Tamy F4U-2N build
  • Please log in to reply
1036 replies to this topic
#886 harvey
harvey
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 18,825 posts
  • Gender:Male
Posted 19 November 2017 - 01:50 AM
Phil and Dan, thanks friends......Harv
  • Harold and Daniel460 like this
There's a fine line between cuddling and holding someone down so they can't get away
working on:  Tamiya F4U-2 Night Fighter
Trump P-38M BACK ON BENCH FINISHED!!!
#887 BloorwestSiR
BloorwestSiR
    Senior Member
  • LSP_Members
  • 5,027 posts
  • Gender:Male
Posted 19 November 2017 - 02:01 AM
Looking great as always Harv. In fact, I've PM'ed Harold about the conversion set and am going to add one to the stash.
For the UV glue, I've got one from Bondic that works really well. They've got some videos posted too on how best to use them.
Carl
  • harvey and Daniel460 like this
#888 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 19 November 2017 - 03:26 AM
One thing about Harold's set, use the kit bomb racks and good luck. Hope you get started soon.... Harv
  • Harold and BloorwestSiR like this
#889 Harold
Harold
    Senior Member
  • LSP_Members
  • 4,352 posts
  • Gender:Male
Posted 19 November 2017 - 04:29 PM
I'm not including the bomb racks. If I had some good measurements and photos of the real thing, maybe I could cobble up a master. But, the kit racks look usable anyway.
Edited by Harold, 19 November 2017 - 04:54 PM.
  • harvey and BloorwestSiR like this
#890 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 19 November 2017 - 05:08 PM
Yes, they are......Harv
  • Harold likes this
#891 Harold
Harold
    Senior Member
  • LSP_Members
  • 4,352 posts
  • Gender:Male
Posted 19 November 2017 - 07:26 PM
Little worried of the outer rim. Not exactly round and uniform. Maybe small enough not to matter, I don't know........Harv
If you drop the resin wheel in a HOT cup of water, let it soak for a couple of minutes (carefully) remove it and squeeze it just bit to make it round. If you should have a small gap remaining all the way around, get some commercial acrylic floor polish (NOT Future), dip a toothpick into a small amount, touch it to the edge of the hub and it will wick and self level, do it several times after it dries in each application. (it can act as a glue for the hubs) The stuff is found in commercial restaurant suppliers, I bound a half gallon for $12 6 years ago and I still have enough left the rest of my lifetime and all of the other LSPers as well.
  • harvey and Shaka HI like this
#892 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 19 November 2017 - 07:31 PM
Thanks for the tip buddy !....Harv
  • Harold likes this
#893 Martinnfb
Martinnfb
    Senior Member
  • LSP_Members
  • 9,207 posts
  • Gender:Male
Posted 22 November 2017 - 02:18 AM
  • LSP_Paul, harvey, sandokan and 1 other like this
In progress:   D-13 ; Ta-152V7 ; Mig-29 ; EMIL ; P-39 Аэрокобра ; Avia S-199 ; K-14 what if
Done:            F-8 F-8 Wurger Party ; D-9 ; D-15; Ta-152E ; P-40E
#894 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 22 November 2017 - 03:29 AM
My friend, you crack me up !!......Harv
  • Martinnfb and Shaka HI like this
#895 Usmcski
Usmcski
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 108 posts
  • Gender:Male
Posted 22 November 2017 - 04:03 AM
Here is a pic I posted earlier. The cap when removed, shows the applicating tip. Its small and has great control. You squeeze the pen to get it through the tip, the glue is jelly like. After applying and placing part, you use the UV end and press to turn on. Shine it on the glue and this cure's it in just a few seconds. There about $5. you can find them at Wallymart in the "seen on TV" section. I highly recommend you try it......Harv
Hell yes! I recently discovered this gem, it's a fantastic way to adhere clear parts. The best thing is, if you screw up placement, you simply pry the part off and remove the cured "goop" without marring the clear plastic of the kit part.
Another use I found is for instrument faces. Unlike Future floor wax, which has a tendency to fill all the recesses of an instrument face, the consistency of this stuff lends itself to producing a flat, level finish, not unlike the flat panes glass of aircraft instruments. Just apply a judicious amount of clear epoxy, zap it with infrared light for about 30 seconds, and whammy, you have a scale representation of a real instrument.
Hope this helps!
Semper,
Ski
  • Harold, scvrobeson, harvey and 1 other like this
-Ski
"For those who fight for it, freedom has a special flavor the protected never know."
#896 scvrobeson
scvrobeson
    Senior Member
  • LSP_Members
  • 5,341 posts
  • Gender:Male
Posted 22 November 2017 - 06:40 AM
I've started using it for landing lights and instrument panels/HUD lenses. Works surprisingly well, can't believe it took this long to come up with such a great solution
Matt  :frantic:
  • harvey and Usmcski like this
#897 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 23 November 2017 - 07:12 PM
Happy Turkey day ! Flaps are done, not glued on. Quick question for guys that have buit this, Should I go ahead and attach now, or wait till painting is done ?......Harv
  • Harold, scvrobeson, JohnB and 2 others like this
#898 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,782 posts
  • Gender:Male
Posted 23 November 2017 - 07:23 PM
I always get the painting done then attach the flaps Harv.
  • harvey likes this
Be careful of the toes that you step on today for they may be connected to the ass you have to kiss tomorrow.
#899 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 23 November 2017 - 07:27 PM
Thanks John. It is a tri color bird......Harv
#900 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,782 posts
  • Gender:Male
Posted 23 November 2017 - 08:04 PM
Makes no difference Harv.
  • harvey likes this
