Joel_W Posted June 18, 2017 Share Posted June 18, 2017 Gotta say that the fuel tanks do have that rubbery look to them. If you do revisit them, what will you do to make them even more like rubber? Joel KiwiZac 1 Link to comment Share on other sites More sharing options...
Jking207 Posted June 18, 2017 Author Share Posted June 18, 2017 (edited) Hi Joel, I am probabably not going to do anything after looking at them. As my Grandpa used to say: "good enough for government work." He grew up during in the Great Depression and am guessing a reference to FDR's WPA program. Should have asked. I test fitted the outer lattice and it looks to line up with everything. Wing is finally close to completion. Edited July 2, 2017 by Jking207 Alburymodeler, Joel_W, KiwiZac and 2 others 5 Link to comment Share on other sites More sharing options...
Joel_W Posted June 18, 2017 Share Posted June 18, 2017 Those tanks look even more convincing inside the wing frame work. Joel Link to comment Share on other sites More sharing options...
Jking207 Posted June 23, 2017 Author Share Posted June 23, 2017 (edited) The wings are joined by two pieces each with 4 tabs that connect the wings. I had glued them in enough so they wouldn't pop out, but there was a lot of play in the wings. I wanted to test fit the outer skin before I made the final bound and set the dihedral. There is also a lot of weight with the fuel tanks then there will be rest of the kit on top of that. Crappy picture, but removed the fuel tanks and put JB Weld (metal epoxy) on both spars, between the center formers, pretty much what everywhere that couldn't be seen. This shows along the back spar and at center rear on the connection piece tabs. The front spar was done in a similar fashion. Edited July 2, 2017 by Jking207 Link to comment Share on other sites More sharing options...
Jking207 Posted June 24, 2017 Author Share Posted June 24, 2017 (edited) Outer skin glued down. Might do a wash and some detailing later, but want to move on to the engine or the fuselage. Fit was generally good, a little effort is needed for it to lay down on all the formers. Edited July 2, 2017 by Jking207 CANicoll, Bil and John F Smith 3 Link to comment Share on other sites More sharing options...
Joel_W Posted June 24, 2017 Share Posted June 24, 2017 It's really taking shape now. Just an amazing build to follow. Joel Link to comment Share on other sites More sharing options...
Jking207 Posted July 3, 2017 Author Share Posted July 3, 2017 (edited) Beginning the fuselage with the first bulkhead filled with the fuel tank, radio, and battery. Got Eduard Tamiya Interior set and the 12 piece battery parts fit fine. Also, from the Eduard kit the cap for the fuel neck and dial face for the fuel level (?). Still need to do some painting, wiring, and clean up, but built up without any issues. Starting to covert the page away from Photobucket. Edited July 3, 2017 by Jking207 CANicoll 1 Link to comment Share on other sites More sharing options...
Jking207 Posted July 19, 2017 Author Share Posted July 19, 2017 Floor build out with the formers. I am finding the fuselage is more challenging than wing to build. Plus dropping it on the floor and loosing the antenna outside during a quick spray of primer has hindered some progress. The two frame sides fitted to the floor. Tricky to assemble at first, but once fitted and a few points glued it was easier to manage. Fooesboy, KiwiZac, Gazzas and 1 other 4 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 19, 2017 Share Posted July 19, 2017 That looks wonderful so far. Could go batty doing this for too long! Joel_W 1 Link to comment Share on other sites More sharing options...
Joel_W Posted July 19, 2017 Share Posted July 19, 2017 The start of the fuselage really looks exceptional. I'll be the 1st one to join both Brian & Ernie that even attempting this kit would surely drive me to bang my head against the closet wall. Joel Link to comment Share on other sites More sharing options...
Jking207 Posted July 24, 2017 Author Share Posted July 24, 2017 (edited) Thanks guys, most of my pain has been self inflicted. This is the back 40 of the fuselage. I know the bottom tanks are oxygen, but I don't know what the larger tanks are for. Has some white metal pieces with an aluminum rod on the back bulkhead. Dropped a wire from the antenna to what I assume is an amp or radio gear. Edited July 24, 2017 by Jking207 KiwiZac, Fooesboy, Gazzas and 2 others 5 Link to comment Share on other sites More sharing options...
Fooesboy Posted July 24, 2017 Share Posted July 24, 2017 Great progress, the rest of the fuse is pretty straight forward from here. I've gotten as far as the engine bearers and have really struggled with a couple of points, your build makes me want to pick it up again! Looking forward to your next update. Joel_W 1 Link to comment Share on other sites More sharing options...
Fooesboy Posted August 22, 2017 Share Posted August 22, 2017 Just wanted to drop by and see how you are going. I have picked up my IMCTH kit again, thanks, in no small part to watching your progress! One step to be careful with is the engine mounts, I have spent an excessive amount of time on them! What I have found is that CA is not a good choice of glue, the PE plates that are glued to the sides of the white metal parts have kept breaking off. The CA is just too brittle, in the end I have used 30 minute epoxy and fitted them to the firewall / rest of the fuselage. This step is proving to be the most difficult one by far for me. I will post an update to my thread once the engine mounts have been painted and the engine installed, I hope ot have this done by the end of the weekend. Link to comment Share on other sites More sharing options...
Jking207 Posted September 16, 2017 Author Share Posted September 16, 2017 Hi Chris, I took a little bit of a break, but thanks for the heads up on the engine mount. it wouldn't have been on my radar as a problem area. On vacation this week and hope to get back on track. Small update: Working on the cockpit sides. Still need some more painting, maybe on decals and wires. KiwiZac 1 Link to comment Share on other sites More sharing options...
John F Smith Posted September 17, 2017 Share Posted September 17, 2017 Really beautiful work! I've been away for a bit, so I'm just now catching up with your build. Your work looks pretty flawless to me and I'm definitely going to be following your build closely. It's so great to see another modeler giving these IMCTH kits a try; they are well worth the effort in that they look so impressive when they are done. Best of luck as you proceed. If you have any questions, I will be happy to field them. Chris's build log is another great resource to use. On the other hand, you look like you are doing a great job all by yourself. Looking forward to more! John Link to comment Share on other sites More sharing options...
