DougN Posted June 24, 2016 Share Posted June 24, 2016 My plan is to correct the wing using the wings from a second kit, and cutting them up to add in the missing length (three ribs on each side if I recall correctly). You should be blue to do it and only have to deal with one join on each side. I would think you could get a second kit for less than the cost of the resin replacement wings. Link to comment Share on other sites More sharing options...
DerekB Posted June 4, 2017 Share Posted June 4, 2017 (edited) Hi, how do the prop and hub holdings look in this kit? I'm searching for a decent copy of the 3D40 hub like this one... Edited June 4, 2017 by DerekB Link to comment Share on other sites More sharing options...
ltdann Posted November 14, 2017 Share Posted November 14, 2017 I have discovered a significant change to the F3F-3 from the F3F-2 that I never noticed or understood, until now. If you look closely at a 3/4 view of the aircraft from the tail looking forward, there is a crescent shaped opening that starts near the aft cabane strut and goes all the way down to the wing fillet fairing. Grumman attempted to clean up the design by fairing the cowling and fuselage a bit more closely. In essence, the fuselage is wider on the -3 from the aft cabane strut all the way to the cowling. That crescent shaped opening also eliminated the need for CO2 vents in the accessory section and near the horizontal tails. The cowl was also slightly different, and the exhausts are faired. Rich Dann Link to comment Share on other sites More sharing options...
Troy Molitor Posted November 14, 2017 Share Posted November 14, 2017 The F3F-3 is really a nice looking bird you don't see every day. I'm looking forward to this one progressing along. Troy Link to comment Share on other sites More sharing options...
