CANicoll Posted July 23, 2017 Share Posted July 23, 2017 I'm sure someone here knows this off the top of their heads - but the IP modeled by Barracuda for the Tamiya 1/32 P-51 (BARBR32013). Did they model an early (before -20) or after -20 IP? I'm finding some conflicting references. Thanks! Chris Link to comment Share on other sites More sharing options...
cbk57 Posted July 23, 2017 Share Posted July 23, 2017 It is the post -20 IP. From what I can find, minus the white line found on early instrument panels and a couple really subtle details a very accurate IP can be made from the stock kit parts. You do need to make the divider line which follows a little different pattern in white, where latter it was in yellow. The gauge layout changed a little also latter that is why the Baracuda set is not right for a -20. Link to comment Share on other sites More sharing options...
