1to1scale Posted April 22, 2018 Author Share Posted April 22, 2018 (edited) I went by pictures, the early GSB aircraft were clearly different. It's funny, because the Insignia blue is completely an accident, I meant to mix Tamiya Sea Blue and Royal Blue, but I accidentally picked up XF-85 rubber (same cap color as Sea Blue), I mixed 2:1 and it came out perfect! This photo shows an aircraft that has significant weathering and wear, but you can see they are different, and the insignia is definitely darker. Edited April 22, 2018 by 1to1scale JeepsGunsTanks and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
Bstarr3 Posted April 24, 2018 Share Posted April 24, 2018 Yes great demonstration of the difference in that photo. This also shows that GSB was not always the bulletproof color I have read it to be. Plenty of chipping and weathering on this example! Thanks for sharing Link to comment Share on other sites More sharing options...
Shawn M Posted April 24, 2018 Share Posted April 24, 2018 that photo shows a LOT of excellent weathering information Link to comment Share on other sites More sharing options...
1to1scale Posted April 25, 2018 Author Share Posted April 25, 2018 My string of bad luck is following me. Today, nothing was working out for me at work today, I wrapped up early, set up the paint booth, and proceeded to shoot some primer. I should have know, bad luck follows me. I loaded up the primer in the airbrush and started spraying. After a few seconds, I noticed the paint pattern was wonky, so I grabbed a cotton bud and some thinner and cleaned the nozzle. Started spraying angain, but the paint flow was dropping to nothing, suspectingting clumps in my primer, I poured off the cup, ran some cleaner through it and changed primer colors, started spraying again, same issue, it's clogging again. I then took the whole airbrush apart and did a deep super clean, put it all back together, then put more primer in it, clogged again! I ran some more cleaner through it and noticed bubbles in the cup. WTH? I took it all apart again, made sure to take it all apart, and soak it in airbrush cleaner. A few hours later, I went to put it back together, noticed that the nozzle o-ring was broken (was perfect during the previous cleaning), I then found out that the paint cup o-ring was also broken! I just replaced it last time I painted! GRRR! Realizing I needed to quit before I destroyed something else, I decided to put all the parts together and order some o-rings. It was then that I noticed, I had completely lost my needle locking nut! This was just turning out to be a bad day... Time to order a new airbrush. BloorwestSiR and BradG 2 Link to comment Share on other sites More sharing options...
1to1scale Posted April 25, 2018 Author Share Posted April 25, 2018 I ordered an Iwata Eclipse Hp-Cs Shaka HI, Kagemusha, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 25, 2018 Share Posted April 25, 2018 Some days, nothing quite goes your way. Sorry to hear about the airbrush troubles. I love my Iwata airbrushes so I think you'll be happy with your choice. Carl Link to comment Share on other sites More sharing options...
Kagemusha Posted April 25, 2018 Share Posted April 25, 2018 At least you noticed something was wrong straight away. There is always a positive. Link to comment Share on other sites More sharing options...
1to1scale Posted April 25, 2018 Author Share Posted April 25, 2018 Yes, I don't hink I will have to strip anything. I checked this morning and all the primer leveled out well. So hopefully my new Iwata arrives sometime today and I get back to priming. Kagemusha, LSP_Kevin and Shaka HI 3 Link to comment Share on other sites More sharing options...
Bstarr3 Posted April 27, 2018 Share Posted April 27, 2018 Sorry for your troubles but congratulations on your new airbrush! Link to comment Share on other sites More sharing options...
1to1scale Posted April 28, 2018 Author Share Posted April 28, 2018 I'm back at it, once again, the Hellcat masks i had didn't work as they were the wrong size and type of insignia. Also, the only place in the world that has this particular Montex mask set in stock, is in Australia. Which means $35 expedited shipped to get it within two weeks, I spent that the first time, but not again. So that's not an option as I'm not spending $70 to buy two sets of masks. Unfortunately, the insignia tore when I removed them the first time, so I didn't bother saving any masks either. So now I am piecing together a set using leftovers and what I have. I managed to find the insignias in a set from a P-47 universal set, the wing tip bar masks were cut by knife from Tamiya tape, I still have the positive side of the “21†masks, as well as decals. So hopefully I can get paint down this weekend. BloorwestSiR 1 Link to comment Share on other sites More sharing options...
1to1scale Posted April 28, 2018 Author Share Posted April 28, 2018 BradG and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
JeepsGunsTanks Posted April 28, 2018 Share Posted April 28, 2018 Nice to see your Hosenose back on track! Paint issues like that are the worst. The Corsair was such an interesting bird, one of the few cases of us putting an airframe in combat that had not had all its bugs worked out, but even so, it did very well. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted April 29, 2018 Share Posted April 29, 2018 Glad to see you back at it. Nice mixing and matching to get the sizes you needed. Carl Link to comment Share on other sites More sharing options...
1to1scale Posted April 29, 2018 Author Share Posted April 29, 2018 I little progress this morning... BradG, LSP_Kevin and johncrow 3 Link to comment Share on other sites More sharing options...
1to1scale Posted May 1, 2018 Author Share Posted May 1, 2018 Significant paint progress today. I used every tool in the kit today, it was humid, I added clear gloss, I used retarder, I thinned the paint 50%, and I put on thin layers. It came out great! Out2gtcha, Dragon, LSP_Kevin and 10 others 13 Link to comment Share on other sites More sharing options...
