thierry laurent Posted July 28, 2017 Share Posted July 28, 2017 Hi folks,Some days ago I got the LEM resin kit of the Ki-115. The kit is VERY nice:- Excellent shapes and seemingly accurate dimensions. It looks like they used the only set of detailed plans I know (also available on the web).- Good details with a fully riveted airframe- Nice level of detail- Excellent casting (I really had to look after them to find some very small air bubbles)The kit does not ask for a lot of improvements. Besides some basic improvements detailed hereunder, I recommend purchasing a set of RB belts as the kit has none.Directly, out of my head, I'm thinking at the following attention points:- The engine is correct but as for any other kit needs adding the wiring- The exhausts ends are not hollowed but they are so thin, I am not convinced it would have been possible to cast them otherwise.- The cockpit could have been a little bit more detailed. But this is essentially a classical matter of adding cables, wires and some missing details or elements here and there. The only point that annoys me is the floor as the full airframe had none! This is not terribly difficult to correct (just time-consuming) but could have been correct from the start (ten minutes of search on Google gave me a view of the actual structure).- Be prepared to add your own reinforcement parts for the seams between the wings, elevators and fuselage. Note that dry-fitting shows excellent assembly but simply butt-joining the parts with glue seems a little bit too risky to my eyes!- The kit has no instructions, just a CD with many pictures of the kit. So take your time to analyse things comprehensively. By the way, I got from the web copies of the instruction sheets of the 1/48 and 1/72 injected kits. This will help in assembling and painting.Last, the references about that plane are VERY limited. I have yet to find one good book dedicated to that plane. So, except some rare pictures from preserved airframes, the sources look to be quite limited. The old Monogram book from Mikesh has some elements but if somebody knows a good book about the plane, I would be interested in knowing it.Hope this helps.Thierry Out2gtcha, Troy Molitor, scvrobeson and 1 other 3 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 28, 2017 Author Share Posted July 28, 2017 One point I should have explained better: as the plane had no cockpit floor, the two supports linking the seat sides to the upper edge of the rear bulkhead should be added. This can be easily done out of two plastic strips. For a similar reason, the systems fixing the control stick or the lever located on the port side of the seat should also be recreated with some bits of plastic. Thierry Link to comment Share on other sites More sharing options...
thierry laurent Posted July 28, 2017 Author Share Posted July 28, 2017 At last, I would have preferred a full propeller axis and a hollow spinner but with some careful work, a good result may be obtained. Link to comment Share on other sites More sharing options...
Shawn M Posted July 28, 2017 Share Posted July 28, 2017 its a neat airplane I had a lot of fun researching it for my 1/48th build Link to comment Share on other sites More sharing options...
thierry laurent Posted August 7, 2017 Author Share Posted August 7, 2017 I forgot: Here is the best page of reference pictures I found to correct and detail the interior: https://web.archive.org/web/20091028065816/http://geocities.com/~scottvanaken/closeups/115guide.html Hth Thierry coogrfan 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted August 8, 2017 Author Share Posted August 8, 2017 This page gives some other interesting pictures such as the lever located on the port side of the seat (bomb launching?): https://airandspace.si.edu/collection-objects/nakajima-ki-115a-tsurugi-sabre The sketches here give an overview of the pit components: https://s-media-cache-ak0.pinimg.com/originals/7a/02/78/7a0278c474a77bdc99b0d0e92e3008f4.jpg The instructions of the Special Hobby kit to get some color and scheme inputs: http://www.cmkkits.com/en/aircraft/ki-115-tsurugi/ and to end some scale plans: http://www.airwar.ru/other/draw2/ki115revi.html https://www.the-blueprints.com/blueprints-depot/ww2planes/ww2-nakajima/nakajima-ki-115-tsurugi-5.png If LEM had used all of such inputs, their kit would have been nearly perfect...! Mebo and Wurzacher 1 1 Link to comment Share on other sites More sharing options...
Wurzacher Posted October 10, 2020 Share Posted October 10, 2020 Hello Thierry, I have to thank you for all the links you provided on the Tsurugi! The material you show up will be so helpful when I will do my build some day! Did you post a WIP here or anywhere else? Would love to read it! Best regards, from rainy southern Germany, Thomas Link to comment Share on other sites More sharing options...
thierry laurent Posted October 10, 2020 Author Share Posted October 10, 2020 Thanks Thomas. No WIP as I did not start the kit. This was just a quick review. Correcting the cockpit will ask for serious analysis as at the same time the floor should be removed but there shouldn't be a fuselage seam. Out of my memory I intended to create a false floor mimicking the fuselage internal side. Link to comment Share on other sites More sharing options...
