G-Man Posted October 18, 2017 Author Share Posted October 18, 2017 Just got done repainting the nose of my 109. Used the lint roller, then wiped the booth with excessive water so there was standing water. Worked great and thank goodness as I had just enough RLM04 to finish. Link to comment Share on other sites More sharing options...
CANicoll Posted October 18, 2017 Share Posted October 18, 2017 Question, when you paint something, where do you put it to dry? Sometimes I will push what I've painted to the back of my paint booth but I keep the fan running, the fan so far keeps anything from falling down on the model. Mostly the part is vertical anyway leaning against the side wall or back wall. Or I put it into a container and keep the lid ajar, but covered what I painted. Good luck! Chris Link to comment Share on other sites More sharing options...
G-Man Posted October 18, 2017 Author Share Posted October 18, 2017 Question, when you paint something, where do you put it to dry? Sometimes I will push what I've painted to the back of my paint booth but I keep the fan running, the fan so far keeps anything from falling down on the model. Mostly the part is vertical anyway leaning against the side wall or back wall. Or I put it into a container and keep the lid ajar, but covered what I painted. Good luck! Chris I leave it in the booth to dry, usually push it to one side so my cleaning station will fit. I let the booth run while I clean my airbrush so that it pulls the laquer fumes from my cleaning station. I use Mr. Color paints which don't take very long to dry. Link to comment Share on other sites More sharing options...
Shawn M Posted October 23, 2017 Share Posted October 23, 2017 do you have a ceiling fan in your build room, check the blades they may need a good cleaning G-Man 1 Link to comment Share on other sites More sharing options...
G-Man Posted October 25, 2017 Author Share Posted October 25, 2017 do you have a ceiling fan in your build room, check the blades they may need a good cleaning Good idea! I do have a fan, not directly overhead, but I should make a point to wipe it down. Shawn M 1 Link to comment Share on other sites More sharing options...
Zero77 Posted October 26, 2017 Share Posted October 26, 2017 My room is quite dusty, and i also have some dust bits of micro-hairs on my paint quite often. But as i always try to work with very thin coats of paint, it's dry almost instantly. So the dust is not very stuck in the paint, and it's usually easy to remove with some micromesh or even with a small pair of pliers if it's big enough. I'm just very careful when i have to spray a wet coat, for example to get a high gloss finish. In that case i try to clean everything around, and i spray some water inside the paint booth. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted October 26, 2017 Share Posted October 26, 2017 My room is quite dusty, and i also have some dust bits of micro-hairs on my paint quite often. But as i always try to work with very thin coats of paint, it's dry almost instantly. So the dust is not very stuck in the paint, and it's usually easy to remove with some micromesh or even with a small pair of pliers if it's big enough. I'm just very careful when i have to spray a wet coat, for example to get a high gloss finish. In that case i try to clean everything around, and i spray some water inside the paint booth. Same here. It quells the dust and sticks the hairs down so they dont fly up into your work. I also always make sure I have a nice tack cloth handy, and always go over the model thoroughly before painting. Zero77 and G-Man 2 Link to comment Share on other sites More sharing options...
Timmy! Posted October 27, 2017 Share Posted October 27, 2017 So I paint naked in the shower and use hot water so no wooly jumper required. Sorry I couldn't resist.... This topic caught my attention as I've been laying paint on a project today. On coat 3 of primer, thin ones, and I find hairs, paper towel threads, whatever in my paint usually from the “cleaning†process. However, orange peel, dry overspray and surface flaws are far more common. Clearly a clean spray environment is advantageous to secure a good paint coat. May I suggest an additional investment in 1000-2000 grit sand paper and / or micro mesh sanding cloths. These, a little bit of soapy water and elbow grease will erase any number of painting sins. Hell if you're crazy you can turn flat paint glossy....don't ask how I know. I would suggest you could paint a model and dry it with your cat and with the right sanding tools you could make a contest winner. Good luck and never underestimate what can be done to save a mistake. In best of fun, Timmy! Zero77 1 Link to comment Share on other sites More sharing options...
Gigant Posted October 27, 2017 Share Posted October 27, 2017 (edited) I use micro brushes... they're cheap if you don't buy them at a hobby store. http://www.ebay.com/itm/100Pcs-Disposable-Swab-Applicator-Micro-Brush-Eyelashes-Extension-Mascara-Tools/162505058266?_trkparms=aid%3D555019%26algo%3DPL.BANDIT%26ao%3D1%26asc%3D41376%26meid%3D3bae61aaf6e14629aece1df12ffb0094%26pid%3D100506%26rk%3D1%26rkt%3D1%26&_trksid=p2045573.c100506.m3226 I use them for everything else as well, and they're not that much more at Hobby Lobby. Edited October 27, 2017 by Gigant Link to comment Share on other sites More sharing options...
