Iain Posted April 24, 2017 Author Share Posted April 24, 2017 And a close-up of some of the detail on #13: I *think* that about covers it for the Pontos set... Iain 109, Hubert Boillot, Jeff and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted April 24, 2017 Share Posted April 24, 2017 Thanks for the tour Iain !........Harv Link to comment Share on other sites More sharing options...
Bomber_County Posted April 24, 2017 Share Posted April 24, 2017 I am totally exhausted just looking at the amount of "stuff" and that's not Including the kit items..........best part of 1000 odd parts? Iain you are a very brave man........i think I'll wait till I am retired to start one of these.......Bismark would be my choice...... Jeff 1 Link to comment Share on other sites More sharing options...
Bomber_County Posted April 24, 2017 Share Posted April 24, 2017 Ready to show at Telford ,,,,,,,,!,,,,,,,,,: Jeff 1 Link to comment Share on other sites More sharing options...
Iain Posted April 24, 2017 Author Share Posted April 24, 2017 Very much doubt it this year Phil - maybe next... Iain Link to comment Share on other sites More sharing options...
Fooesboy Posted April 24, 2017 Share Posted April 24, 2017 And a set of 4 propellers - 2 l/h and 2 r/h rotation. I'll probably end up painting these as they're a bit shiny, as well as having some areas I want to smooth off. Iain Hi Ian, From what I've read, the propellers are brass plated. I ordered a second sheet #5 direct from Pontos, not sure if I will use it or just go with the smaller funnel as kitted by Trumpeter. Everywhere I have looked I cannot find an extra funnel sprue and I'm not too keen on splashing out another $100.00 USD for a shapeways one. Guess I'll make that decision once I get to that step in the build. Link to comment Share on other sites More sharing options...
Iain Posted April 24, 2017 Author Share Posted April 24, 2017 Hi Chris, I was going to just make a mould and cast a copy of the parts for the front one in resin - until someone pointed out that spares were available from Trumpeter. You never know - they may become available again at some point, the next time Trumpeter run off another batch of kits? Probably reasonably easy to just cut the rear funnel parts in two vertically and add plastic sheet inserts to make up to correct size - most of the body is skinned anyway. Iain Link to comment Share on other sites More sharing options...
Fooesboy Posted April 24, 2017 Share Posted April 24, 2017 Looking at the hull plating on my kit, I'm not so sure that Trumpeter have over done it "that" much. Take a look at the 5th and 6th photo on this website http://www.navy.gov.au/history/feature-histories/yachtsman-and-mighty-hood I as going to just post the photo but photo bucket doesn't work for me today I am thinking about using a hi-build automotive spray filler / primer and sanding back to the high points.... does that make sense??? Completely filling and then using primer might not give enough relief. Link to comment Share on other sites More sharing options...
Iain Posted April 24, 2017 Author Share Posted April 24, 2017 They are pronounced - but not nearly as much as the kit IMHO - especially at the bow... I definitely want to reduce the prominence and current plan is use the high-build filler primer after I've got it filled and masked for the plates. I did think of using from the off - but using body filler first and get smooth first will be easiest I recon. I can get quite an edge/raise with filler primer and masking. But still pondering... From the Hood Association site: And a general view further back - taken on the Empire Cruise (I love this image): Night folks!I Iain Fooesboy and Jeff 2 Link to comment Share on other sites More sharing options...
Iain Posted April 24, 2017 Author Share Posted April 24, 2017 The photos that Chris mentioned (Royal Australian Navy images) Just found another two (albeit small) more from National Archives of Scotland, via Hood Association which might be useful: Will do some more head-scratching before I wade in... Iain Rick Griewski, Fooesboy and Jeff 3 Link to comment Share on other sites More sharing options...
JRutman Posted April 25, 2017 Share Posted April 25, 2017 Would be nice to see a forced perspective dio with this steaming along and the Connie flying overhead. Finish it by next week ? J Shawn M 1 Link to comment Share on other sites More sharing options...
Jeff Posted April 25, 2017 Share Posted April 25, 2017 Iain................... wow, this is incredible, and my hat is off to you for even attempting this, seems very daunting, BUT I know you will do the kit justice, and what a fine tribute to the Crew of the Mighty Hood this will be..... when complete , it should be in a museum for all to see and reflect..... I will be watching this with extreme interest...... how long is this kit, ( in feet and inches, I don't do mm's very well.................... 'M&M's yes............. just not mm's) ) Link to comment Share on other sites More sharing options...
TimW Posted April 25, 2017 Share Posted April 25, 2017 I feel bad I still haven't finished the Missouri... I need that Hood Pontos set for my Hood! Which I may build after the Nelson. Or not. Looking great! Tim W. Link to comment Share on other sites More sharing options...
LSP_K2 Posted April 25, 2017 Share Posted April 25, 2017 I can't even begin to imagine adding all of that P.E. CANicoll 1 Link to comment Share on other sites More sharing options...
ClumsyDude Posted April 25, 2017 Share Posted April 25, 2017 All that PE is so intimidating ... there has to be over a pound of it! Can't wait to see you put this together Iain (not that you have permission to go slow on your Connie). Jim LSP_K2 1 Link to comment Share on other sites More sharing options...
