Miloslav1956 Posted November 9, 2017 Share Posted November 9, 2017 Tamiya model All colors MRP/Mr.Paint HGW wet transfres & seat belts All mask homemade Eduard wheels Loach Driver, MikeMaben, Bill Cross and 11 others 14 Link to comment Share on other sites More sharing options...
LSP_Paul Posted November 9, 2017 Share Posted November 9, 2017 Beautiful Work on the Corsair! . Excellent construction and painting, very realistic color tones and weathering! Paul Miloslav1956 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 9, 2017 Share Posted November 9, 2017 Beautiful work as always, Miloslav! I don't believe Corsairs ever had the main wheels bays finished in exposed primer, however. As far as I'm aware, the primer was covered with the underside colour. Kev Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 9, 2017 Share Posted November 9, 2017 Fantastic! Link to comment Share on other sites More sharing options...
Jan_G Posted November 9, 2017 Share Posted November 9, 2017 Outstanding weathering Miloslav! jan Link to comment Share on other sites More sharing options...
Gazzas Posted November 9, 2017 Share Posted November 9, 2017 Miloslav, Fantastic! Paint and weathering and detailing all work together for a great finish! Gaz Link to comment Share on other sites More sharing options...
Miloslav1956 Posted November 9, 2017 Author Share Posted November 9, 2017 (edited) Beautiful work as always, Miloslav! I don't believe Corsairs ever had the main wheels bays finished in exposed primer, however. As far as I'm aware, the primer was covered with the underside colour. Kev I must paint according the references: F4U-1 BuAer 02449 Paint Standard 2 tone paint scheme used in early 1943. Top non-specular Blue-Grey(no ANA ever assigned). Bottom Non-specular Light Gray ANA602 Center section wing fold area Light Gray. Inside oil cooler area Light Gray Fuselage Side number and number on front of gear door. Not sure yet. Will be either 49 or 449 Firewall and all items firewall forward -Salmon Prop blades Non-Specular black. Prop dome Semi-polished. Cockpit -Interior Green ANA611 or FS34151. Instrument panel, control panels and glare shield Non-specular black. Radio compartment Salmon Interior structure thru out airframe -Salmon Inside Nose bowl forward of cylinders. Same color as outside of same area. Inside engine accessory panels salmon. Inside engine cowl Flaps same as outside. Outer wings non-specular Blue-Grey top and bottom. Wing fold area on outer wing panels the same on outer wing, BlueGray. Gun bays-Salmon. Landing gear -metallic silver Inside (back of) main gear doors - gray. Main gear wheelwells above hinge -Salmon. Tailwheel parts-Gray Inside tailwheel doors -gray Inside tailwheel area above hinge line -Salmon Insignias Blue circle, white star. On both wings both top and bottom. NO bars. Edited November 9, 2017 by Miloslav1956 Link to comment Share on other sites More sharing options...
Miloslav1956 Posted November 9, 2017 Author Share Posted November 9, 2017 Thanks all! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 9, 2017 Share Posted November 9, 2017 That's an interesting painting guide, Miloslav. What's its source? Kev Link to comment Share on other sites More sharing options...
Miloslav1956 Posted November 9, 2017 Author Share Posted November 9, 2017 That's an interesting painting guide, Miloslav. What's its source? Kev That's what he sent me, the owner of this plane, Chuck Wahl. It is now being restored. Colors are based on what they found on the plane. The model I built for him. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 9, 2017 Share Posted November 9, 2017 That's what he sent me, the owner of this plane, Chuck Wahl. It is now being restored. Colors are based on what they found on the plane. The model I built for him. Thanks, Miloslav. I'm still not convinced that the wheel bays would be in exposed primer, but I can't fault you for doing it the way you did, based on the instructions you were given. It's still an excellent model! Kev Miloslav1956 1 Link to comment Share on other sites More sharing options...
Bill Cross Posted November 10, 2017 Share Posted November 10, 2017 Jarhead aviation rocks! Love them Corsairs. Link to comment Share on other sites More sharing options...
Martinnfb Posted November 10, 2017 Share Posted November 10, 2017 Lovely build as always Miloslave. You make it look all so easy Cheers Martin Link to comment Share on other sites More sharing options...
Miloslav1956 Posted November 10, 2017 Author Share Posted November 10, 2017 Thanks all ! Link to comment Share on other sites More sharing options...
dodgem37 Posted November 10, 2017 Share Posted November 10, 2017 Bang up job, Milo! Excellent photography. Love the walk-around. Sincerely, Mark Link to comment Share on other sites More sharing options...
