Loic Posted March 12, 2015 Author Share Posted March 12, 2015 Jack, I thought about it (especially for the air intake) but I do not have the Mirage III kit so ... But, I have 1 hasegawa startfighter that may be of help Link to comment Share on other sites More sharing options...
Loic Posted March 12, 2015 Author Share Posted March 12, 2015 (edited) Filippo, Lee, Kevin, thanks for the kind words guys Edited March 12, 2015 by Loic Link to comment Share on other sites More sharing options...
wunwinglow Posted March 14, 2015 Share Posted March 14, 2015 Excellent choice of subject. Another beautiful French aircraft. it really should be available as a kit! Best of luck with the project, Tim Link to comment Share on other sites More sharing options...
Youngtiger1 Posted March 14, 2015 Share Posted March 14, 2015 Can't wait to follow Link to comment Share on other sites More sharing options...
Loic Posted March 14, 2015 Author Share Posted March 14, 2015 Thanks guys, I started to cut styren to run some trial on my lamination technique for the nose end... I will post an update when I have something worthy Link to comment Share on other sites More sharing options...
Loic Posted March 16, 2015 Author Share Posted March 16, 2015 (edited) Hi ! well, it's been a raining most of the weekend so that was the perfect opportunity to make some progress on the Mirage project I decided to start with the nose / pit area because the shapes are rather complicated so I thought it would be a good test for what's ahead... I started from a styren skeleton : Then, a first layer of styren is applied. It is imprtant that is in one signle piece (or as low as possible number) and it has to be very well positionned (if not perfect) as this will reduce the amount of work needed in the next steps: Then, I used small stripes of styren to apply the secon layer. It is important that the stripes' alignment matches the shape to get both curves and strengh. The horizontal stripes match the canopy line. continue untill it's all covered It is a bit "dirty" so far and all joints are filled with CA glue. Once dry: sanding action ! (the better the first and second layers, the less sanding...) You may see that the section goes from round to square (with rounded corners), it also varies in width ... and the alignment is done from the bottom edge, not centre of section... the most complicated job is to make the skeleton "good" in fact. Getting ready for third layer now... this will be the finishing layer onto which the scribbing will apply. Last but not least, during all the process, the nose part has about 1 extra cm on each side (top, front and rear) that will need to be trimed at the end: it is important to get smooth joint when I will mate the rear end o the AC, canopy or the nose cone. Thanks for following !! Edited March 16, 2015 by Loic Anthony in NZ, geedubelyer, Harold and 5 others 8 Link to comment Share on other sites More sharing options...
alain11 Posted March 16, 2015 Share Posted March 16, 2015 (edited) HiWow!!!!! this is an ambitious project !!!! this is with this kind of built , that we can make the difference between a .. modeler ( in the strict terms), and the rest of " world" .... this one ( built) reminds me of this 1/32 Mirage 4000 built a few time ago by Emmanuel Gato .....can I wish you a good luck,Alainhttp://www.master194.com/forum/viewtopic.php?f=4&t=71088 Edited March 16, 2015 by alain11 Link to comment Share on other sites More sharing options...
Loic Posted March 16, 2015 Author Share Posted March 16, 2015 Thanks for the kind words Alain I had never seen this M4000 build before and all I can say is WOW, incredible !! I recon the build process share the same spirit, I only hope I can end up with something half this good has this would already be quite an achivement ! Harold 1 Link to comment Share on other sites More sharing options...
Lee White Posted March 16, 2015 Share Posted March 16, 2015 (edited) Hey Loic! I don't know if it would help, but this fellow is working on one too- http://maquettes-aviations.forumsactifs.com/t532-mirage-f1-1-32 http://fighters.forumactif.com/t51027p45-mirage-f1-au-1-32 Edited March 16, 2015 by Lee White Link to comment Share on other sites More sharing options...
brahman104 Posted March 16, 2015 Share Posted March 16, 2015 Ooh I am looking forward to this! I love the F1.... about time someone made one and I couldn't think of a better person to do it Craig Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 16, 2015 Share Posted March 16, 2015 Another fantastically inspirational project from the master. One to follow for sure. Kev Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 16, 2015 Share Posted March 16, 2015 Loic What a scratch build ... going to be a fantastic project and you're off to a great strat Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Loic Posted March 16, 2015 Author Share Posted March 16, 2015 Many thanks for the kind words and for the vote of confidence guys, much appreciated @Lee: I know this build but it seams to be at idle since a couple of years or so now... Lee White 1 Link to comment Share on other sites More sharing options...
Mal_Belford Posted March 16, 2015 Share Posted March 16, 2015 Geez......what a project...im looking forward to see more.... /Mal Link to comment Share on other sites More sharing options...
Loic Posted March 17, 2015 Author Share Posted March 17, 2015 Thanks Mal Link to comment Share on other sites More sharing options...
