Chris Hannover - Germany Posted January 12, 2005 Author Share Posted January 12, 2005 Chris, first i brushed the bird with a silver coat, then preshadeing, after that the camo colors. Next step is apply the decals directly on the color. Then i used a lead pencil for the panellines. When all is ok and clean i brush overall with a 70/30 mixture (flat/gloss) the clearcoat. (pic) I only have to give the bird a "used-look" now. Then Landing gear, antennas and some small parts. Finish. Hope that helps and ou all like it. Cheers Chris Hannover Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 12, 2005 Author Share Posted January 12, 2005 ... Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 12, 2005 Author Share Posted January 12, 2005 last one. Link to comment Share on other sites More sharing options...
ChrisS Posted January 12, 2005 Share Posted January 12, 2005 So tell me when you need me to give you my address so you can send it to me It's really a stunning bird now...looking forward to seeing it finished. Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 12, 2005 Author Share Posted January 12, 2005 I think i have still much to learn. But it´s getting better and better since i´m on this site Link to comment Share on other sites More sharing options...
Rob Colvin Posted January 12, 2005 Share Posted January 12, 2005 Very nice. O' my k is not nearly as nice looking as your's. S! Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 12, 2005 Author Share Posted January 12, 2005 Oh, i don´t think so. Yours looks fantastic! I like your weathering very much. I´m far away from that... And yours is already on her own feet. I just painted the gear legs. Chris Hannover Link to comment Share on other sites More sharing options...
Chris/Germany Posted January 12, 2005 Share Posted January 12, 2005 Simply-----WOW! great Job! the ripper Link to comment Share on other sites More sharing options...
Dave Pratt Posted January 13, 2005 Share Posted January 13, 2005 Chris,thanks so much for picking out my next project!So much for building what I was originaly going to build.I blame this all on your great build.Oh well,I'll get around to the Typhoon in the near future...cheers Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 13, 2005 Author Share Posted January 13, 2005 Hi all, i have made a mistake when painting the MG smoke. It´s a bit to much at the wrong area :angry: Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 13, 2005 Author Share Posted January 13, 2005 But the exhaust smoke looks very good to me this time Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 13, 2005 Author Share Posted January 13, 2005 . Link to comment Share on other sites More sharing options...
Chris Hannover - Germany Posted January 13, 2005 Author Share Posted January 13, 2005 The question is now, how can i remove the gun smoke, without the camo and decal to destroy?! It´s a clearcoat over camo and decal. Can i use a 1000 sandpaper to remove? Or what do the pro´s say? Thanks Chris Hannover Link to comment Share on other sites More sharing options...
ChrisS Posted January 13, 2005 Share Posted January 13, 2005 Chris, Yes this is the best exhaust staining you've done yet! I must take this opportunity to again state how flexible the pastel method is. You will never make that MG staining mistake using pastels, where as a solution using paint is far more hazardous unless you have a barrier of clear coat between the camo and weathering that uses a different tolerance (like Future) from the acrylic camo. That way you can use more agressive cleaning methods. Pastels wash off completely with water. You can try the technique over and over and over again on your most precious model with no fear at all, and the results are easily as impressive as an airbrushed technique. Actually I believe that pastel staining is far more realistic myself, but now I'm getting too high on the soap box Now to actually help you if I can.... I would use a q-tip with distilled water first (these are acryics right?) and work slowly and carefully. There may indeed be some repair to do with paint. Sanding should be done with fine grit, but be careful here as the "high" points get sanded more than the flat areas, and again some paint repair seems like it might need to happen. Looks great Chris. Hope that MG stain comes out ok! Link to comment Share on other sites More sharing options...
Dave Pratt Posted January 14, 2005 Share Posted January 14, 2005 Chris in Hannover-those exhaust stains look really nicebut like the other Chris mentioned you'll have to go pretty slow at fixing the gun trough but I'm sure you will do o.k. The K-4 does look very good...cheers Link to comment Share on other sites More sharing options...
