Joel_W Posted May 16, 2017 Share Posted May 16, 2017 I'm looking forward to just how you go about correcting those filet issues. Joel Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 16, 2017 Author Share Posted May 16, 2017 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 16, 2017 Author Share Posted May 16, 2017 I did just an acceptable few lines of rivets - far from whats really on the upper surface. First time using the rivet tools I bought. Not bad for a quick job In this case i will use the recessed side as the upper surface but to be accurate you could use the blue side which has very nice looking raised rivets. I glued in some plasticard to start forming a stronger base for the surface skin. Last 2 steps will be to glue in a thin layer of card to form the upper surface properly and then finally the metal skin goes on. Not sure how i will get the bolt line fairings back on - (at the wing joints). Maybe cut them off the remaining parts that I removed - in other words the original fairings go back on as individual pieces. Oh - and then we get to the Leading edges and wheel fairings Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 16, 2017 Share Posted May 16, 2017 Very cool work, SBH! Kev Link to comment Share on other sites More sharing options...
Joel_W Posted May 16, 2017 Share Posted May 16, 2017 Most impressive riveting. I never would have guessed that it's your 1st time doing it. Joel Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 17, 2017 Author Share Posted May 17, 2017 Glued horizontal stabiliser halves cleaned up undercarriage legs realised that even aligning the trailing edge of the horizontal stabs with fuselage mounting slot puts them too far back, they need to got forward about another 3-5mm so quite an adjustment to be done in that area Cut undercarriage doors Then I spent ages slowly trimming one side undercarriage gap on wing lower surface - this will be a very long process. I guess a week will pass before I can move on past this section. Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 21, 2017 Author Share Posted May 21, 2017 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 21, 2017 Author Share Posted May 21, 2017 After swearing to myself that I'd never build another vacform, i had a quick look at the other vacform i bought at the same time (sister kit to this one) being the Harvard Mk 1, and Im already wanting to build it. It doesnt contain a Centre section so id have to make one (I dont want to steal one from one of my monogram kits. So once this build is done I may just start the next one. As you can see I spent the weekend doing some spraying and painting. Still a lot to do Link to comment Share on other sites More sharing options...
Joel_W Posted May 22, 2017 Share Posted May 22, 2017 It sure seems like the bug has bitten you. Joel Link to comment Share on other sites More sharing options...
Lee White Posted May 22, 2017 Share Posted May 22, 2017 Crew chief is doing the YMCA dance. Link to comment Share on other sites More sharing options...
Lee White Posted May 22, 2017 Share Posted May 22, 2017 After swearing to myself that I'd never build another vacform, i had a quick look at the other vacform i bought at the same time (sister kit to this one) being the Harvard Mk 1, and Im already wanting to build it. It doesnt contain a Centre section so id have to make one (I dont want to steal one from one of my monogram kits. So once this build is done I may just start the next one. As you can see I spent the weekend doing some spraying and painting. Still a lot to do Is the center section constant chord, like your metal one? You could carve it in wood, and heat a suitably sized piece of plastic, drape it over the mold, and when it cools, you can trim it to shape. Joel_W 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 22, 2017 Author Share Posted May 22, 2017 Yes it is, and yes - not a bad suggestion at all. Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 22, 2017 Author Share Posted May 22, 2017 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted May 22, 2017 Author Share Posted May 22, 2017 Theres the Harvard Mk 1. A couple of minor differences to the BC-1, notably the rear canopy and also differences near the cowling. Link to comment Share on other sites More sharing options...
