Basilisk Posted July 22, 2017 Share Posted July 22, 2017 Your cockpit is coming along nicely! But what are the two dials for above the Yahu IP? I also have some bad news. I think you fitted the front radiator grill back to front as the mesh should face forward so that you can see it through the front opening. Hopefully you can still fix this. Cheers, Peter DirkE 1 Link to comment Share on other sites More sharing options...
DirkE Posted August 11, 2017 Author Share Posted August 11, 2017 Your cockpit is coming along nicely! But what are the two dials for above the Yahu IP? I also have some bad news. I think you fitted the front radiator grill back to front as the mesh should face forward so that you can see it through the front opening. Hopefully you can still fix this. Cheers, Peter Peter, regarding the radiator grill. There is going to be a second one to be installed. This one you see fixed is done by the instructions. So once I have the second one, it should be ok. Anyway, I have to check my references again in case I or SpecialHobby is wrong and you are right. Dirk Link to comment Share on other sites More sharing options...
DirkE Posted August 11, 2017 Author Share Posted August 11, 2017 Progress has stalled, but its still on the bench and will be continued soon. Link to comment Share on other sites More sharing options...
Basilisk Posted August 11, 2017 Share Posted August 11, 2017 Peter, regarding the radiator grill. There is going to be a second one to be installed. This one you see fixed is done by the instructions. So once I have the second one, it should be ok. Anyway, I have to check my references again in case I or SpecialHobby is wrong and you are right. Dirk I see now, you only used the mesh, replacing the plastic part (I attached the mesh onto the plastic part). In that case there is nothing to worry about. Looking forward seeing your progress. Cheers, Peter Link to comment Share on other sites More sharing options...
