Zero77 Posted March 21, 2018 Share Posted March 21, 2018 tony , ever since 2014 , things have been rather more polarized up here alas! Sorry - we're way off topic here I'm up fr anything that enhances revell's rather flimsy Eurofighter model , I've built two of the things and they really need all the help they can get , definitely a a case of a kit being produced down to a price Seriously? I've heard only good comments about that kit (not the cas for the Trumpeter one). It's not so good? Daniel Leduc 1 Link to comment Share on other sites More sharing options...
Iain Posted March 21, 2018 Author Share Posted March 21, 2018 The shape is far better than the Trumpeter kits, but some of the details look like they've been scaled up from a 1:48th kit - and fit in some areas needs a little work. Intakes are probably the most needed area now IMHO... Iain Daniel Leduc and Zero77 2 Link to comment Share on other sites More sharing options...
Zero77 Posted March 21, 2018 Share Posted March 21, 2018 (edited) Thanks Iain. I have that kit (the single seater) with several resin sets from Aires, if i remember correctly i have the cockpit, the exhaust, maybe the wheel bays? And a very nice booklet with profiles and a sheet of decals. Mine will be italian with the cavalino on the tail. I hope i can solve those details issues. As long as the overall shape and dimensions are good, it's not that bad. And the kit is very cheap for such a big box. By the way, thank you for your review ! It seems that Olimp models bring some interesting sets, but the quality is not that good. That's the second time i hear that. And what a strange resin color ! As it's been said, some parts look strange as if they have been burnt (kind of black edges). Edited March 21, 2018 by Zero77 Link to comment Share on other sites More sharing options...
thierry laurent Posted March 22, 2018 Share Posted March 22, 2018 Quality is not bad but quality control is really not acceptable. A stupid example: some people got damaged decals because they were put against the resin casting blocks! This is plain stupid and does not ask for a tremendous effort to avoid such a problem. Ditto for the casting quality of some parts or even missing parts. I just have the Eurofighter set, not the Harrier one and my set does not have any of the mentioned problems. It had just one broken part and this is not uncommon; even in high-end resin sets. However, it looks I was simply lucky. Too bad as there is room for an aftermarket company focusing on British LSP postwar topics. Various good things have been released by Brit companies (Heritage, Relish, Paragon, Xtraparts, etc.) but the availability is always so-so. Link to comment Share on other sites More sharing options...
red Dog Posted March 22, 2018 Share Posted March 22, 2018 (edited) here is a comparison between trump and revell as i built both side by side. In the end i couldn't decide which won, they both have pro's and cons: https://reddogsmodels.wordpress.com/2012/06/18/132-ef-2000-revelltrumpeter-comparison-side-by-side-report/ at the end of the build, i couldn't make up my mind, so I made a spreadsheet assigning points for each aspects; look at the results: back then the olymp set wasn't Edited March 22, 2018 by red Dog Tony T, Daniel Leduc and wunwinglow 3 Link to comment Share on other sites More sharing options...
Tony T Posted March 22, 2018 Share Posted March 22, 2018 Interesting perspectives Red Dog. The twin seater release comes with bangy things to drop from the wings. Two Mikes inlet covers "solve" the dustbin-depth ducting, but it would still be nice to open it all up properly. When I build one using the kit parts, instead of something far preferable like G-factor bronze legs, I will probably stiffen the lower NLG plastic leg with layers of cyanoacrylate glue or epoxy glue or get a bespoke one made. Tony Link to comment Share on other sites More sharing options...
