Has anyone use Milliput as a bonding agent on resin kits?
milliput resin adhesive
  • Please log in to reply
12 replies to this topic
#1 Mustang JBB
Mustang JBB
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 84 posts
  • Gender:Male
Posted 26 September 2017 - 08:48 PM
I was thinking of mixing some milliput(or similar epoxy putty), rolling it out into long thin strips, then laying these strips over the contact areas on resin kits.  Instead of using CA or mixed liquid epoxy, use the milliput to bond the fuselage together.  Basically sandwiching a very thin layer of milliput between the parts, then trimming off the excess before curing.  Hopefully filling some gaps along the way.
Anyone ever tried this?  Any thoughts on pros and cons?  Experienced milliputers... any suggestions?
Thanks in advance!
James B
Edited by Mustang JBB, 26 September 2017 - 08:49 PM.
#2 Jack
Jack
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 6,419 posts
  • Gender:Male
Posted 26 September 2017 - 09:54 PM
hmmm interesting, never thought about that, but then again i never tried it, might be an option.
Did you try it out yourself??
everyone in the circuit switch off your radios....now switch 'em back on again......
#3 JeffH
JeffH
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 221 posts
Posted 26 September 2017 - 10:07 PM
Sounds intriguing for sure but the cost of some resin kits (cough HpH) makes it risky to be a pioneer in the field :)
If you have a cheaper test-bed kit to try it on, make sure you let us know how it goes.
You could experiment using chunks of the pour stubs first. Just to check how the materials interact
  • Shawn M likes this
#4 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,804 posts
  • Gender:Male
Posted 26 September 2017 - 10:16 PM
I think Milliput would be too thick for this sort of job, though it's great for filling large gaps in any type of kit, because it does add significant strength to the join beyond what traditional putties or CA would.
Ke
  • Zero77 likes this
#5 Iain (32SIG)
Iain (32SIG)
    Senior Member
  • LSP Moderator
  • 7,334 posts
  • Gender:Male
Posted 27 September 2017 - 12:52 AM
More inclined to use standard two-part epoxy glue personally - more messy than the cyanoacrylates, but gives useful 'wiggle' time.
I think Milliput would be too thick and can't see a reason to use an epoxy putty over an epoxy glue?
Iain
  • Harold and Zero77 like this
Iain Ogilvie - http://www.aeronut.co.uk
#6 Jennings Heilig
Jennings Heilig
    Senior Member
  • LSP_Members
  • 7,402 posts
  • Gender:Male
Posted 27 September 2017 - 01:26 AM
There would be nothing gained by doing this. Milliput is far too bulky to use as an adhesive. You’re much better off just using regular epoxy, or better CA.
"It's all part of the show..."
#7 nichenson
nichenson
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 268 posts
  • Gender:Male
Posted 27 September 2017 - 03:24 AM
I used it on my Kfir to hold some items like the wheelbays in place on the inside of the fuselage to make sure it was good and strong as well as no light getting through.  I would not advise it for joining small parts or something like joining halves as epoxy or superglue works best there.
#8 Tony T
Tony T
    Senior Member
  • LSP_Members
  • 5,020 posts
  • Gender:Male
Posted 27 September 2017 - 07:16 AM
Yes, ditto. I've been using it to lock-in Aries wheel wells on A-7Es after being fixed in place with CA glue - belt and braces. It also fills in any tiny gaps.
Tony
Finally spraying again
#9 Mustang JBB
Mustang JBB
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 84 posts
  • Gender:Male
Posted 27 September 2017 - 06:03 PM
Not yet.  I am getting my ducks lined up to build the Fisher X-1B and was thinking of how to approach the different building phases.  I have used Milliput before as a gap filler and similar strengthening of hidden joints.  I am going to experiment with scraps as soon as can get back to my bench.  I am away for two weeks, and day dreaming about building.
#10 Mustang JBB
Mustang JBB
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 84 posts
  • Gender:Male
Posted 27 September 2017 - 06:05 PM
The cost of the kit is definitely on my mind, that is why I am asking for advice.  As you suggest, I intend to experiment with scarps and pour stubs first.
#11 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 6,038 posts
  • Gender:Male
Posted 28 September 2017 - 09:16 AM
Personally, I would not do it for a simple reason: a Milliput seam will not resist to any shock... Keep in mind large scale kits means large parts and to glue fuselage parts, this is not really recommended as you need some structural strength.
As others wrote relying on epoxy glue is a far better solution and it offers similar gap-filling properties. However, as most glues, it is obviously less forgiving...
#12 ringleheim
ringleheim
    Senior Member
  • LSP_Members
  • 800 posts
  • Gender:Male
Posted 29 September 2017 - 05:28 AM
Thanks in advance!
James B
Yes, I use epoxy putty as a glue of sorts to glue homemade backpacks, sandbags, and gear onto the the rear decks of tank models.  It's a pretty common technique among armor modelers.
I should point out I have only done it on styrene; I guess there could be a bonding issue with resin specifically, but I bet it would work fine.
This video tutorial discusses and shows what you are trying to do.
#13 Zero77
Zero77
    Senior Member
  • LSP_Members
  • 5,942 posts
  • Gender:Male
Posted 29 September 2017 - 12:28 PM
In my opinion, it's doubtful that milliput would provide enough tackiness and strenght to get a secure bond on large parts like fuselage halves.
Following the big Photobucket rip-off attempt, all my pictures on the forum cannot display anymore. I try to reupload the RFI pictures, but i'm not sure i'd have enough time and energy to reupload the pictures of the WIP threads. If you're interested in a specific subject and want me to reupload some pictures, just let me know. :)
Finished : F-16C Barak, F-4J VMF333, Czech Mig-19PM, Bell X-1, Russian Su-25 in Chechnya, Ta152H-1, Czech Avia S.199, Heinkel He162, Swiss AF Bf109G-6, Regia Aeronautica Bf109G-6, P-47D "Slick Chick", RFC Sopwith Pup, A5M2 Claude, Schneider Cup 1926 Macchi M.39, German F-104G JaboG34, Curtiss P-6E, Curtiss P-36A USAAC, Piper SuperCub floatplane (PA-18-150), Russian built Nieuport 11, Albatros D.Va Seefrontstaffel 1, Bf109G-12 (two-seater trainer), Texas ANG F-86D,  Post-war Hawker Tempest Mk.V, Bf109E-3, F-35A 34th FS
Also tagged with one or more of these keywords: milliput, resin, adhesive
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
