crowe04 Posted July 25, 2017 Share Posted July 25, 2017 I recently acquired the old Matchbox 1/32 Puma helicopter kit, a great model but obviously due to its age the decals are pretty much unusable. The main issue with them (apart from the yellowing) is the protective waxed paper is stuck to the entire sheet. I was hoping to somehow remove the waxed paper, scan the decals and reprint them on decal paper after a bit of photoshop work. Does anyone have any clues as to how the waxed paper can be safely removed without damaging the decals? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 25, 2017 Share Posted July 25, 2017 Welcome aboard, sir! I'm not sure if there's an easy answer to your question, but if there is, I'm sure one of our members will know it. Kev Link to comment Share on other sites More sharing options...
Bill_S Posted July 25, 2017 Share Posted July 25, 2017 Try good old-fashioned lighter fluid. As always, test on a piece before you do the whole sheet. Link to comment Share on other sites More sharing options...
Jeff Posted July 25, 2017 Share Posted July 25, 2017 wasn't there a thing where you could put a warm damp cloth over the decal, and let it sit for a while? Then when the cover paper softened a bit from the warm and damp, it came off? I thought I remember reading that some where a LONG time ago..... Out2gtcha 1 Link to comment Share on other sites More sharing options...
modelingbob Posted July 25, 2017 Share Posted July 25, 2017 Good luck. I've never been able to salvage the decals when they are stuck firmly to the waxed paper. Maybe someone here has had better luck than me. Link to comment Share on other sites More sharing options...
Tony T Posted July 25, 2017 Share Posted July 25, 2017 (edited) There are Puma decals available for French Army & Air Force machines, made by FFSMC. Search for decals for 1/32 SA 330 Puma on e-bay. Tony p.s. this is a UK link to this item... http://www.ebay.co.uk/itm/FFSMC-Productions-Decals-1-32-Puma-SA330-AS332-PUMA-AdA-Army-of-theAir-/302221142383?hash=item465dc8a96f:g:WNkAAOSwYmZXKhG7 edited to add link Edited July 25, 2017 by Tony T Link to comment Share on other sites More sharing options...
MikeMaben Posted July 26, 2017 Share Posted July 26, 2017 The paper became stuck due to the atmospherics of temperature and moisture over time, so it should take something similar to remove it. If you can direct some steam in a relatively small stream and do small areas at a time, you might steam it off. I have 'not' done this myself so this is merely a suggestion. Have fun Link to comment Share on other sites More sharing options...
ssculptor Posted July 26, 2017 Share Posted July 26, 2017 I will have to try the lighter fluid solution when I find my Matchbox kits in the stash. Back in the '70's when I was collecting old postcards we used to dissolve the adhesives from old pieces of tape using Ronson lighter fluid. This stuff came in a yellow container, still does as a matter of fact. Often the tape would come off in a few seconds but once the tape had discolored the paper that was permanent. Never use Zippo fluid as that often stains. Link to comment Share on other sites More sharing options...
