SEA F-4C/D
  • Please log in to reply
112 replies to this topic
#91 Tony T
Tony T
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 4,736 posts
  • Gender:Male
Posted 14 August 2016 - 05:30 PM
Luca, I'm fairly certain I still have a set of CE GBU-10A/B Paveways as used in Vietnam.
Like the Israeli F-4 AAR probe and CE Israeli decals they are lurking in the attic. I will investigate all these after I get back from Cornwall if you still are interested.
Tony
  • Luca likes this
Finally spraying again
#92 Luca
Luca
    Senior Member
  • LSP_Members
  • 1,181 posts
  • Gender:Male
Posted 16 August 2016 - 03:04 PM
Tony
Hi Tony, yes I'm still interested (CE GBU-10A/B plus Israeli IFR probe). Many thanks!
cheers
#93 Luca
Luca
    Senior Member
  • LSP_Members
  • 1,181 posts
  • Gender:Male
Posted 19 August 2016 - 07:32 AM
4x AIM-9B + 6x Mk.118 bombs (3 each side on TERs) on Casper... reliable loadout?  :ph34r:
#94 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 5,762 posts
  • Gender:Male
Posted 19 August 2016 - 03:35 PM
I guess you mean Mk.117 as the 118 was far bigger!
For the warload, I would say not really even if this was not impossible. When AtoA missiles were carried with bombs, planes normally had Sparrows.
  • Luca likes this
#95 Luca
Luca
    Senior Member
  • LSP_Members
  • 1,181 posts
  • Gender:Male
Posted 19 August 2016 - 05:27 PM
yes I mean mk.118 (I didn't know they were so big)... which pylons were they usually carried up by F-4s?
#96 ziggyfoos
ziggyfoos
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 19 August 2016 - 05:45 PM
Probably know, M118 was 3000lb bomb while the M117 was "only" 750lb. No 118s on TERs. Where are you getting 118's in 1/32? I didn't think there were any. I know this F-105 scratchbuilt them:
http://www.largescal...cle.php?aid=190
  • Luca likes this
#97 Luca
Luca
    Senior Member
  • LSP_Members
  • 1,181 posts
  • Gender:Male
Posted 19 August 2016 - 06:49 PM
Fisher Model and Pattern makes them... they are HUGE:
http://fishermodels....105-and-f-4-132
#98 ziggyfoos
ziggyfoos
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 19 August 2016 - 07:24 PM
Thanks! I've ordered from Fisher many times but completely missed seeing those.
  • LSP_Typhoonattack likes this
#99 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 5,762 posts
  • Gender:Male
Posted 21 August 2016 - 07:51 AM
I do not remember immediately one picture of them under F-4 pylons even if I know they were used. So, such use was probably quite rare. The LGB version of the Mk. 118 was carried under the inner wing pylons, so I guess the plain 118 used the same one.
Thierry
  • Luca likes this
#100 Luca
Luca
    Senior Member
  • LSP_Members
  • 1,181 posts
  • Gender:Male
Posted 21 August 2016 - 02:03 PM
ok no more Mk.188 then... too big :)
how many Mk.83/84 bombs could be hanged up on each TER?
#101 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 5,762 posts
  • Gender:Male
Posted 21 August 2016 - 08:25 PM
TERs were rather used with Mk.81 or 82. Larger bombs were used individually.
  • Luca likes this
#102 Luca
Luca
    Senior Member
  • LSP_Members
  • 1,181 posts
  • Gender:Male
Posted 22 August 2016 - 10:59 AM
IIRC there is a b/w photo on the Squadron Signal in action book that shows a vietnam F-4D (or maybe an F-4E, now I do not remember) with 2 Mk.83 on the opposite sides of the same TER...
Edited by Luca, 22 August 2016 - 11:00 AM.
#103 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 5,762 posts
  • Gender:Male
Posted 22 August 2016 - 12:53 PM
Hi Luca,
I never wrote the 83 was never used on TERs but again, there is a difference between the theoretical load, the very occasional load and the common ones!
Have a look at the chart below: http://airwarvietnam.com/F4Chart2.jpg
It clearly shows TERs could be used to load larger and heavier stores per pair but this was not very common with bombs. Remember my similar comment about the Mk.118 use. The target locations, rules of engagement and mission profiles actually dictated the warload configuration. Add to this the fact that the fuel alone added 40% of weight to the plane without the warload and you will quickly realize that understanding this matter is far more complicated than what most modellers think. A warload to bomb the area close to Khe Sanh had nothing in common with the one to bomb the Doumer bridge or the Haiphong warehouses in spite of the fact we are considering short nose Phantoms in all cases...
Thierry
  • Luca likes this
#104 Luca
Luca
    Senior Member
  • LSP_Members
  • 1,181 posts
  • Gender:Male
Posted 22 August 2016 - 02:35 PM
wow great useful loadout chart Thierry... as always you rock  :bow:
found a pic on the squadron signal "in action"... but it's a recce bird  :doh:
Edited by Luca, 22 August 2016 - 02:56 PM.
#105 Darren Howie
Darren Howie
    Senior Member
  • LSP_Members
  • 1,300 posts
Posted 24 August 2016 - 12:28 AM
F-105's very frequently carried full racks of 83's.
Very rarely see F-4's with anything other than 82's or 81's.
On the centreline I'd be thinking ground clearance would immediately be an issue.
F-105 was quite a bit taller and even then the lower 750 barely cleared the ground.
