Youngtiger1 Posted July 10, 2012 Share Posted July 10, 2012 Wow Peter, you are doing some crazy work. Now, I can see the man's talent behind those cool cockpit decals. Also, thank you for sharing the tip on your brass sheet detail work. BTW, one small request, will it be to much to ask for tad bit larger photographs of your updates? If that is ok with you. TIA Mike Link to comment Share on other sites More sharing options...
Martinnfb Posted July 10, 2012 Share Posted July 10, 2012 Fantastic detail with some great tutorial photos. Thanks for sharing. M. Link to comment Share on other sites More sharing options...
A.Wolf Grant Posted July 10, 2012 Share Posted July 10, 2012 I really ought to check in more often on this fabulous build. Masterful scratch building sir, and a great tutorial to boot. Grant. Link to comment Share on other sites More sharing options...
airscale Posted July 10, 2012 Author Share Posted July 10, 2012 You are all too kind Thanks for your comments and encouragement, I can see now why a build log and a GB are so enjoyable – just wish I had given it a go years ago and maybe wouldn’t have stopped for so long I am having great fun and at the moment anyway things are going well I think. It’s strange having not worked on a kit part all week, it’s actually set me wondering if I one day I might try scratchbuilding literally from ‘scratch’ – a 1/32 Tigercat, is one I have always wanted and with no kit in sight (yet) would be ultra cool Anyway, back to reality and the Fury. Have been getting the side consoles in shape – still more levers and switches to add but starting to look a bit more busy now. Getting ready for the instrument panel but I am waiting for my prototype airscale bezel samples to arrive from the etch bods (oops hope I don’t get disqualified! ) – I love doing IP’s... Excuse the big blobs of white tack and everything not quite being true and square as it’s just dry fit for now - have made the pics a bit larger too (scary, I can see loads of corrections...) until next time Peter Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 11, 2012 Share Posted July 11, 2012 You are all too kind Thanks for your comments and encouragement, I can see now why a build log and a GB are so enjoyable – just wish I had given it a go years ago and maybe wouldn’t have stopped for so long Quite.............doing some AMAZING work here Peter. It is true from personal experience, that WIPs and GBs here at LSP are quite special.......and mostly all due the wonderful modelers and overall wonderful human beings we have here. It’s strange having not worked on a kit part all week, it’s actually set me wondering if I one day I might try scratchbuilding literally from ‘scratch’ – a 1/32 Tigercat, is one I have always wanted and with no kit in sight (yet) would be ultra cool OIY! Again..........................my ALL TIME favorite aircraft! If you DO, you better make me a master, so I can have the Boss Man! I swear, its the only airframe I KNOW Id by multiple, multiples of................... :wub: :wub: Link to comment Share on other sites More sharing options...
dodgem37 Posted July 11, 2012 Share Posted July 11, 2012 Most excellent scratching, Peter. A nicely rendered 1/33 Paper F7F: http://kartonist.de/...69c4#post186810 Sincerely, Mark Link to comment Share on other sites More sharing options...
airscale Posted July 11, 2012 Author Share Posted July 11, 2012 Been working from home this week (normally in the city) so have had a chance to crack on in between conference calls / emails... I realised in my last post i hadn't touched the kit, so set about it with lots of sharp objects..... I intend to show the engine panels open, and having removed the exhaust panels already as they are so crude and mis-shapen I cut away the inspection panels on one side with a razor saw & dremel I now have a big void staring at me which needs a bit of planning on how best to fill it - I want to make a cylinder head master and cast copies in resin - has anyone got any tips or are there any past threads on doing it? Made initial vertical cuts with an x-acto razor saw - left plenty of spare plastic to finish down to the correct panel line - the covers themselves will be re-made Made the horizontal cuts with a fine tooth circular saw in a Dremel at the lowest speed setting Deliberately left the nose cowl ring to preserve the structural integrity of the fuselage Voila! a big hole to tuck a Centaurus into.... TTFN Peter Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted July 11, 2012 Share Posted July 11, 2012 Hi Peter,what an amazing cockpit you've done already! Are you sure there are corrections needed? Looks incredible to me. How do so many of you on this site build 1) so quickly and 2) with such an eye to detail??!!! Maybe in a few years, i'll be able to come close. I almost went with a Seafury too (I have the Fisher one) but decided on the X-15. Still great to see so many of them being built. Carl Link to comment Share on other sites More sharing options...
airscale Posted July 11, 2012 Author Share Posted July 11, 2012 Thanks Carl Kind words indeed, I guess I am going faster than some simply because this is my first build in 2 years and I think the repressed inner me has burst out with an insane level of enthusiasm As for detail, just get good references and build what you see - each part is a set of shapes and a like a mini-kit in itself Thought I would add a last post for the day simply because to get around the whopping hole I made in the fuselage for the engine I needed a plan. A cunning plan came as if from the professor of cunning at cunning university - I can build the engine around a central core that slots neatly into a recess in the kit nose where the prop boss is... In the real aircraft there is no firewall until the cockpit as the engine is mounted on a framework of rods so doing it this way should support everything and keep it central here's what I mean... Here is the core dry fitted - all I need now are 9 cylinders - I need that professor of cunning again... until next time Peter Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
A.Wolf Grant Posted July 12, 2012 Share Posted July 12, 2012 Wow, that's clever and more than a little effective too. I'm thoroughly enjoying this. Grant. Link to comment Share on other sites More sharing options...
Thomas Lund Posted July 12, 2012 Share Posted July 12, 2012 Excellent work - I've already learned a lot. I'm very impressed with your skills 'toddlers with crayons' made me LOL Link to comment Share on other sites More sharing options...
airscale Posted July 14, 2012 Author Share Posted July 14, 2012 evening all, and thanks Grant & Thomas..kind words indeed I see some fantastic builds coming along in this GB and more importantly everyone enjoying themselves - it's a pleasure to take part I have been fiddling about with more tiny bits and am beginning to wonder if the real world is just a giant scale version there to make me feel clumsy (Doc, where's my pills) Got a bit further, and got some casting stuff on order so definately stepping out of the comfort zone on this one.. hope it goes well as I have a few ideas how I might add to airscale's ranges with resin cockpit bits if I can make it work on the Sea Fury anyways, on to todays update.. until next time.. Peter Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
A.Wolf Grant Posted July 15, 2012 Share Posted July 15, 2012 Great update Peter ... you're certainly going the whole hog on this one (and why not?). I think patience of a saint crossing the mind yet again, somehow I suspect that will be a recurring theme Grant Link to comment Share on other sites More sharing options...
airscale Posted July 16, 2012 Author Share Posted July 16, 2012 evening all just a little update as I thought I would get on with something else while I wait for the silicone & resin to arrive so I can cast some engine bits Had a bash at the prop and spinner... thats all folks.. until next time Peter Landrotten Highlander 1 Link to comment Share on other sites More sharing options...
A.Wolf Grant Posted July 16, 2012 Share Posted July 16, 2012 Extraordinary! Grant. Link to comment Share on other sites More sharing options...
