patricksparks Posted August 18, 2016 Share Posted August 18, 2016 Work has been really slow for the last few months, so I had to do something to keep my sanity..Full size BF-109G instrument panel, why not... while working on it I suddenly realized how big the Revi gunsight was and thought hmmm..make it work ? It's amazing what you can do with a really good color copier(instrument faces) built every thing from scratch with the exception of the screws and nuts...started the wind screen but work picked up again.... Fooesboy, Jolly Roger, 109 and 28 others 31 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 18, 2016 Share Posted August 18, 2016 That looks amazing! What kind of work do you do that allows you to do that in your spare time? Kev mpk, patricksparks, Out2gtcha and 2 others 5 Link to comment Share on other sites More sharing options...
CATCplSlade Posted August 18, 2016 Share Posted August 18, 2016 Well, he obviously works for the Federal government. 109, mpk, Jeff and 14 others 17 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 18, 2016 Share Posted August 18, 2016 Wow, that looks SUPER DUPER impressive!! Really love it................it looks like those instruments could spring to life any moment patricksparks and mpk 2 Link to comment Share on other sites More sharing options...
patricksparks Posted August 18, 2016 Author Share Posted August 18, 2016 Thanks for the compliments, I'm a model maker by trade, display industry right now, used to work in the toy and prototyping industries as well. andromeda673, Shawn M, mpk and 4 others 7 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 18, 2016 Share Posted August 18, 2016 Thanks for the compliments, I'm a model maker by trade, display industry right now, used to work in the toy and prototyping industries as well. You can haz skillz. Kev Bill_S, Out2gtcha, mpk and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted August 18, 2016 Share Posted August 18, 2016 Well, it definitely translates well to scale aircraft modeling! patricksparks and mpk 2 Link to comment Share on other sites More sharing options...
Shawn M Posted August 18, 2016 Share Posted August 18, 2016 thats excellent, can you share the materials used? mpk and patricksparks 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted August 18, 2016 Share Posted August 18, 2016 Really impressive work there. At first, I thought this was the Eduard IP they included in a couple kits. Do you plan on making others to go with it? Carl mpk and patricksparks 2 Link to comment Share on other sites More sharing options...
patricksparks Posted August 18, 2016 Author Share Posted August 18, 2016 thats excellent, can you share the materials used? The panels are 1/2" or 12MM PVC foam board(AKA, Sintra,Komatex,Celtec)it is very easy material to use can be cut on a band saw, table saw, jig saw, routed you can drive screws into it and does'nt split. The instruments are routed 1/4" styrene backs with vacuum formed bezels and 1/16" acrylic lenses. The instrument faces are color copied images propotioned to the appropriate size and inicator needles are made from .030 styrene and some music wire for some of the pointers. The srews and nuts are real hardware, I bought brass screws for mounting the instruments and blackened them. The paint is all spray cans mostly Valspar, they make a nice grey called "Blindfold" that looks pretty close to interior grey. Shaka HI, Joe66, Vandy 1 VX 4 and 3 others 6 Link to comment Share on other sites More sharing options...
patricksparks Posted August 18, 2016 Author Share Posted August 18, 2016 Really impressive work there. At first, I thought this was the Eduard IP they included in a couple kits. Do you plan on making others to go with it? Carl For now it's just a one of a kind, I started to make the wind screen and also part of the fuselage to mount the panel into but work started to get busy and I had to set it aside, that's the downfall of being a model maker for a living, when your busy all day making models for your job I tend to not want to keep doing it after work !!! Link to comment Share on other sites More sharing options...
Shaka HI Posted August 18, 2016 Share Posted August 18, 2016 The panels are 1/2" or 12MM PVC foam board(AKA, Sintra,Komatex,Celtec)it is very easy material to use can be cut on a band saw, table saw, jig saw, routed you can drive screws into it and does'nt split. The instruments are routed 1/4" styrene backs with vacuum formed bezels and 1/16" acrylic lenses. The instrument faces are color copied images propotioned to the appropriate size and inicator needles are made from .030 styrene and some music wire for some of the pointers. The srews and nuts are real hardware, I bought brass screws for mounting the instruments and blackened them. The paint is all spray cans mostly Valspar, they make a nice grey called "Blindfold" that looks pretty close to interior grey. Well then, that's simple enough.. Uncarina, mpk and patricksparks 3 Link to comment Share on other sites More sharing options...
Derek B Posted August 18, 2016 Share Posted August 18, 2016 That is amazing work Patrick - well done (if that's what you are capable of when you're bored, I can't even imagine what you do when you are busy!). I appreciate exactly what work and effort goes into fabricating a full scale replica from scratch (in a former life, I was a professional model maker for the RAF Exhibition Production Flight (EPF) and one of my tasks - apart from making models for the RAF Museum and refurbishing CIO models - was to produce full scale cockpit facsimiles for full scale replica fibre glass aircraft and EPF Trailer Display Units (TDU's) ). Derek mpk, patricksparks and jgrease 3 Link to comment Share on other sites More sharing options...
ssculptor Posted August 18, 2016 Share Posted August 18, 2016 It would be fun to use in place of the real dashboard on a real car. Slip the few necessary real dials in there and off we go into the wild blue yonder. I would put it in a hot rod type auto. Stephen mpk, patricksparks and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
jgrease Posted August 18, 2016 Share Posted August 18, 2016 Wow - that is just ridiculous. Awesome work! John mpk and patricksparks 2 Link to comment Share on other sites More sharing options...
