Mark B. Posted October 16, 2003 Share Posted October 16, 2003 In checking out my Revell F4-E and RF-4C stash kits, I found what I at first thought was a small drop tank/travel pod for the inboard pylons. It is on the "common sprues" between the ECM pod halves. But when I looked closer, I saw that there were only two halves to this pod (so you can only make one of them ruling out inboard drop tanks) and both the front and back ends are squared off and open (ruling out travel pod). I thought it was a gun pod but in comparing it with CAM's SUU-23 it is too short and too thin to be a 20mm cannon pod. I was wondering if anyone knows what it is. #> TIA & Cheers Mark B. Link to comment Share on other sites More sharing options...
Mike Phillips Posted October 21, 2003 Share Posted October 21, 2003 Not sure...but I think its a flare dispenser pod. Mike Link to comment Share on other sites More sharing options...
Mark B. Posted October 21, 2003 Author Share Posted October 21, 2003 Hmmm. Flares as in heat seeking missile counter measures flares? Where would that go, inboard pylon or center line? Thanx for the info Link to comment Share on other sites More sharing options...
Menelaos Posted October 22, 2003 Share Posted October 22, 2003 This is an ECM pod (I forgott what Nr ...) I show it in one of my In action books... will came late with more Infos M. Link to comment Share on other sites More sharing options...
