Bomber_County Posted October 2, 2016 Share Posted October 2, 2016 John, here's a question for you...... My Corsair is at the stage of yours except I haven't fixed tail fin or tail planes. Everything is built and ready including outer wings, all flaps and gear Not sure if to spray now and then fix flaps etc etc after or bolt her together and spray, several guys seem to do it both ways. That's my dilemma......... Any help would be welcome........ Phil John F Smith and Mal_Belford 2 Link to comment Share on other sites More sharing options...
John F Smith Posted October 2, 2016 Author Share Posted October 2, 2016 Hi Phil, I'm not sure that I have a very good answer to your question, but here goes. I've not fixed my tail fin or tail planes either, they are only fitted for the photographs. You see I have been struggling with the same question myself. It seems to me that whichever approach you choose, there is going to be a lot of masking involved. Unless, of course you have better freehand control than I in the area of spraying straight lines, managing overspray, and other (to me, anyway) advanced airbrush techniques. My intent is to paint the sub assemblies creating soft lines with raised masks and using the scribed lines on the aircraft for "hard" demarcations. But I'm sure open to thinking about assembling, priming, and painting the whole airframe, too, which was Peter's (another LSPer) approach Could you weigh in on this topic, Peter, if you are reading? John Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 2, 2016 Share Posted October 2, 2016 (edited) Hi John & Phil John knows me like a book and when I built my Corsair, as my normal procedure, the vertical stabilizer rudder, horizontal stabilizers and elevators were all glued in place, allowing any fit issues to be taken care prior to priming. I also prefer to install the flap as well. In the Corsairs case, I had the wings folded, so they were painted off the model but at the same time. I just find it easier to take care of seam and any small fit issues before painting. Somehow, parts fit well before painting but the fit afterwards never seems to be the same for me. The outer wings completed and left off until the last stages Edited October 2, 2016 by Peterpools Link to comment Share on other sites More sharing options...
shark64 Posted October 3, 2016 Share Posted October 3, 2016 stunning build Link to comment Share on other sites More sharing options...
Bomber_County Posted October 3, 2016 Share Posted October 3, 2016 John / Peter Thanks for the thoughts, there is no easy answer to this one as you said John. I agree with both of you.........I must admit adding liquid cement to a fully top coated model scares me...........I think I am going for, add everything bar the u/c and going for it........ Wish me luck..........I think....... John F Smith 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 3, 2016 Share Posted October 3, 2016 Phil Solid plan ... you should do just fine Peter Link to comment Share on other sites More sharing options...
John F Smith Posted October 4, 2016 Author Share Posted October 4, 2016 Anytime, Phil If you have more questions, I'm sure that anyone here will be happy to help you, or refer you to someone who can. BTW, I'm with you on this question; everything but the u/c and then bring on the primer. John Bomber_County 1 Link to comment Share on other sites More sharing options...
Bomber_County Posted October 4, 2016 Share Posted October 4, 2016 Only trouble I'll have to wait until after Telford Scale show next month as I was going to treat myself to a new brush and compressor ...... plus plus plus plus.....come the conclusion you only live once, taken me 56 years to realise it.......... KUROK 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted October 4, 2016 Share Posted October 4, 2016 Phil Absolutely, you only go around once Peter Link to comment Share on other sites More sharing options...
David Hansen Posted December 7, 2016 Share Posted December 7, 2016 I don't know if this is still relevant, but on the two Corsairs i've built so far, i left off the flaps, ailerons, tailplanes, and rudder until i get the camo pattern finalized. The two areas that are hardest to paint (well) are the areas beneath the tail planes, and the lower fuselage right behind the trailing edge of the wing where the intermediate blue transitions into the white. Leaving the inboard flaps off allows you to fine-tune the separation without the flap acting as an unwanted paint mask, throwing off the separation. The actual F4U at final assembly was primed in yellow zinc chromate primer. The outer wing panels, flaps, rudder, vertical fin, ailerons, and horizontal stabs arrived on the final assembly line as completed and pre-painted units, so the majority of the paint work done at final assembly was painting the fuselage and center wing segment to "blend it in with the rest of the airplane", which is why you see non spec sea blue over spray on the base of the vertical fin, on the undersides of the wings around the wing fold line, etc. The horizontal stabs fit well enough that you shouldn't need to fill the joint and gluing them on late in the game should be easy to do. Cleanup should be minimal. I DO recommend putting little bits of making tape on the trailing edges of the wing where the ailerons go, since those tips are unprotected and have a tendency to hook onto things and possibly break off. Same problem goes for the Tamiya P-51D. Hope this helps. -d- Anthony in NZ 1 Link to comment Share on other sites More sharing options...
Bomber_County Posted December 27, 2016 Share Posted December 27, 2016 Thanks David, just picked the Corsair up again and having purchased new brush and compressor I am ready to go........ On the point of outer wings, did you fix them to the spar or just leave the panels as a slide fit. My only concern is keeping the witness line consistent as in the real plane? Any pointers gratefully recieved......... Link to comment Share on other sites More sharing options...
David Hansen Posted December 28, 2016 Share Posted December 28, 2016 Hi Phil, I glued my outer wing panels on, since i needed to do a progressive evolution of spot gluing the get the lower inner and outer wing surfaces level and flat with each other. Tamiya actually engineered that .010 gap along the upper wing "break" line on purpose, as far as i can tell. If built correctly its pretty consistent from left to right wings. If the upper surfaces are not absolutely, perfectly level with each other, not really a deal breaker; not that obtrusive. -d- Link to comment Share on other sites More sharing options...
Bomber_County Posted December 30, 2016 Share Posted December 30, 2016 David. Come to the same conclusion to get the outer and inner to be flat with each other it has to be glued. The differential is minuscule but I know it will bug the hell out of me. Just about there, cleaned off all sprues as double check.......tally Ho and thanks for the advice..... Link to comment Share on other sites More sharing options...
Bomber_County Posted December 30, 2016 Share Posted December 30, 2016 John, how is yours going..........you're probably finished, decaled and weathered......... Link to comment Share on other sites More sharing options...
John F Smith Posted January 4, 2017 Author Share Posted January 4, 2017 Hi Phil, Mine is in a holding pattern right now. Other priorities got in the way for a while, but I'm planning on making a "start" to finish it in the next couple of weeks. Many thanks to both you and Dave for the fine suggestions on the painting process for the Corsair. John Link to comment Share on other sites More sharing options...
