Erwin Posted August 10, 2004 Share Posted August 10, 2004 Hi all, Getting started on the tropical 109... Link to comment Share on other sites More sharing options...
Erwin Posted August 10, 2004 Author Share Posted August 10, 2004 ...a special 'thank you ' goes to Chris Sherland for providing the technical data. And to Ermeio from Italy for making this filter. I owe you guys ! Strange that the aftermarket doesn't make a resin trop filter for these kits Link to comment Share on other sites More sharing options...
Lancman Posted August 10, 2004 Share Posted August 10, 2004 Hi Erwin looking good, is that the G-6 early that you are building? How is the kit building any pitfalls yet. Cheers Graham Link to comment Share on other sites More sharing options...
Erwin Posted August 10, 2004 Author Share Posted August 10, 2004 Lancman, It's the G 6 early kit. Asking about pitfalls. Well,the engine is not what I hoped it to be.Those vinyl parts just suck ! :angry: Don't know why Trump didn't mold that in plastic. So I dicided not to show it after messing to much with glue. But I'm sure a better builder than me will have no problems with it. Link to comment Share on other sites More sharing options...
Erwin Posted August 11, 2004 Author Share Posted August 11, 2004 ...started brushpainting...left wing still wet. Link to comment Share on other sites More sharing options...
Erwin Posted August 13, 2004 Author Share Posted August 13, 2004 ...the wings and tail section are done. I'm not using the Trump national decals,because they are to glossy. I used the Airfix decals. My problem is ,that with brushpainting it's difficult to add a overall matt cote when all painting and decaling is done. It ruined my Fokker this way before,so I'm not taking that risk again. The Airfix decals are more matt. Link to comment Share on other sites More sharing options...
maverick728470 Posted August 13, 2004 Share Posted August 13, 2004 Erwin, For doing the flat coating of u'er decals.Just brush the inside of each decal and work out as to fill in the decal,from the center out.One thin coat should do the trick.And one thing u can do first before u coat them with flat.Use a decal solvent.It will draw down the decaLS AND THEN AFTER THE SOLVENT HAS DRIED.tHEN FLAT COAT THE CALS.lARRY Link to comment Share on other sites More sharing options...
Tim Carroll Posted August 14, 2004 Share Posted August 14, 2004 Hi Erwin, Why dont you coat the decals with a mat varnish while the are still on the decal sheet? When dry you can cut them close to or on the decal clear film then and apply them over the settling solution as suggested. I use the Polyscale clear flat by brush and airbrush on my models and have found it wonderfully flat. Once dry it is a pretty bullet proof coating. I have not found it to leave brush streaks if its well mixed Cheers Tim Link to comment Share on other sites More sharing options...
Erwin Posted August 14, 2004 Author Share Posted August 14, 2004 How do you find your filter now Ermeio ? Looks good to me. Thanks again Link to comment Share on other sites More sharing options...
Erwin Posted August 14, 2004 Author Share Posted August 14, 2004 ...almost there.Fuselage got the first coating. Link to comment Share on other sites More sharing options...
Dave Pratt Posted August 15, 2004 Share Posted August 15, 2004 Good job Erwin.I really like that trop filter.I still have my 1/32 G-4 trop to finish as soon as it cools down some here.Keep up the great work...cheers Link to comment Share on other sites More sharing options...
Erwin Posted August 15, 2004 Author Share Posted August 15, 2004 ..Finished !! OoB and brushpainted. No personal markings added.Just showing a Tropical 109. Link to comment Share on other sites More sharing options...
Erwin Posted August 15, 2004 Author Share Posted August 15, 2004 ... Link to comment Share on other sites More sharing options...
