DirkE Posted March 25, 2017 Author Share Posted March 25, 2017 Added those details... :-) Wurzacher, F`s are my favs and Shaka HI 3 Link to comment Share on other sites More sharing options...
Wurzacher Posted March 25, 2017 Share Posted March 25, 2017 Such a great build! Like it! I already saved some stuff as reference for my own kit when being build! DirkE 1 Link to comment Share on other sites More sharing options...
Marko Posted March 30, 2017 Share Posted March 30, 2017 Great reference build. May i ask how would you rate the kit in aspect of buildability (including issues and positives that it offers)? Im deciding what should i take (hasegawa/eduard-academy or ZM) considering that the ZM costs nearly double as either of both, is the question if it is worth? Does it assemble itself so much better? Im no external contour fanatic, so if it looks like a F-4J its pretty much close enough for me. I did not read carefully enough though, are the fit issues due to insufficient dry-fitting/or similar, or are a general design issue - i know that i should read it once more in detail prior posting, but somehow i dont get to it at this time due to work regards, Marko DirkE 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 30, 2017 Share Posted March 30, 2017 Super work on the details. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Joel_W Posted March 30, 2017 Share Posted March 30, 2017 Great reference build. May i ask how would you rate the kit in aspect of buildability (including issues and positives that it offers)? Im deciding what should i take (hasegawa/eduard-academy or ZM) considering that the ZM costs nearly double as either of both, is the question if it is worth? Does it assemble itself so much better? Im no external contour fanatic, so if it looks like a F-4J its pretty much close enough for me. I did not read carefully enough though, are the fit issues due to insufficient dry-fitting/or similar, or are a general design issue - i know that i should read it once more in detail prior posting, but somehow i dont get to it at this time due to work regards, Marko Marko, if price is a consideration, I'd opt for one of the Academy F4 kits. I built the B and it's more detailed and a better fitting kit then the old Hasegawa kit. Buy what AM parts you feel you want, not what Eduard decides to include in the kit. Like I posted, I'm getting a ZM J and the Academy C. Joel DirkE 1 Link to comment Share on other sites More sharing options...
DirkE Posted April 2, 2017 Author Share Posted April 2, 2017 Great reference build. May i ask how would you rate the kit in aspect of buildability (including issues and positives that it offers)? Im deciding what should i take (hasegawa/eduard-academy or ZM) considering that the ZM costs nearly double as either of both, is the question if it is worth? Does it assemble itself so much better? Im no external contour fanatic, so if it looks like a F-4J its pretty much close enough for me. I did not read carefully enough though, are the fit issues due to insufficient dry-fitting/or similar, or are a general design issue - i know that i should read it once more in detail prior posting, but somehow i dont get to it at this time due to work regards, Marko Marco, since I haven´t built the Academy kit I can´t tell you which one is better. I liked the Z-M kit, dispite those problems I had. Considering the price and what the aftermarket offers, I would go for the Academy kit. Otherwise I would wait what Z-M releases in the future and what they did to adress the issue with the outer wings. Dirk Marko, Joel_W and Wurzacher 3 Link to comment Share on other sites More sharing options...
Marko Posted April 3, 2017 Share Posted April 3, 2017 (edited) Hi Dirk, thanks for heads up. Well, i jumped too early and ordered two of the ZM kits...darn :/ (not yet paid,..but still) With a bit of blocksanding i figure the wing issue is easy solveable, is it? How about with the cockpit sides, can you give a good insight about that issue? regards, M Edited April 3, 2017 by Marko Link to comment Share on other sites More sharing options...
DirkE Posted April 3, 2017 Author Share Posted April 3, 2017 Hi Dirk, thanks for heads up. Well, i jumped too early and ordered two of the ZM kits...darn :/ (not yet paid,..but still) With a bit of blocksanding i figure the wing issue is easy solveable, is it? How about with the cockpit sides, can you give a good insight about that issue? regards, M Marco, the outer wing issue is solveable. Regarding the cockpit. Just make shure that the walls of the front wheel well ar fiting good together. And than add the cockpit on top of it. Just check if everything is there where it should belong. Then you won´t have any problems. I just didn´t pay enough attention, therefore my problems with the cockpit. Dirk Marko 1 Link to comment Share on other sites More sharing options...
Joel_W Posted April 3, 2017 Share Posted April 3, 2017 Dirk, At 1st I posted that the ZM kit seems to offer greater deal, and therefore I was going to buy the J from ZM rather then from Academy. Honestly, the wing tip issue has been nagging at me, as I didn't have any real dimensional issues with the Academy B, so I'm going to buy the Academy F4-C, & J. And then see if ZM address the wing tip issue with their S. Joel Link to comment Share on other sites More sharing options...
Marko Posted April 3, 2017 Share Posted April 3, 2017 Well, mine are paid now, so im all in. Dirk, thanks for the heads up, i will keep the tips in mind. I just hope that the boxes are not as exaggerated in size as the ones from Eduard DirkE 1 Link to comment Share on other sites More sharing options...
