nickd Posted November 13, 2006 Share Posted November 13, 2006 Hi guys, Need some help...I had a small problem with the decals on my Hunter last night. One of the decals for the large, underwing serial numbers is slightly damaged (completely my fault, as I touched it with a brush AFTER I'd put the Micro-Sol on). The end of the top bar in the 'F' in the large XF526 code, has gone a bit 'wobbly' What is the easiest way to remove decals ?? but without causing too much damage to the underlying Futre/paintowrk??? For info, the wing had three thin coats of future/Klear applied, then Micro-Set before applying decal, then two coats of Micro-Sol after applying decal. Any tips would be most welcome! cheers Nick Link to comment Share on other sites More sharing options...
Haggis Posted November 14, 2006 Share Posted November 14, 2006 I just pull it up with sellotape. Works like a charm. Link to comment Share on other sites More sharing options...
nickd Posted November 15, 2006 Author Share Posted November 15, 2006 Thanks Jamie, I'll give this a try tonight with some scrap decals, just to get a feel of it. cheers nick Link to comment Share on other sites More sharing options...
