It ain't the airbrush. It's the paint.
airbrush acrylic paint
  • Please log in to reply
38 replies to this topic
#31 tucohoward
tucohoward
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 750 posts
  • Gender:Male
Posted 14 December 2017 - 07:59 PM
MRP is easiest paint to spray ever. As much as I love Mr. Color, I can get the same results with MRP without any of the thinning to get the right mix. Shake it up and spray. Pressure doesn't even matter. From less than 5 psi on up to whatever you want. Will still use Mr. Color since I have a ton of it but will replace it with MRP as it is used up. It will spoil you.
Jay
  • Out2gtcha and Peterpools like this
#32 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,212 posts
  • Gender:Male
Posted 15 December 2017 - 12:55 AM
Jay
I'm pretty well hooked on both MRP and Mr Color and use them interchangeably. I thin Mr Color out 3:1 with their thinner and MR - no thinning required. Of course, this is all your fault as you got me hooked on Mr Color!
Peter
  • Out2gtcha and tucohoward like this
Trumpeter SBD-1
#33 Gewehr 43
Gewehr 43
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 118 posts
Posted 15 December 2017 - 05:14 PM
In spraying a test aircraft last week, I found that Mr Color tended to splatter more than MRP.  The Mr. Color was thinned 2:1 and later 3:1 with Mr Leveling Thinner, and shot with an HP-CS with a .3mm nozzle at ~12psi.  I could lay down the MRP paint with ease and the pattern was nice & tight.  The Mr Color splattered and while the center of the spray cone was smooth, the fringes of the cone were much less consistent.
In short, I too, am an MRP convert.  I'll still spray some Tamiyas and the occasional Vallejo product, but they will never behave like the MRP stuff.
  • tucohoward likes this
#34 davral64
davral64
    Member
  • LSP_Members
  • PipPip
  • 14 posts
Posted 19 December 2017 - 01:27 AM
Thanks all for the advice.
I ordered mission model paints from hobby easy out of HK. (I'm in Australia and there isn't much in the way of modelling stuff here compared to back home.)
By the way, a shout out is in order for hobby easy... Their prices are 1/3 the price of everything available in Australia and their selection is really good. Their sites a little hard to search being the only drawback.
Anyhow, next time I spray I'll bump pressures to 10 and see how I go.
Again thanks for the advice.
#35 rafju
rafju
    Senior Member
  • LSP_Members
  • 967 posts
  • Gender:Male
Posted 19 December 2017 - 09:20 AM
My spraying way to get rid of closing airbrush nozzle:
Tamiya / Gunze acrylics / Humbrol enamel...
Evolution H&S, usually work with 0.3mm and at 10-12psi max.
start with 2-3 drops of thinner in the airbrush
- spray out of the parts
add max 5-10 drops of  pre-thinned paint
- spray to the parts
before end of the paint, re-load with 2-3 drops of thinner, not necessary to mix
- continue to spray to the parts
if necessary, re-load with thinned paint (some drops)
and so on...
"My" rules are to work with small paint qty in the cup and to add thinner at regular time.
#36 davral64
davral64
    Member
  • LSP_Members
  • PipPip
  • 14 posts
Posted 20 December 2017 - 06:24 AM
Okay okay already, I've moved the pressure up to 10psi (spraying pressure) and I've had much better results, so good call and thanks.
Still shooting Vallejo Air but I'm thinning just a few molecules more and the results are better.
Super pumped for the Mission Model Paint to arrive to see if it'll make me a convert. Hobby easy sent me an email saying they're out of the poly additive. I ended up ordering the poly and a couple of other colours from Airbrush Megastore here in Australia. Their prices were only a little higher than Hong Kong. Now I've got a backup source for MMP.
  • LSP_Kevin and JMason5067 like this
#37 G-Man
G-Man
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 88 posts
  • Gender:Male
Posted 20 December 2017 - 12:37 PM
I use only Mr. Color paints. Colors get mixed at a 1:1 ratio with Mr. Leveling Thinner, clears are 2:1 (2 parts thinner). I spray them around 12-15 psi through an Iwata Neo TRN. Everything sprays beautifully.
ON THE BENCH: Trumpeter 1/32 Ju 87B-2
ON DECK: Hasegawa 1/32 Fw 190D-9
#38 Bstarr3
Bstarr3
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 133 posts
  • Gender:Male
Posted 22 December 2017 - 06:20 AM
Davral, I too have had frustrating experiences with Vallejo model air. every color seems to be thinned to a different level - some need additional thinner, some don't. I've played with different levels of thinking and different pressures, and I rarely get really good results.
I have quite a few colors of Mission Models and really like their stuff. It sprays very well and they publish a consistent recommended thinking ratio using their thinner and poly additive. I recommend their product heartily, and think you'll be happy with them.
That said, I've heard so many great things about MRP that I ordered a few bottles of it for my next project, Tamiya Mossie. I look forward to trying it out based on the glowing reviews in this thread and elsewhere.
Also, I should note that I've had very good results with Model Masters Acryl, whether sprayed or brushed on, despite a somewhat negative reputation that it seems to carry on many message boards.
Current project: Tamiya 1/32 Mosquito FB VI
#39 davral64
davral64
    Member
  • LSP_Members
  • PipPip
  • 14 posts
Posted 23 December 2017 - 01:32 AM
Back in the good old days of the early '80s there was Testors and Tamiya and that was it. Back then Tamiya was formulated differently than it is now. It brushed perfectly and airbrushed through one of those siphon feed airbrushes beautifully. Of course back then I was painting aircraft like houses are painted today. But, like I said Tamiya was great.
Now there are something like 10 mainstream paint manufacturers each with its own advantages. Choice is a good thing. Spending a couple of hundred dollars on paint isnt. Well, I think it is but my wife doesn't which ultimately means I don't either. So like everyone else I'm in search of the holy grail.
Everything I've seen about Mr. Paint MRP leads me to believe that it may be THE one but I like the water based stuff as I paint in the house without a fan or respirator (I'm a total barbarian I know!).
Anyhow stay tuned for me painting my fingers with Mission Models Paint and we'll see how it goes!
Also tagged with one or more of these keywords: airbrush, acrylic paint
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
