Out2gtcha Posted December 5, 2017 Share Posted December 5, 2017 Very nice work! What he said! I still like the overall look of the 110. Its a good looking airframe. I like the overall desert schemes too! Link to comment Share on other sites More sharing options...
ChuckD Posted December 6, 2017 Author Share Posted December 6, 2017 (edited) I agree. It is a good looking airframe. In certain roles, it excelled. In it its intended role, however... Anyway, my new paints are due to arrive today, and I don't have any specific plans for the evening, so I'm hoping to get some bench time to get this project moving forward. (!!) Yep, I agree but it is very difficult to find photographic proof. Just makes sense that they would paint that area with the underside of the horizontals. Thanks! That was my logic too, but I also struck out when looking for definitive references. Edited December 6, 2017 by Gewehr 43 sandokan 1 Link to comment Share on other sites More sharing options...
ChuckD Posted December 14, 2017 Author Share Posted December 14, 2017 Hey, as a quick heads up, the kit I'm using for this build is on sale today (12/14/17) at Dragon. http://dragonusaonline.com/item_detail.aspx?ItemCode=CHC3209 It's a pretty solid deal on a very nice kit. monthebiff, MikeMaben and sandokan 3 Link to comment Share on other sites More sharing options...
ChuckD Posted December 19, 2017 Author Share Posted December 19, 2017 (edited) Progress! Back again with another slow update. Since I've now ended up running both my 109 and 110 builds in parallel, I'm going to just update the WIP for both of them here and have changed the thread title to denote that. I never created a dedicated thread for the 109, but I figure who wouldn't want to see more pictures of plastic. That's why we're here, right? Anyway, after 66.7 hours (total, to date) base coating is nearly done on the 110. I still have a couple detail things to do, like painting the air filters and MGs, but those will only take a little bit. I decided to go with the one Italian scheme primarily because my six year old said he liked the look of the yellow cowlings. So, here we are. Paints on the 110 are Tamiya XF-59 (Desert Yellow) and XF-64 (Red Brown) in a 3:1 mix for the RLM79. I did a little color modulation/fading by adding some white to that mix. The RLM78 on the lower fuse is MRP's RLM78. Yellow is Tamiya and the white band is MRP's Insignia White. All in all, painting went fairly smoothly. I was able to lay down both colors at around 14 PSI, so masking was kept to a (thankful) minimum. I had to stick the gear legs on because without them, the beast rested on the air scoops and the yellow paint was scuffing. Chipping will be next. Going to go with the tried and true sponge method. Hope it translates to aircraft as well as it has treated me with armor. As an aside, these two builds remind me just how miserable it is to paint white and yellow in general. The 109 is a little further along. It has been decaled, washed, faded, and had an oil dot filter applied. Next will be final weathering for oil streaking, exhaust staining, dirt, grime, etc, then it'll be done. This is the Hasagawa Bf-109F4 Trop kit and it's a dandy. I forgot to look, but I believe I have about 35 hours into it so far. For this one I used Mr. Color 119 RLM79 for the upper fuselage. Both this and the custom Tamiya mix above came out pretty well and I don't see a significant different in appearance or performance for either of them. I did not do any airbrush fading with the Mr. Color, so any fading you see was achieved with oil paints. Anyway, on to pics. Edited December 19, 2017 by Gewehr 43 tucohoward and sandokan 2 Link to comment Share on other sites More sharing options...
ChuckD Posted December 19, 2017 Author Share Posted December 19, 2017 Continued... AlexM, LSP_Kevin, sandokan and 5 others 8 Link to comment Share on other sites More sharing options...
mozart Posted December 19, 2017 Share Posted December 19, 2017 A timely update "Herr Gewehr", and both are looking very good indeed. I'm also a fan of MRP paints, in fact I've just ordered extra stocks of various colours including RLM02. Having just completed a commission build in 1/48th of an FAA Hellcat, I'm finally "released" to do one of my Bf110s! Before starting the G-4 based on the E-2Trop (and I have your build bookmarked!) I'm going to do my E night fighter, using it as a "practice run" for the G-4. Max Link to comment Share on other sites More sharing options...
Gazzas Posted December 20, 2017 Share Posted December 20, 2017 109 and 110 are looking fantastic! Can't wait for more! Gaz Link to comment Share on other sites More sharing options...
ChuckD Posted December 29, 2017 Author Share Posted December 29, 2017 (edited) Good evening, everyone. Hope you all had a wonderful holiday in whatever corner of the world you call home. I'm back with a quick update. The Bf-109 is done. I'll be posting an RFI thread shortly and linking it here once it's done. It turned out pretty well. Probably my best aircraft kit so far, but I still have lots of room for improvement. Here's a teaser till I get the RFI posted: Edit: Here is the RFI thread. Anyway, for the -110, I finished the chipping process. I'm waffling on whether or not to do a clear gloss. The base coat is so smooth, I bet I can get away without it. I had a real problem with microscopic hairs and dust getting in the clear on the 109, so I'm wary of the same thing happening to the 110. I'll probably do a clear coat, but I'm not looking forward to battling the dust bunnies. So, after a grand total of 71.2 hours, here's where I'm at with the 110. I hope to knock out a bit more before the holiday ends. Having started it in September, I'm hoping to have it done before the 4 month mark. Ugh. This shot helps show off the color modulation pretty well. Edited December 29, 2017 by Gewehr 43 Daniel460, tucohoward, sandokan and 4 others 7 Link to comment Share on other sites More sharing options...
Bstarr3 Posted December 29, 2017 Share Posted December 29, 2017 Beautiful paint work on both. Good color modulation with tan and yellow is hard to do. Link to comment Share on other sites More sharing options...
Daniel460 Posted December 29, 2017 Share Posted December 29, 2017 Excellent work on both! I'm not sure if you noticed it in yours. I had to increase the size of the front section of my engine cowls by adding some plastic stock for the G-4. I do believe that one upper cowl is a bit larger than the other, I say that because I can't be sure that all the work I did may have distorted one? Dan Link to comment Share on other sites More sharing options...
mozart Posted December 29, 2017 Share Posted December 29, 2017 I'm liking both the 109 and the 110 very much indeed. Max Link to comment Share on other sites More sharing options...
ChuckD Posted December 29, 2017 Author Share Posted December 29, 2017 Beautiful paint work on both. Good color modulation with tan and yellow is hard to do. Thank you. Starting with a black base coat helped. Excellent work on both! I'm not sure if you noticed it in yours. I had to increase the size of the front section of my engine cowls by adding some plastic stock for the G-4. I do believe that one upper cowl is a bit larger than the other, I say that because I can't be sure that all the work I did may have distorted one? Dan I can definitely say that one of the cowls fit far better than the other, even though they're the exact same part number. I didn't have to add anything other than some tabs that helped place them as I showed earlier in the thread. The cowls are by far the worst part of this kit. I'm liking both the 109 and the 110 very much indeed. Max Thank you! Daniel460 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 29, 2017 Share Posted December 29, 2017 Love it! The desert 110s looks lovely. Link to comment Share on other sites More sharing options...
ChuckD Posted December 31, 2017 Author Share Posted December 31, 2017 It's times like this that I'm thankful the Germans decided to number every bulkhead in this aircraft, from nose to tail. :/ 6.5 hours of decal work later, and that phase is done. Here are the decals installed, faded/blended slightly, and sealed. Having worked a lot with Tamiya & Hasegawa decals lately, these Cartograf decals are a joy to work with. They snuggle into panel lines really well. The only thing I didn't like was the swastika because it was in 3 pieces and looked really weird after assembly. So, I borrowed a couple for a 109 from the spares bin. They're a tiny bit undersized, but I think they're close enough for government work. So, here's what just shy of 80 hours' worth of work looks like: Hitting the home stretch now. Once the sealer coat cures, I will start with some oil streaking and general dirtying up, then flat coat, pigments, and final touches. Almost there! mozart, TaffyMan and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
ChuckD Posted January 2, 2018 Author Share Posted January 2, 2018 The RFI thread is up! She's done! Thanks to everyone for following along, offering advice, and encouragement. Hope you enjoyed the build thread. LSP_Kevin 1 Link to comment Share on other sites More sharing options...
