Misha, This is fantastic! I just found your build but the detail work is really something. I have to say, the light is perfect for that engine and your description of the build is informative - thanks. Looking forward to more of your work. Keep it up! Chris Girlscanplay2 1 Link to comment Share on other sites More sharing options...
elmarriachi Posted March 27, 2017 Author Share Posted March 27, 2017 Thank you very much @ all! Link to comment Share on other sites More sharing options...
elmarriachi Posted March 27, 2017 Author Share Posted March 27, 2017 Hello. all the kits parts of the underside of the hull are mounted and the holes for all the LED lamps drilled inside the hull. I have installed the wiring and the LED for testing .... lot of wires (without the LEDs for the engine). Next I will make the base and the stand which will include the wires then. ... and lights on for testing ... Some nice small figures are included with the kit, it is even possible to recognize the persons.... I will install Han Solo the captain, Chewbacca and on the seats behind C3P0 and Luke Skywalker. Cheers Micha CANicoll, Girlscanplay2, Menelaos and 3 others 6 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 27, 2017 Share Posted March 27, 2017 Neat! Looks fantastic so far Link to comment Share on other sites More sharing options...
spacewolf Posted March 27, 2017 Share Posted March 27, 2017 A snake pit of wiring.. but the results are wonderful... this is going to look amazing when completed.. Great effort !! Vaughn Link to comment Share on other sites More sharing options...
dodgem37 Posted March 28, 2017 Share Posted March 28, 2017 (edited) Very cool. Got ruler for scale? Thank you. Sincerely, Mark Edited March 28, 2017 by dodgem37 Link to comment Share on other sites More sharing options...
elmarriachi Posted April 10, 2017 Author Share Posted April 10, 2017 Hello, after having added all parts as far as necessary I have sprayed the inside of upper and lower hull in black before gluing the LEDs in the holws with white glue. Around every LED I have added a piece of plastic pipe which was glued in place and filled with white glue from the top side... Then the lightbox for the engine was installed... ... and all wires put together.... finally, there will be four wires going out from a hole in the center of the bottom, inside the display stand... Before having installed the lightbox, the rear side of the hull was painted already ... Menelaos, BiggTim, Girlscanplay2 and 1 other 4 Link to comment Share on other sites More sharing options...
elmarriachi Posted April 10, 2017 Author Share Posted April 10, 2017 Once all the glue was set I have painted also the plastic pipes and the filled white glue in black.... Now there is no chance for any light shining somewhere where it is not planned A testing and everything works as it should Also the LEDs for the cockpit were added now, the lower cockpit area glued to the lower part of the hull. BiggTim, Menelaos and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
elmarriachi Posted April 10, 2017 Author Share Posted April 10, 2017 Once everything is finished in the inside of the hull the upper hull was put on top.... testing, some wires putting in place.... testing, some plastic removing from the lower side of the upper hull at the center of it .... testing ... fits. The upper side was mounted on the lower one with scews... then the lights tested again ... works. After that I have added all the side panels full of added details and the upper part of the cockpit. The docking ports left and right were replaced with 3D-printed parts, painted also black from the inside. Also the radar on the top and the engine nozzles were 3D-printed parts with correct size and better details. The engine will receive some etched grills later after the primering. CANicoll, Menelaos, Girlscanplay2 and 4 others 7 Link to comment Share on other sites More sharing options...
elmarriachi Posted April 10, 2017 Author Share Posted April 10, 2017 With the Dremel I have added some damages as it is seen in several pictures of the movie ... some holes on the upper side nect to the radar, some scratches on the lower side.... Now everything is ready for some first primering Cheers Micha Girlscanplay2, BiggTim, Menelaos and 2 others 5 Link to comment Share on other sites More sharing options...
Uncarina Posted April 10, 2017 Share Posted April 10, 2017 Micha, Huge update, and great work! Cheers, Tom Link to comment Share on other sites More sharing options...
