Joel_W Posted July 26, 2017 Share Posted July 26, 2017 Brend, Every update has custom made parts that are as near perfect as humanly possible. Joel 109 1 Link to comment Share on other sites More sharing options...
airscale Posted July 28, 2017 Share Posted July 28, 2017 Good evening, going on with the frames that go into the right fuselage shell. I made the right segment of frame 6. Dry fitting of the frame: Glued in place: That´s it for now ... Bye, Bernd. how the hell did you do that curved frame with a flange without using soft pewter or ali? I have tried & pretty much failed failed to make parts like that with flanged edges by pinching folds with flat nosed pliers, but yours look like they just came off a press.. mighty impressive stuff Peter Joel_W, sandokan, Derek B and 2 others 5 Link to comment Share on other sites More sharing options...
109 Posted July 28, 2017 Author Share Posted July 28, 2017 Hi Peter, my solution is to make a template from MDF. I lightly anneal those areas that will be formed around corners, e.g. the outer rim of the part shown. Happy modeling, Bernd. Derek B, Greg W, sandokan and 6 others 9 Link to comment Share on other sites More sharing options...
dodgem37 Posted July 28, 2017 Share Posted July 28, 2017 (edited) Nice capture. Inside riveting, too. Hope it shows with painting. It'd be a detail not often seen. Really good stuff, Bernd. Sincerely, Mark Edited August 22, 2017 by dodgem37 HerculesPA_2, Doctorgaz, sandokan and 2 others 5 Link to comment Share on other sites More sharing options...
Joel_W Posted July 28, 2017 Share Posted July 28, 2017 I'm speechless. the level of work is beyond us mortals. Joel 109 1 Link to comment Share on other sites More sharing options...
fab Posted July 29, 2017 Share Posted July 29, 2017 Hello Sometimes, i believe that I open meierMotors Gmh's website page...Non, it's again 109 in Lsp... Fab 109, KiwiZac and Rainer Hoffmann 3 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted July 29, 2017 Share Posted July 29, 2017 Hello Sometimes, i believe that I open meierMotors Gmh's website page...Non, it's again 109 in Lsp... Fab Couldn't have said it better. Phantastic workmanship, Bernd. Cheers Rainer Derek B and 109 2 Link to comment Share on other sites More sharing options...
109 Posted August 12, 2017 Author Share Posted August 12, 2017 (edited) Good evening, some progress on the right fuselage shell... I added frame 5, the longitudinal U-profile, frame 3d and frame 2. Frame 5 has a large circular opening for the oxygen-shower. The U-profil runs along the top edge of the sideconsoles from frame 3d to frame 5: Frame 3d is quite simple. In front of frame 3 is frame 2 with four circular openings: Close-up of f5 and f6: F2 (dry fitting) with the openings for four electrial sockets/connectors: Bye for now, Bernd. Edited August 12, 2017 by 109 XOPCT, Doctorgaz, Alburymodeler and 12 others 15 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted August 12, 2017 Share Posted August 12, 2017 Amazing work with aluminium. Taking notes and learning a lot. Hubert Derek B and 109 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 12, 2017 Share Posted August 12, 2017 How is this even possible? Kev 109, Derek B and aircooled_nut 3 Link to comment Share on other sites More sharing options...
109 Posted August 22, 2017 Author Share Posted August 22, 2017 Hi, before I can make the pilot´s shoulder armor and the seat assembly I have to make the floor plating. I am working on the rear floor between frames 8 and 3A. The circular holes are for the fuel tank connections. Pictures show some dryfitting. Now it´s time to light the charcoal for a barbeque ... :-) Bye! Doctorgaz, HerculesPA_2, MikeMaben and 8 others 11 Link to comment Share on other sites More sharing options...
HerculesPA_2 Posted August 22, 2017 Share Posted August 22, 2017 Its a great job!! CONGRATULATIONS!!! 109 1 Link to comment Share on other sites More sharing options...
109 Posted August 22, 2017 Author Share Posted August 22, 2017 Its a great job!! CONGRATULATIONS!!! Thanks! HerculesPA_2 1 Link to comment Share on other sites More sharing options...
Dan Paxton Posted August 22, 2017 Share Posted August 22, 2017 Its...its...ITS ALIVE!!!!! 109 and williamj 2 Link to comment Share on other sites More sharing options...
dodgem37 Posted August 22, 2017 Share Posted August 22, 2017 That is some sweet stuff, Bernd. Check F2. Sincerely, Mark XOPCT, 109, F`s are my favs and 6 others 9 Link to comment Share on other sites More sharing options...
