Zero77 Posted June 25, 2016 Author Share Posted June 25, 2016 It's virtually done now. I now just have to spray thin brown wash on the underside and add a bit of dirt splash on the wheels and under the lower wing and tail. And then, go to the display to keep the Sopwith Pup company ! The last steps were : -building the gun mount (parts are supplied but i broke the resin tiny strut and i did not like the PE part for a tubular part. So i only used the V shaped part and built the rest from scratch). -add the small reinforcement tail struts (made with styrene profiles as i did not like the kit parts). -chose and paint a Gaspatch Lewis MG. I chose the Mk.II. -Glue the wings. -detail and paint the tail skid. I applied an additional coat of putty to add with on the rear underside of the part to give the illusion of an added steel blade hold in place by the brace, and it worked nicely. -Replace the aileron control rods (the kit ones were short and thick) by styrene 0.64mm profiles, cut them to lenght and glue them inside the cockpit on the control stick brackets (hard to see on the picture, sorry). bstachel, X15 and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
Lothar Posted June 25, 2016 Share Posted June 25, 2016 What a fantastic build and tutorial, I love it Lothar Zero77 1 Link to comment Share on other sites More sharing options...
TimW Posted July 14, 2016 Share Posted July 14, 2016 Looking great! Tim W. Zero77 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted July 15, 2016 Share Posted July 15, 2016 That is beautiful, Zero!!! Zero77 1 Link to comment Share on other sites More sharing options...
Gene K Posted July 21, 2016 Share Posted July 21, 2016 What a magnificent build, Nicolas. (I came across this thread while looking for references to do a small Radio Control Nieuport 11 ... and I found plenty - thanks. Now I'll have to read all of your other WWI threads!!) Gene K Zero77 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 22, 2016 Share Posted July 22, 2016 Superb, Nicolas! Kev Zero77 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 22, 2016 Share Posted July 22, 2016 Very nice job on this kit. Mine never made it this far before I gave up (mine might have been the 16 though, I don't really recall). Zero77 1 Link to comment Share on other sites More sharing options...
Zero77 Posted July 22, 2016 Author Share Posted July 22, 2016 Thank you guys ! Now I'll have to read all of your other WWI threads!!) Gene K It will be quick, i only finished 3 WW1 models. Glad my WIP can help you for your RC Nie.11 ! Very nice job on this kit. Mine never made it this far before I gave up (mine might have been the 16 though, I don't really recall). Get back to it if you can ! There are a lot of little annoying traps in this kit, but it's a good kit (better than the Roden Nieuport series in my opinion) and with a little work it's quite easy to build. The kit engine cowling is correct for a Nie-16. Link to comment Share on other sites More sharing options...
X15 Posted July 22, 2016 Share Posted July 22, 2016 (edited) Absolument superbe !!! Je suis sur un N16 et ton montage me sert de référence ! ça semble facile en voyant tes posts mais c'est un vrai montage d'homme ce kit !!! Absolutely amazing Work !! I building a Nie16 and your work serves as my reference ! It looks easy when we saw your work but this kit is a real man mounting !! Edited July 22, 2016 by X15 Link to comment Share on other sites More sharing options...
Zero77 Posted July 22, 2016 Author Share Posted July 22, 2016 Merci à toi ! J'ai aussi le Nie.16 en stock, pas au programme dans l'immédiat mais je sais déjà que le ferai avec un camouflage et des fusées. Montage d'homme, oui et non. Il y a du travail de nettoyage et de renfort, mais globalement ça s'ajuste pas mal, et les détails sortis de boîte sont bon, donc c'est déjà pas mal ! Comparé à ton Caudron, je ne pense pas que ça soit un gros problème pour toi ! Link to comment Share on other sites More sharing options...
1to1scale Posted October 10, 2017 Share Posted October 10, 2017 I just purchased a SH 11 and 16, i am learning a lot from your build, beautiful craftsmanship! TimW 1 Link to comment Share on other sites More sharing options...
