Derek B Posted March 1, 2012 Author Share Posted March 1, 2012 Removal of the Milliput inserts from the wings: These inserts will now have to be chopped and squared, and I may need to shim them as well...more progress to follow... Derek Link to comment Share on other sites More sharing options...
Derek B Posted March 6, 2012 Author Share Posted March 6, 2012 The SG500 jagdfaust is still progressing well, but as I was completing my Spitfire universal bomb carrier box artwork, I decided to really get ahead and do likewise for my SG500 box artwork as well, so here it is: Cheers Derek Link to comment Share on other sites More sharing options...
Daywalker Posted March 6, 2012 Share Posted March 6, 2012 Excellent stuff Derek! What a great tip on the milliput, I should get myself the Tee shirt as well! I always enjoy seeing your work, your solutions to problems and ideas are a source of inspiration to me. Link to comment Share on other sites More sharing options...
Derek B Posted March 6, 2012 Author Share Posted March 6, 2012 Excellent stuff Derek! What a great tip on the milliput, I should get myself the Tee shirt as well! I always enjoy seeing your work, your solutions to problems and ideas are a source of inspiration to me. Thanks Frank - You're too kind! Derek Link to comment Share on other sites More sharing options...
LSP_Matt Posted April 9, 2012 Share Posted April 9, 2012 Mmmm...good tips on the milliput there Derek. Thanks for that. That will help me out no end. I do love the Komet. What a ride....R1 pilots only...hehe Cheers Matty Link to comment Share on other sites More sharing options...
Derek B Posted April 9, 2012 Author Share Posted April 9, 2012 (edited) Mmmm...good tips on the milliput there Derek. Thanks for that. That will help me out no end. I do love the Komet. What a ride....R1 pilots only...hehe Cheers Matty Hi Matty, I have completed the inserts and I'm now workng on the tubes (I have wasted two already; I made them 0,4mm undersize!). I have no idea at present how I am going to manage to drill out the inserts and mount all eight tubes at exactly the same distance, angles and alignment...we'll see? Glad that you found the Milliput tips useful Cheers Derek Edited April 9, 2012 by Derek B Link to comment Share on other sites More sharing options...
Derek B Posted April 10, 2012 Author Share Posted April 10, 2012 Small update. I have now cut my eight Jagdfaust tuebes (screwed up five more in the process!) and am now in the process of thinning and shaping them all. I will have to make the SG 500 rounds for them next before I attempt to install them into the wing inserts (the scary bit!). Derek Link to comment Share on other sites More sharing options...
Tnarg Posted April 10, 2012 Share Posted April 10, 2012 Extremely cool project. I really want one of these. Will we have to use brass tubing in the kit? It seems the best way to do the tubes given casting limitations. Thanks, Tnarg Link to comment Share on other sites More sharing options...
Derek B Posted April 10, 2012 Author Share Posted April 10, 2012 Extremely cool project. I really want one of these. Will we have to use brass tubing in the kit? It seems the best way to do the tubes given casting limitations. Thanks, Tnarg Thanks Grant This will be a one-piece casting withe the brass tubes already in place. I think that it comes down to how well the mould is designed in terms of casting success here? (Grey Matter Figures have a lot of experience in this field). Ultimately, we will wait and see? - If it doesn't work, I'll have to have a plan B! Cheers Derek Link to comment Share on other sites More sharing options...
spacewolf Posted April 10, 2012 Share Posted April 10, 2012 Great work Derek, good info too. I take it you'll be using a drill press to make the holes ? Perhaps a jig cut to hold the part at the proper angle for the holes would be the way to go ? Vaughn Link to comment Share on other sites More sharing options...
Derek B Posted April 10, 2012 Author Share Posted April 10, 2012 Great work Derek, good info too. I take it you'll be using a drill press to make the holes ? Perhaps a jig cut to hold the part at the proper angle for the holes would be the way to go ? Vaughn Yeah, these are the sort of things that I need to consider? I have calculated that the tubes are angled backwards by 4 degrees and inboard by 3 degrees, so they will be very tricky to correctly space and align! Cheers Derek Link to comment Share on other sites More sharing options...
Derek B Posted April 17, 2012 Author Share Posted April 17, 2012 A little more progress. The eight SG 500 tubes (with SG 500 round/inserts aded) are now completed. The next stage will be to drill the wing inserts and install the SG 500 tubes into them. Derek Link to comment Share on other sites More sharing options...
Youngtiger1 Posted April 17, 2012 Share Posted April 17, 2012 Hey Big D, I like what you are doing here. I totally love the step-by-step tutorial on the putty. I'm going to save it all Mike Link to comment Share on other sites More sharing options...
Derek B Posted April 17, 2012 Author Share Posted April 17, 2012 Hey Big D, I like what you are doing here. I totally love the step-by-step tutorial on the putty. I'm going to save it all Mike D. Link to comment Share on other sites More sharing options...
dutik Posted April 17, 2012 Share Posted April 17, 2012 (edited) Make a jig with proper inclination, then drill with the help of a drill stand. Proxxon or Dremel will do the trick. Even much more comfortable if you are able to borrow a crosstable too; this will make the drilling of evenly spaced holes a breeze. As for mixing Milliput (as well as other 2-part putties): Nice trick to roll the material into balls to get the correct mixing ratio I suggest to roll the balls into thin "sausages" and twist the two parts around each other just like copper wire. This will make the mixing process much easier (especially if you are not the Schwarzeneggerian type with muscles the size of sea mines ) and eleminate the problem of having not-so-well mixed residues inside. Regards! - dutik Edited April 17, 2012 by dutik Link to comment Share on other sites More sharing options...
