BloorwestSiR Posted November 12, 2015 Share Posted November 12, 2015 (edited) So here's one out of the stash. It's not the new Bandai release that everyone (well, Star Wars fans) have been clamouring over but I have it. I figure this will make a decent trial run for when I get to the 1/72 one in the stash. There's not a lot of parts in the kit surprisingly: One of the update sets I have is for the grills on the rear of the upper hull. You have to remove the existing detail first which I did using a r/c body reaming tool. Here's the first one done: And with all of them reamed out. I then installed the resin replacements from beneath. After painting, you add some PE grills over top. Edited November 28, 2015 by BloorwestSiR dpastern, Uncarina, Girlscanplay2 and 4 others 7 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 12, 2015 Author Share Posted November 12, 2015 Here's the turret wells and some of the inserts for the hull. These are the inserts that go on the mandibles and the MLG which I won't be using as I plan to pose it in flight. scvrobeson, Uilleann, Uncarina and 3 others 6 Link to comment Share on other sites More sharing options...
Hartmann352 Posted November 12, 2015 Share Posted November 12, 2015 WooHoo! "She may not look fast, but she's got it where it counts. Made the Kessel Run in less than 12 parsecs." "Fastest hunk of junk in the galaxy." Will follow...please advise on fit...want to attain one, but hesitant. Cheers, Dave Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 12, 2015 Share Posted November 12, 2015 NICE! Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted November 12, 2015 Share Posted November 12, 2015 1/144? I though the real one was about 18 inches long.... I'd say it's a bit overscale.. more like 1/2 scale.. Jus' sayin' Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 12, 2015 Author Share Posted November 12, 2015 WooHoo! "She may not look fast, but she's got it where it counts. Made the Kessel Run in less than 12 parsecs." "Fastest hunk of junk in the galaxy." Will follow...please advise on fit...want to attain one, but hesitant. Cheers, Dave The fit so far has been good. I haven't come across any issues yet, in fact most parts are almost a press fit. Carl Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 12, 2015 Author Share Posted November 12, 2015 1/144? I though the real one was about 18 inches long.... I'd say it's a bit overscale.. more like 1/2 scale.. Jus' sayin' Actually, the original Star Wars filming miniature was about 5' in size. They made a smaller one that's 32" in size for Empire. So I guess it depends on whether we go with "life size" or actual size for its scale. Or we could call it box scale since it fits in the box Carl Carl Link to comment Share on other sites More sharing options...
scvrobeson Posted November 12, 2015 Share Posted November 12, 2015 Awesome Carl! I'm glad that we're seeing so much excitement about Star Wars, makes me want to crack open my Bandai X-Wing. Still need to pick up a Y-Wing before they disappear completely. Matt BloorwestSiR and BiggTim 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 12, 2015 Author Share Posted November 12, 2015 Here are some of the inserts installed on the upper hull section. Seeing how tight things would get, I painted some sections prior to assembly. This included the inner sections of the jawbox. The outer walls are mostly separate parts which helps to keep the detail nice and sharp. It's fun picking out all the various model parts that were used for the details on the original. There's a bunch of tank parts and engine bits from Tamiya 1/12 car kits that I recognize. Uilleann, Girlscanplay2, jgrease and 4 others 7 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 12, 2015 Author Share Posted November 12, 2015 Awesome Carl! I'm glad that we're seeing so much excitement about Star Wars, makes me want to crack open my Bandai X-Wing. Still need to pick up a Y-Wing before they disappear completely. Matt Thanks Matt. I've got so many kits in the stash that I figured I might as well start on them. They're a great break from other more intensive projects on my workbench. Helps keep me motivated. If you can't find the Bandai Y-Wing, I'd be willing to sell you my Fine Molds one. They're pretty much equal in quality. Uncarina 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted November 12, 2015 Share Posted November 12, 2015 Quick question Carl. How much of those inserts are included in the kit, and how much are update/detail sets? You mentioned up top that there are update sets you're using with this Matt Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 12, 2015 Author Share Posted November 12, 2015 Ok, I've run into the first parts that need a bit of work to fit. As I mentioned, I'm building the Falcon in flight so I needed to install the gear bay doors. There are five of them in total. The forward three fit fine but the rear two needed a small bit of work to make them fit. I had to shave off the detail inside the bays to get them level. And a quick coat of Gundam white and here's where I am: The hull halves are just test fitted together and there doesn't seem to be any issues. mywifehatesmodels, Lars Befring, Uncarina and 4 others 7 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 12, 2015 Author Share Posted November 12, 2015 Quick question Carl. How much of those inserts are included in the kit, and how much are update/detail sets? You mentioned up top that there are update sets you're using with this Matt So far, everything but the six rear grill vents are kit parts. I have some parts from Shapeways coming. They are for the cockpit, turret windows, blasters and radar dish. I'm thinking of getting a clear acrylic stand for the model. I have the larger one (for the 1/72 kit) made by TS Designs and it's quite nice. Uilleann and scvrobeson 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 12, 2015 Share Posted November 12, 2015 Really cool project, Carl! And some very nice work, too. Kev Link to comment Share on other sites More sharing options...
mywifehatesmodels Posted November 12, 2015 Share Posted November 12, 2015 Great start! And I love the title of this thread, by the way! John Link to comment Share on other sites More sharing options...
