elmarriachi Posted June 14, 2017 Share Posted June 14, 2017 Hello, I want to show you one more small kit of a construction vehicle. This time an old motor grader from Caterpillar, model number 12. It was built during world war two and still used long time after the war all around the world. The kit comes from Plus Model from Czech Rep. and is a multimedia kit consisting of resin, wire, etched parts and decals. Also included a CD-Rom with pictures of the kit and the original, a good mounting instruction and clear head lamps. Unfortunately the kit includes only decals and painting guide for two versions of the US Army - no civil one in the typical Caterpillar yellow which I will make ... First I have started with the frame, rear tandem-axle and the steering axle with the steering linkage, then the wheels. The engine is consisting of several small and smaller parts plus some photo etched parts. I think I will add some wire to it next to give it some more details ... Cheers Micha Shawn M, dutik, Joe66 and 1 other 4 Link to comment Share on other sites More sharing options...
Shawn M Posted June 14, 2017 Share Posted June 14, 2017 gonna be cat yellow or combat green? Always been fascinated by these machines since I was a kid Link to comment Share on other sites More sharing options...
Jeff Posted June 15, 2017 Share Posted June 15, 2017 I operate a Cat 160 M series road grader ( no steering wheel, and no control levers , all joy stick and button controls VERY cool ), and they are an awesome piece of kit, I love old iron like this and hope to see it in Caterpillar colors... I hope they do a newer road grader kit too..... looking forward to seeing this build Tinbanger 1 Link to comment Share on other sites More sharing options...
elmarriachi Posted June 21, 2017 Author Share Posted June 21, 2017 Hello, and some more pictures .... The driver's place .... some levers follow later..... the rest is done .... ... and primered in rusty red ... ... also the rest of the car is primed in red ... some wiring at the engine added (although only a little bit will be visible later) ... Behind the front axle mounted: The ripper ... behind the ripper follows the blade .... Next follows some hairspray.... then typical Caterpillar yellow at the engine and rear/bottom of the driver's place .... Cheers Micha Shawn M, Jeff T, Girlscanplay2 and 2 others 5 Link to comment Share on other sites More sharing options...
elmarriachi Posted June 26, 2017 Author Share Posted June 26, 2017 Hello, the rear area of the grader was primered in rusty red, then water and salt added. The main color was sprayed on top in the rear area and on the engine, consisting of Tamiya X4 and Lifecolor orange. After that the blade and some further parts were added, also some parts at the drivers place - levers, steering wheel, ... After that the new added parts were primered, water/salt added and everything painted in the final yellow colors. Then the salt removed. Next step - painting all the details, then weathering. Cheers Micha Joe66, Girlscanplay2, Rick Griewski and 4 others 7 Link to comment Share on other sites More sharing options...
Jeff Posted July 2, 2017 Share Posted July 2, 2017 Micha, this is looking good........ I hope you greased all those knuckle joints ! This is looking really good, I especially like the scarifiers, they have some good details......that seems to be an old school option, seems these days graders now have rea rippers and olny occasionally, that I have seen.... VERY cool kit and you are doing an incredible job, it's looking well used.... cheers Jeff Link to comment Share on other sites More sharing options...
elmarriachi Posted July 6, 2017 Author Share Posted July 6, 2017 Hello, the motor grader is mostly finished now. Some last details need to be done, also the base which I have begun needs some further work... But before I could go on I will leave to summer vacatiln now Cheers, Micha Jeff, Girlscanplay2, BiggTim and 2 others 5 Link to comment Share on other sites More sharing options...
Jeff T Posted July 6, 2017 Share Posted July 6, 2017 Superb work Micha! That is awesome, and as someone that has spent a few years on Graders, a very interesting project to me, you certainly dont see too many Grader models. Cheer's, Jeff. Link to comment Share on other sites More sharing options...
dodgem37 Posted July 6, 2017 Share Posted July 6, 2017 New or used, you hit a home run every time. Talent galore! Nicely done, Micha. Sincerely, Mark Link to comment Share on other sites More sharing options...
elmarriachi Posted July 28, 2017 Author Share Posted July 28, 2017 Hello, I think that's it ... some weathering of the white/red rods missing yet, then I think it is done ... Cheers Micha Rick Griewski, Girlscanplay2 and BiggTim 3 Link to comment Share on other sites More sharing options...
elmarriachi Posted August 1, 2017 Author Share Posted August 1, 2017 Hello, pictures of the finished Motor Grader 12 of Caterpillar in 1/35 by Plus Model: I hope you like it! Rick Griewski and BiggTim 2 Link to comment Share on other sites More sharing options...
