PCM 1/32 Re. 2005..... tale of an elegant fighter
alaninaustria
Alan, this is some beautiful work you are doing! So crisp and clean.... :unsure:
You're making me reconsider tackling a resin kit like this at some point. Can't wait to see the finished product, and your step-by-step is like a master class.
This bird has a couple of really nice sized "bumps" :unsure: I decided to pin these as well, just like I did with the props..first I marked the locations...
Who doesn't love a nice set of bumps on a gorgeous dame ... like the Re. 2005 Sagittario? :wacko:
and then I removed the bumps... and deepened the holes slightly to accept the pins! :unsure:
It will help if you scrape a little material away from the center of the bumps... a concave surface will sit down nicely on the upper surface!
One small detail that I forgot to tackle before glueing the wings together was to clean out the cannon shell/link ejector holes... I used a small file to get this done - it still requires clean up with a polishing stick...atleast the wing is deep enough to allow a small file to clean that out...
