kuky76 Posted October 14, 2014 Share Posted October 14, 2014 OK. You have worked very precisely I would like to ask you about Montex Mask. Which item did you use? Could you recommend it? THX Link to comment Share on other sites More sharing options...
cbk57 Posted October 14, 2014 Author Share Posted October 14, 2014 Hi Kurky I used the set specifically for the A6m2 in the hope that the hinomaru would be the correct size for those plane in case there is a difference with the a6m5. Also I knew I would not be using white outlines which look like they are on the a6m5 set. I kind of think the a6m5 set might be better as a whole since they include masks for the no walk area on the wings. As far as using them goes I really worry with any adhesive that it will leave residue or worse pull up paint. In this case the masks have a very minimal tack but it is sufficient to easily seal the mask area. I had a very slight bleed of white on one or two which can be fixed with a bit of careful touch up. I used extremely thin paint though as I only wanted a base not total coverage and the bleed was on panel lines. I did not want to compromise paint thickness. I removed the masks immediately after finishing paint to minimize time in contact with the base color. I had no residue and no pull up at all. I am going to try them on my next build which will require a more difficult test as it will be US stars and bars which involve two colors and so the star will have to be down longer. I also think their price point is good for what you get. Maketar for example is more expensive but you get a lot more in a package. I tried Maketar once and found these easier to work with vs. Maketar kabuki masks. My only complaint is that the number sets seem to only represent aircraft already in the Tamiya kit. It would be nice if they would have included more generic letters and numbers to do some common and popular alternatives. The Tamiya kit depicts all Pearl Harbor schemes which I don't think are very interesting as the Zero was not that significant at Pearl Harbor. Only a handful of American Fighters even got off the ground. I agree that I probably placed them just a little far inboard as I noticed as I was placing that the back side was farther than shown from the rear edge of the wing but appeared that the right side of the circle was falling on the correct panel line. Anyway that error is going down to close enough. Someone posted a poll last week about a hypothetical subject page. I kind of figure that I always make some mistakes and every model as a result is a bit hypothetical. Link to comment Share on other sites More sharing options...
kuky76 Posted October 14, 2014 Share Posted October 14, 2014 Hello cbk :-) Thank you very much for your exhaustive answer about Montex Mask. I have just bought the same model kit hlj.com, but I have not yet decided about markings. Montex Mask is one of possibilities. Of course I agree with you. A6M2 Zero is most famous Japanese aircraft of the Pacific War. Unfortunately many world's hobby industries prefer machines from Pearl Harbour. Dont worry about Hinomaru. I am convinced that Hinomaru has corect size Link to comment Share on other sites More sharing options...
ringleheim Posted October 15, 2014 Share Posted October 15, 2014 The markings look great to my eye. The paintwork is a noticeable improvement over the use of a decal in my opinion. It allows for greater surface detail through the marking and it just looks more "correct" like the real thing. Nicely done. Link to comment Share on other sites More sharing options...
mywifehatesmodels Posted October 15, 2014 Share Posted October 15, 2014 I like the way you used the salt technique to add a dimension that's not usually seen in model aircraft finishes. Personally, I don't think it's too subtle and will probably look just right by the time you are finished. A nice touch and I'm going to have to catalog that one in the back of my brain for later. John Link to comment Share on other sites More sharing options...
cbk57 Posted October 21, 2014 Author Share Posted October 21, 2014 I have mounted the motor and applied decals. Not shown here but the Landing gear has been installed, inner cowlings painted, gear bays sprayed in exterior color. Decalling is mostly done. I added some wiring on the back side of the motor. mywifehatesmodels 1 Link to comment Share on other sites More sharing options...
kuky76 Posted October 22, 2014 Share Posted October 22, 2014 uf...your project is better and better. The engine with wires is more detailed. I really like it :-) P.S. Do you have any detail picture of controle surfaces on the wing? THX Link to comment Share on other sites More sharing options...
cbk57 Posted October 29, 2014 Author Share Posted October 29, 2014 I have mainly been working on weathering. I have been using various shades of grey and green filters on different parts of the plane. I have also been used different types of fuel, oil, and grime staines on relevant areas. I hope you enjoy. mywifehatesmodels 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted October 30, 2014 Share Posted October 30, 2014 I have mounted the motor and applied decals. Not shown here but the Landing gear has been installed, inner cowlings painted, gear bays sprayed in exterior color. Decalling is mostly done. I added some wiring on the back side of the motor. I was borne in Saskatchewan and I don't recall ever seeing a zero in front of any of the grain elevators? Link to comment Share on other sites More sharing options...
Troy Molitor Posted October 30, 2014 Share Posted October 30, 2014 Looking fantastic. Link to comment Share on other sites More sharing options...
cbk57 Posted November 6, 2014 Author Share Posted November 6, 2014 (edited) It is not done but I am wrapping up the details. Here are a few photos, I hope to finish this weekend. I am starting with an aged B&W. I think the paint came out okay. Edited November 6, 2014 by cbk57 Link to comment Share on other sites More sharing options...
cbk57 Posted December 5, 2014 Author Share Posted December 5, 2014 I have been awaiting some better lighting and backdrop for photos. Received them today. This is all but done and will move to posting in ready for inspection when I am happy with my final photos. mywifehatesmodels 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 5, 2014 Share Posted December 5, 2014 Looks good! Can't wait for the final photos. Kev Link to comment Share on other sites More sharing options...
LSP_Ray Posted December 5, 2014 Share Posted December 5, 2014 Beautiful work! Link to comment Share on other sites More sharing options...
