Bomber_County Posted February 19, 2017 Share Posted February 19, 2017 Perhaps someone can enlighten me on fixing resin, I use cyno both gap filling and thin but to no avail, driving me insane, not sure if adding to much, to little, is the bottle to old, is there contamination Its basically resin to anything else, Thanks BiggTim 1 Link to comment Share on other sites More sharing options...
Bill_S Posted February 19, 2017 Share Posted February 19, 2017 Have you washed the resin thoroughly? BiggTim 1 Link to comment Share on other sites More sharing options...
williamj Posted February 19, 2017 Share Posted February 19, 2017 Release agent is probably the culprit....Strong detergent is required to clean,don't scrub it,just soak it. swat I do anyway. BiggTim, MikeMaben and Jack 3 Link to comment Share on other sites More sharing options...
Bob MDC Posted February 20, 2017 Share Posted February 20, 2017 If the CA is old this is a common problem, looks ok sticks to flesh but totally useless as we use a fair quantity and being Scottish and only wanting to replace when we are totally out, I use one part with CA and the other sprayed with CA activator and that works for me. We use Hafix not cheap but the best I have found over the years and works with most 3D material we have used. http://www.hafixs.co.uk/products/profglue/index.html Bob williamj, BiggTim and etendard 3 Link to comment Share on other sites More sharing options...
Bomber_County Posted February 20, 2017 Author Share Posted February 20, 2017 Thanks guys, I do wash the resin but probably not enough and Bob you're right had the cyno to long, I'll try the hafix as suggested......... BiggTim 1 Link to comment Share on other sites More sharing options...
Bob MDC Posted February 21, 2017 Share Posted February 21, 2017 Just another thought if you store your CA in a cool place (we use our resin fridge) also if you are mating two surfaces together and you sand to clean the surfaces "don't" clean the sanding waste off the part it works like the powder activator and cheaper !! Bob BiggTim 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 21, 2017 Share Posted February 21, 2017 Phil I've broken, snapped and cracked more resin then I care to admit. The guys are correct in that all the mold release agent needs to be removed and it's the easiest before starting. Down the road a bit and when underway, if a part snaps, breaks or cracks, resin is easy to repair. Small cracks - clean the area and make sure the crack is wide enough to allow extra thin CCA to flow in. Breaks and snapped off parts - clean the area and if needed remove any old CCA with CCA debonder. I then follow up with a Q-tip and a bit of Mr Color Leveling Thinner to clean the matting surfaces. If the parts fit reasonably well, I use regular Loctite CCA, glue and then hold 'ape together If the break is really bad and the parts don't fit together well with a nice gap and I can't glue some sheet inside as a brace, then I'll go with slow setting CCA GEL in a few spots just to get the parts to hold together and give the GEL a shot of CCA Accelerator. . Once set, I'll start filling in the the gaps slowly first with more CCA GEL and Accelerator filing in the gap. Once the gap is filled in. I switch back to regular Loctite CCA and over fill the remain gaps. let dry over night and then it's sanding and scribing. Peter Link to comment Share on other sites More sharing options...
Bomber_County Posted March 4, 2017 Author Share Posted March 4, 2017 Thanks guys, I have always have left the CA in the fridge until about a year ago, that may be the answer..... I need some more kicker as well, I have used CA with micro balloons successfully..... Link to comment Share on other sites More sharing options...
