BloorwestSiR Posted July 1, 2015 Author Share Posted July 1, 2015 All in all, those tires look like an excellent bit of engineering. K2, I finished the second one and the fit was much better after I gave the nubs a quick shave as I previously mentioned. I think with a coat of paint the small gaps will be hard to see. Since I'm not really building in order (as long as it all fits together in the end ), I started on the engines. The main block and cylinder heads are from the Spitfire kit but there are changes throughout so I had to make sure I was using the right part. The original engine sprue: One change is the inclusion of magnets into the cylinder head covers. These look like they're used to hold the exhaust covers in place. Not a great pic, but the part in the upper left corner P1 is from the new sprue and you can see the slight differences in it compared to the original Spitfire one. Here's the engine block, cylinder heads and supercharger assembled (x2) and ready for a coat of paint. The two bits in the upper right are a pair of jigs for attaching the cylinder heads at the right angle. This is something new that wasn't in any of the Spitfire kits or the Mustangs. The jigs just slide onto either end of the block... ...then you attach the cylinder heads and they're at the correct angle. I've left the left cylinder bank off to make it easier for painting. Once I have paint on, I'll re-use the jig and attach them. Carl Mal_Belford, Anthony in NZ, Uncarina and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_Ron Posted July 1, 2015 Share Posted July 1, 2015 I just assumed there was only one engine, nice to see there are two! Out2gtcha 1 Link to comment Share on other sites More sharing options...
Ryan Posted July 1, 2015 Share Posted July 1, 2015 You either have really small thumbs or those tires are huge! Looks good. Ryan BloorwestSiR 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 1, 2015 Share Posted July 1, 2015 Carl Awesome start and the Mossie and the up close and personal photos are perfect. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 2, 2015 Author Share Posted July 2, 2015 You either have really small thumbs or those tires are huge! Looks good. Ryan LOL, my thumbs aren't that small. Here's a size comparo next to a Tamiya Spitfire tire: Carl Awesome start and the Mossie and the up close and personal photos are perfect. Keep 'em coming Peter Thanks Peter. Your F-16 looks great as well. I have a couple in the stash that I'll get to one day. Carl Uncarina, Out2gtcha and Ripaman 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 2, 2015 Share Posted July 2, 2015 I do remember being quite astounded at the size ofthe Paragon Mossie wheels when I pulled them out of the packaging. That size comparison is indeed an eye opener! Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 2, 2015 Author Share Posted July 2, 2015 Happy belated Canada Day! We had family over and it was the first time we had all the grandchildren from both sides of my family in one place so that made it extra special. The hot dogs and ice cream everywhere after, not so much. Thankfully my dog made a valiant effort to help clean up. Back to the build, I added the PE bits to the centre section (not sure what it is but think it has something to do with the fuel system). I then attached all the engine parts to paint clips and sprayed them X-18 semi-gloss black. Since I had more paint left in the airbrush, I painted some other bits still on their sprues. Chris Wimmer, Uncarina, Whitey and 1 other 4 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 2, 2015 Author Share Posted July 2, 2015 I do remember being quite astounded at the size ofthe Paragon Mossie wheels when I pulled them out of the packaging. That size comparison is indeed an eye opener! It really is. I hadn't thought much of it until I put them side by side. It'll be interesting to see the same thing when the Lancaster comes out. Out2gtcha 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 2, 2015 Author Share Posted July 2, 2015 Here are the jigs in place on the engine: They certainly work well enough but I think thy're redundant with the way the cylinder heads are moulded and then attached to the block. The completed supercharger assemblies: And with the main components assembled: geedubelyer, Ripaman, Out2gtcha and 1 other 4 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 2, 2015 Author Share Posted July 2, 2015 While the paint was drying, I put the tail planes and elevators together. Although they're not the one piece set up that HK does, they go together very well once you trim the tree stubs off. Carl tomv87, geedubelyer, John F Smith and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 2, 2015 Share Posted July 2, 2015 Looks great Link to comment Share on other sites More sharing options...
Ryan Posted July 2, 2015 Share Posted July 2, 2015 (edited) With those balloon tires, I bet that was quite a bouncy landing. Ryan Edited July 2, 2015 by Ryan Link to comment Share on other sites More sharing options...
geedubelyer Posted July 2, 2015 Share Posted July 2, 2015 Hi Carl, I've just found this thread and like what you've accomplished so far. Good stuff. I shall try to follow this as often as possible to see how this uber kit builds up. So far, things are extremely encouraging. Cheers. Link to comment Share on other sites More sharing options...
S.Pelletier Posted July 2, 2015 Share Posted July 2, 2015 (edited) Hi Carl, Good build thread I am following your thread for sure. The Tamiya Mossie is probably my next purchase Stephane Edited July 2, 2015 by S.Pelletier Link to comment Share on other sites More sharing options...
Ripaman Posted July 3, 2015 Share Posted July 3, 2015 Hi Carl, Wow what a start, mine arrived this week so I will be watching your build closely. Regards Richard Link to comment Share on other sites More sharing options...
