Dave Williams Posted March 1, 2018 Author Share Posted March 1, 2018 I've tried the Olfa Circle cutter and didn't care for it. One the one I used, you grabbed the center knob and spun it, with the blade at the end of the arm doing the cutting. But there was no way to put pressure above the blade. Many times I would twirl it, and find that it wouldn't cut all the way through all the way around, partially because I would tend to tilt the tool while spinning it. With the shadow cutter, the blade is spring loaded, so it puts constant positive pressure on the blade so it always cuts. Also, because of the design, you can't tilt it, and it's relativey heavy so it doesn't slide around. I just get a constant clean cut with one or two spins. Link to comment Share on other sites More sharing options...
Thud_Ally Posted March 2, 2018 Share Posted March 2, 2018 OK got me sold, next time I've got some hobby monies available I'll snag one. Cheers all for the helpful comments & great advice. Link to comment Share on other sites More sharing options...
