Converting Hasegawa Bf-109G-4 to a Bf 109F-4 w/o Aires conversion
  • Please log in to reply
8 replies to this topic
#1 oyoy5
oyoy5
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 757 posts
Posted 20 March 2017 - 02:50 PM
Correct me if I am wrong but would it be easier to convert the G-4 to and F-4 with some simple fixes.  The gun cowling is correct in the G-4 for the F version.  Cut off the 4 cooling scoops and putty in the hole and scribe a couple access hatches and open the landing gear area of the wings into the circular shape instead of the square.  Front canopy can be replaced from my extra box of Eduard and cyber hobby.  Am I way off base?
  • harvey and AdamR like this
#2 Jennings Heilig
Jennings Heilig
    Senior Member
  • LSP_Members
  • 5,920 posts
  • Gender:Male
Posted 20 March 2017 - 03:29 PM
Perhaps I'm being too obvious, but why not just get a gorgeous Hasegawa Bf109F-4 kit and build it?
  • Rick Griewski, Martinnfb, harvey and 2 others like this
"It's all part of the show..."
#3 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 5,353 posts
  • Gender:Male
Posted 20 March 2017 - 03:50 PM
It also depends on the F type you are looking for. The initial G is actually very close to the F-4Z subtype.
Thierry
  • Martinnfb likes this
#4 Jennings Heilig
Jennings Heilig
    Senior Member
  • LSP_Members
  • 5,920 posts
  • Gender:Male
Posted 20 March 2017 - 04:39 PM
Only in terms of the prop and oil cooler.  Otherwise the F-4/Z was like other Fs.
#5 Mikester
Mikester
    Senior Member
  • LSP_Members
  • 1,403 posts
  • Gender:Male
Posted 20 March 2017 - 10:42 PM
It can be done but unless you have a compelling reason to do it I'd just get a Hasegawa F-4.  Don't forget the cockpit layout was slightly different in the F as well.  Your G-4 kit probably has later style main wheels and the larger tail wheel so they'd need to be replaced too.
Edited by Mikester, 20 March 2017 - 10:44 PM.
Mike Offutt
Yokosuka, Japan via Temecula, Ca
#6 Thunda
Thunda
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 364 posts
  • Gender:Male
Posted 20 March 2017 - 11:14 PM
Can confirm that about the wheels- I had taken the resin ones out of my G4 kit to use with the F4 'Marseille' kit, and theres quite a difference- ended up putting them back and getting Aires ones- plus the spinner and props are correct and more accurate. Both great kits, but the F4 has the edge in my opinion- paticularly if you want to build any early-ish F.
Im guessing you already have the G4 in your stash though?
#7 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 5,353 posts
  • Gender:Male
Posted 21 March 2017 - 07:51 AM
The oil cooler is precisely why I stressed that aspect as it is really a nasty part to convert oneself. I know I got a F one somewhere but this was not from one of the usual suspects (possibly Vector). Finding thinner propeller blades is not necessarily easy either...
T.
#8 Kagemusha
Kagemusha
    Senior Member
  • LSP_Members
  • 8,930 posts
  • Gender:Male
Posted 21 March 2017 - 09:20 AM
The Aires conversion set illustrates what needs changing, curious the op hasn't added further input.
#9 Rick Griewski
Rick Griewski
    Senior Member
  • LSP_Members
  • 1,025 posts
  • Gender:Male
Posted 29 March 2017 - 10:46 AM
The Hasegawa kit has the split flaps. By the time you complete the conversion you will be too tired to do the great tree branch camo scheme.
Rick
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
