SirBlueHenry Posted June 21, 2017 Share Posted June 21, 2017 I am almost starting a 1/12 Frame which is not for a full aircraft. It is intended for open viewing but will include as much of all the small detail as i can. I purchased 3.5mm Brass rod a while back, then I finally got the North American blueprints and a couple of weeks back got a gas torch as my soldering iron will never handle the heating of this large brass rod. The Frame will include a select few bras at 2.5mm. What I have yet decided is if all the sleeves at the joints will be part of my plan. The jig style that I had used previously on smaller frames will of course not work due to the blowtorch so I have some interesting jig planning to do - in a style which can handle a couple hundred degrees heat. First up will be some trials on soldering with the torch - which I will post as well 109 and Dan Paxton 2 Link to comment Share on other sites More sharing options...
Jim Barry Posted June 21, 2017 Share Posted June 21, 2017 Scratchbuilding seems to be buzzing here lately. Glad to see this, too. Looking forward to your progress! Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 21, 2017 Author Share Posted June 21, 2017 Heres some pics of some of the work on 1/72 and 1/48 brass frames Jim Barry, Rdrunner, Joe66 and 1 other 4 Link to comment Share on other sites More sharing options...
Joe66 Posted June 21, 2017 Share Posted June 21, 2017 Really nice work ! In 1/12 scale, it might be wise and look really good to sleave per the prototype, or at least pin all the joints... with the right pins and "fish mouthing" of the tube ends, you may not need any fancy jigs. Good luck and I look forward to seeing you project ! Joe Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 21, 2017 Author Share Posted June 21, 2017 109 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 21, 2017 Author Share Posted June 21, 2017 Yes Joe, I think you might be right. I looked through my stuff and I have a tiny bit of 4mm tube which fits beautifully, so now I would have to find quite a bit of it - maybe my local hobby shop - will have to see. I will have to do some thinking about how to manufacture these multitube joins. Link to comment Share on other sites More sharing options...
Joe66 Posted June 22, 2017 Share Posted June 22, 2017 SirBlueHenry, If you are not familiar with these tools, have a look on the internet for pictures / info: Jewelers torch ( if flame soldering is your thing ) Tubing notcher - I think you could whip up a miniture version, for fish mouthing the smaller brass tubing Bicycle frame building jig - again, make something akin to this for miniature work and your soldering of frames will be easy peasy ! ( the joints for your a/c framework are somewhat similar to the lugged construction of a steel bicycle frame ) Best wishes for your project ! Joe Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 22, 2017 Author Share Posted June 22, 2017 Cheers Joe, no I am not familiar with them except maybe the jewellers torch. Anyway - all of this will be new area for me. All I've done up to now is straight soldering. Thanks for the info. Link to comment Share on other sites More sharing options...
PROPELLER Posted June 22, 2017 Share Posted June 22, 2017 Hi SBH! Expansive, but the best way... https://americanbeautytools.com/Resistance-Tweezer-Systems Link to comment Share on other sites More sharing options...
Dan Paxton Posted June 22, 2017 Share Posted June 22, 2017 Cant wait to see and watch you weave your magic!!! Dan Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 23, 2017 Author Share Posted June 23, 2017 Hmm, looking at the blueprints I see that in fact very few of the joints had sleeves so that makes things MUCH easier and much less work. Dan Paxton 1 Link to comment Share on other sites More sharing options...
