seiran01 Posted August 6, 2014 Share Posted August 6, 2014 I've started fidgeting around with my revell G10 Erla and the brand new Alley Cat 109H conversion (meant for the G6), The intent behind this build is to have some fun and possibly annoy the 109 purists at the same time. I need some inspiration to get stuck in to this build, even at this stage - Help me find a fun paint scheme for this bird, it does not need to be German or even historically accurate. Basically anything but hello kitty! Once I really get stuck into the build, I'll start a post on the In Progress board. In the meantime I wanted to share a pic of roughly how this will look now that I've dry-fit the main Alley Cat resin parts. Looks great and I have to commend Ali over at Alley Cat, as this may be the best of their conversions I've come across yet. Perfect fit and it's VERY easy to make the needed cuts. I eyeballed them without measuring and the resin fits like Revell molded the parts themselves. Bravo, Alley Cat! Uncarina, BGB, Rick K and 2 others 5 Link to comment Share on other sites More sharing options...
CATCplSlade Posted August 6, 2014 Share Posted August 6, 2014 Well, since Hello Kitty is off the table, perhaps My Little Pony? They're quite popular with the kids (and older men with issues). Sparzanza 1 Link to comment Share on other sites More sharing options...
Hardcore Posted August 6, 2014 Share Posted August 6, 2014 Overall RLM 76. With skull and bones markings... Wurzacher 1 Link to comment Share on other sites More sharing options...
BGB Posted August 6, 2014 Share Posted August 6, 2014 Hello, Will follow this !! Cheers Boris Link to comment Share on other sites More sharing options...
thierry laurent Posted August 6, 2014 Share Posted August 6, 2014 Why not a Afrika scheme with some green camo? Link to comment Share on other sites More sharing options...
Rick K Posted August 6, 2014 Share Posted August 6, 2014 NMF...break out the Alclad! Link to comment Share on other sites More sharing options...
ChrisK89 Posted August 6, 2014 Share Posted August 6, 2014 Paint it like a space shuttle, glossy white and matt black. Or orange like the american X-1? Cheers Chris Link to comment Share on other sites More sharing options...
Juggernut Posted August 6, 2014 Share Posted August 6, 2014 What happed to "I'm leaving the scale for everything except WWI cause I don't have the room"? Apparently not.... Link to comment Share on other sites More sharing options...
seiran01 Posted August 6, 2014 Author Share Posted August 6, 2014 I'm still leaving 32nd for the most part as I mentioned in the sale post I'm keeping my unbuill wingnut kits including the Gotha, but this conversion, 2 HK Meteors and a PCM Spit 14 (for a commission build) are the only non-Wingnut LSPs I'm holding on to after that. Rick - Alclad is your answer to everything lately, isn't it? No dice, buddy! Space shuttle scheme would be a different one! I'll keep that in mind Rick K 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted August 6, 2014 Share Posted August 6, 2014 Red Baron, with WWI style insignia, definitely. BGB 1 Link to comment Share on other sites More sharing options...
mattlow Posted August 6, 2014 Share Posted August 6, 2014 One off, post war Israeli aircraft converted to photo recon... Could do it in whatever that blue-ish colour some F-5 recon aircraft used (Haze camoflage).. Matt Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 6, 2014 Share Posted August 6, 2014 (edited) How bout a light pale blue underside....................with a gloss white upper side...................and a dark blue stripe down the side with gold pin-striping round the dark blue stripe.............and some N A S A decals on the rudder............... A captured 109 used by NASA in its infancy for high altitude research! THAT should send the nazi-counters into a frenzy. Edited August 6, 2014 by Out2gtcha Link to comment Share on other sites More sharing options...
Zero77 Posted September 17, 2014 Share Posted September 17, 2014 Nice ! I wanted to see what this conversion looks like. It seems to be nice. Would be good and uncommon addition in a 109 collection. But if you really want to annoy purist, you must have set this conversion on a fw190. Link to comment Share on other sites More sharing options...
dutik Posted September 17, 2014 Share Posted September 17, 2014 Its a late Messerschmitt, so why not add Spanish trim and markings - a la Buchon - or some Arab roundels ("Buchon export model")? If it has to be more fancy: Korea war markings. North or South - as you like it. Or French Indochine livery, with bomb racks... - dutik Link to comment Share on other sites More sharing options...
Mikester Posted September 17, 2014 Share Posted September 17, 2014 As a "109 purist" I'd say go ahead an paint it however you like because it's your model and however you do it, it won't offend me in the least. Although I strive to make my 109s (and other aircraft) as historically accurate as I can I would never presume to tell anyone else how they should finish their model or be the least bit perturbed by a fictional paint scheme. BGB, MikeC, Wurzacher and 1 other 4 Link to comment Share on other sites More sharing options...
